15 x10's, talk to me about back spacing
Car: 92 GTA
Transmission: A-4
Tried posting this in the wheel and tire section and didn't get much help, figure I'll try it here. I currently have a set of 15x8 drag lites with 4.5" BS and they look good on the car with 275/50/15 (26") Hoosier Dr's. I will be buying a set of RT-S' and I want to go with a 15x10 in the rear. I want to fit a 275/60/15 (28") tall Hoosier Dr or MT radial pro. I am torn between a 5.5" and 6.5" BS. I like the look of the 6.5 but it seems like a lot of work. Also seems like you have to change the suspension up a little bit. On the flip side I have seen pics of the 5.5" BS that look good and flush with the wheel wells and other pics where it looks like Joe Dirt's car. Pics and advice welcome. I know the 275 radials aren't all that wide. Just want the car too look good, retain all stock style suspension and not rub with a slightly lower stance.
Here's the car with the 15x8's. I like the placement of the tire in the wheel well. I'm going for this look with a wider rim and taller tire.
Car: 92 GTA
Transmission: A-4
Re: 15 x10's, talk to me about back spacing
Thanks guys. 15x9 with a 5.5 was my original plan but I would like to have the extra inch if it's that easy. mw66nove, I love you car. The rear wheels look right.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The 28" Hoosiers should fit with no problems on a 10" rim with 5.5" of backspace. You could go with a 6.5" backspace to tuck them under the fenders a little more but also may need to do some inner clearance work with the bump stops and maybe the front radius of the inner fender. Tucking the tires under the fender more really depends on the tire height. It's not the inner frame rails or bump stop that causes the most problems. It's that the taller tire needs more room at the front and rear of the wheel opening on the inside because the inner fender wraps around.
Either rim will work just fine however the 5.5" choice is more common and easier to use.
Car: 92 GTA
Transmission: A-4
I only run radials so my tire choice is either a 275/60/15 DOT Hoosier radial or new MT ET street radial pros. I might run the stand ET street radial on the street from time to time. No bias ply's, no 295's, no "W" tires. I would like to see some more pics of 5.5" BS because some look good and other stick out too much for my liking. Also I'm not sure how and fender well cutting will work with my GFX.
it won't effect your GFX at all. all the cutting happens on the inner fender, nothing outside.
bump stop area cut out.
you can either box it when you're done or not. this was a little extreme, i could have done it differently probably, so i boxed mine back in. here it is boxed back in:
i did the mods like the pictures above, and 28x10.5 hoosier slicks were still a tight fit with a 15x10 5.5 bs. no way in the world could i have used a 6.5 bs on my car, but what i am thinking is the rearend that was in the car before i got it was a little bit narrower than stock. 275 60 15's fit pretty easily, though.
Car: 92 GTA
Transmission: A-4
Car: 92 GTA
Transmission: A-4
Yeah, mini-tub is the last thing I want to do. It seems like a lot of guys have gotten 6.5" BS wheels to fit with minimal work and they run bigger tires.
When it comes down to it a 15x10 with 6" BS is really what you need, but there's very few of them out there. I'm another one that just went with a 15x9 with 5.5" BS (275/60-15), which is the same offset as the 6" bs, since 10" is on the wide side for most of the tires people try to run on these cars (and actually above spec for a few 275 and 10" DOT tires).
If you insist on a 10 and don't want to find a 6" BS, then you have to make a choice, 5.5 and have most sidewalls stick out a little (but the tread is in the fenders), or 6.5 and have to do some cutting/hammer work to the insides (honestly, with a 28" tall tire, even the 6" BS requires some hammer work in the front of the wheel well to clear >27" tall tire)
Car: 85 Trans Am
Engine: 383 ci
Transmission: Liberty Geared Tko 600
Axle/Gears: Moser 9" 4.11 gear wavetrac locker
here is a look at 15x9 5 bs. with the rear narrowed .5 on each side. So a total of 5.5 inch of bs
Car: 85 Trans Am
Engine: 383 ci
Here is a 15x10 with 5.5 bs and .5 narrowed on each side
Car: 85 Trans Am
Engine: 383 ci
Here is 15x8 with 4.5 bs and stock rear all pics are shown 275-60r15 mt drag radial
Car: 92 GTA
Transmission: A-4
Thanks. I like the look of the 15x9's. I just hope the narrower rim won't beat up the sidewall if you run the radials with low pressure.
Car: 92 GTA
Transmission: A-4
I know you're not supposed to. I have raced in unrepped events and I used to run on the street with my last car. I ran a 275/40/17 Hoosier Dr all the way down to 11-13 psi on occasion and got it to hook on ice. An 8" rim also may cause the car to sway a bit because you lose some side wall integrity but putting a wide tire on a narrow rim. I'm just wondering how much that is present on a 275/60/15 on a 8,9 and 10" rim. I have never ran a 15" rim or 28" drag radial and my car will be grudge raced quite a bit, probably won't be on the street though.
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
I run a 4th gen width 9", 2" wider then a thirdgen. I run 15 x10's with 7.5" backspace and 1/2" spacers, effectively making it a 7" BS. I had to do about 15 seconds worth of hammering at the front of the drivers side wheel well and cut out the bump stops. They fit like a glove.
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
^^^ nice car ^^^^
I run a 4th gen rear with 15x9 wheels with a 6.5 bs. That's with a 275 radial, and minimal removal around bumpstop
Car: 1984 camaro z28
Engine: sbc 383
Transmission: Th400
Axle/Gears: Moser 9", 4.11 gear
Here are a couple of mine, 15x8 with a 28x10.5 slick and 5.5" backspacing. Required minimal "massaging".
Car: 92 GTA
Transmission: A-4
Nice looking cars guys, keep them coming. I'm still looking for some pics of 15x10 w/ 5.5 BS.
Car: 92 GTA
Transmission: A-4
I completely agree with you. That is the look I want to stay very far away from. Looks like 6.5 is the only option for a 15x10 for me. Otherwise it's a 15x9 with a 5.5 BS.
Car: 89 GTA
Engine: 400
Transmission: 400
Axle/Gears: 9 inch 355
Car: 92 GTA
Transmission: A-4
Yeah, 15x10 6.5 BS it is. Thanks guys.
Ogie, nice shot of Vito in your first pic.
Car: 89 GTA
Engine: 400
Transmission: 400
If you want any pictures of the car with the 275 Pro Radials I can post them also. But I figured that the slick is slightly bigger .
#43
or you can stuff 29/13/15 on a Weld RTS 10x15 6.5 Back space. (9"ford)
looks like this
and
could only go this tall of tire (29" tall) GFX stops me from going 30" tall... but the 4.11 gears and 29" tall tires are fantastic
SMALL bit o work
but it all in the name of fun
looks like this
and
SMALL bit o work
#45
note all the above shots of rims are of the RTS wheels all the wheels in the rts line run .275 over what ever width you order in anything over 8"
expl a 10" wide wheel will be 10.257 wide same for the 9"wide =9.275 wide
as with the 9" wide wheel with the 6.5 back space runs close to the out side
= spokes looking flush with rim face. with stock rear disck brakes you can run a low pad wheel with a 5.5 back space and fit the smaller 275 tire tucked under.
I my self like the look of the off set=more dish looking
this below shot shows 15x8 welds 4.5 back space 28/12.5 et streets
cars on stands but wheels & tires fit. with out any mods for years ran fine.
it was time for updating the car.
so now the 29/13/15 sportsmen look like this on the 10.275/6.5 BS/15Weld RTS wheels
and
and just to show size
I like it
lets not forget a few aftermarket parts to go with/work with this size of rim
below shot shows a bit of info
and
I like it
#46
the sportsmen tires have a overly large balloon side wall. a set of 325/50/15 drag radials are 1" shorter at 28" tall and are 1/2" wider. but are less bulbous on the side wall. and would fit even better. still tucking under even better
#49
cuzz that was the 10 sec ticket back in the 90's.when weld drag lites sold like hot cakes
and you have to keep the LCA 's on the car with SSM bars/ladderbars. to run just the bars is wrong/Dangerous. even SSM stated in the install info to Keep them.
Contrary to what a few Folks THINK...there is No Binding. or what ever they seem to think..the guys who did not run the LCA broke parts and gave up.. this set up has over 500 track hits on it..
most of them in the 10.50's a few in the 11.70's.. but that's back in the 90's when it was 50 state smog ligt.
it's getting backhalf soon. this is also the last small block (427) im doing,,ever!
it's 572's as a base.. for now on...
#50
thanks..OD shows 50.000 miles..thats what I get for locking it away for over 10 years..
but now with a new house and a new 40x40 shop just for the car and weekends to finnish some upgrades..who knows...
but it's not going to look like this anymore... 165/15's in front 28/12.5/15's in back
