ESP drivers; LCA?
Car: 2004 Mazda RX-8
Engine: 1.3l Renesis
Axle/Gears: \
ESP drivers; LCA?
What are you guys doing about LCA bushings? I am seriously considering getting my car preppred for ESP, which would entail going back to a factory motor... and some roll back on my suspension mods. From my understanding of the rules established for ESP, rotojoints, heims, polyballs, etc; are NOT legal for the car.. nor are LCARBs
What are your solutions? Just stock LCAs with poly? Poly/rubber combo? There don't seem to be a lot of options as set in the book.
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Re: ESP drivers; LCA?
Do they say anything about aluminum??? Reason I ask is way back I used aluminum bushings in stock control arms. just food for thought.
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
If you need something that articulates.... you can use something like this:
http://www.howeracing.com/p-7603-rub...ing-joint.aspx
It's one of the reasons I got rod-end LCA's, because I can put almost any end bushings I want on them whenever I want.
