battery disconnect switch
1 Post
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
how do i hookup the alternator part to a two post kill switch (battery shutoff switch)? my switch shuts off but car still runs. it runs to a ford selonoid on firewall. do i run a wire from the battery swtich "off" to the red wire on the alt or the connector part on top of the alternator? alt i have http://www.summitracing.com/parts/sum-811001.
__________________
__________________
1 Post
Car: 1989 Firebird Formula
Engine: 385
Transmission: Full Manual TH350
Axle/Gears: Moser 9" 3.70
Re: battery disconnect switch
I run my wire from the alternator to the battery. Then I run the battery to the switch, and switch up to the starter. This way, all current from the alternator has to pass through the switch.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Simply disconnecting the battery will not kill an engine in an OEM setup. The alternator is backfeeding into the system so the ignition etc is still getting power.
Best way is to run the main power wire off the back of the alternator all the way to the battery power post or input side of the kill switch. Master switch turned off will kill everything including power to the alternator which is keeping your car running. It should be at least 10 gauge but 8 gauge is better. You will have 2 wires running to the battery. Main power and alternator power.
Master switch needs to disconnect the positive cable from the battery.
my battery isnt remote mounted but i changed the wiring on my car since the po hacked the wiring to hell.
i put the alternator feed wire on the same relay as my ignition coil, kill the switch that controls the relay and the engine shuts off , if the battery was in the trunk and somone hit the battery disconect using this method it would also shut down . then u have no need to run the alt charging wire to the trunk
1 Post
Engine: 385
Yes, the switch kills the car as of present. The alternator and battery are on the same side of the switch. The wire to the starter and everything else is on the other side of the switch. All current from the battery and alternator runs through the killswitch.
Car: 87 IROC L98
I use relays in mine. When the master switch is turned off, relay power for the ignition and alternator field are disconnected and everything electrical in the car is killed.
