Kirkey pro-street seat
Car: 92 Camaro z28
Engine: 427 sb
Transmission: th400
Axle/Gears: 9"/4.30
What width size seat does everyone use? I'm upgrading my 10 pt. cage to 25.5 and still have factory interior.
1 Post
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Re: Kirkey pro-street seat
Depends on how wide your a** is.....
FWIW, I am 6' and 185 lbs and am using a 17.5" seat.
I'm 5'11 and 195lbs and I'm using the 41700(17" hip), fits awesome.
I just installed the cage in my car so I haven't driven or raced with them yet, but I have made motor sounds while sitting in the seat
Seriously, go to their site, they say how to measure your butt for the right seat.
If you're going to put kirkey's into a 3rd gen for the driver seat, use this! I did.
http://www.racecraft.com/index.php?m...roducts_id=249
As for the passenger side( if you're putting in a kirkey there), don't use this!
http://www.racecraft.com/index.php?m...roducts_id=250
It doesn't work.
I did this for the passenger
Then drilled holes in the back, put some square tubing underneath it and bolted it to the stock bolts
It doesn't work.
