a different kind of muffler question.
if you have ever gone from a chambered muffler to a straight through muffler, and gained or lost performance, please post up your gains/losses. i'm having a debate on another board and need at least 30 (according to the central limit theorem) scenarios so i can form a proper hypothesis and interval test. depending on where this goes, i may use it as my senior paper, lol.
thanks for the help guys!
Ps, please provide DA data for the runs so I can standardize the info. I put this in this section because it directly correlates to drag racing. it should be noted that for this test, only n/a cars/trucks will be considered as a turbo or blower might skew the data.
Re: a different kind of muffler question.
so i'll start, format should be as follows
Muffler type: Moroso spiral mufflers
DA: 2400'
1/4mile mph: 121.8
1/4 et: 11.31
Muffler type: Dynomax Bullet
DA: 3200'
1/4 MPH: 122.4
1/4 ET: 11.26
i will then take your data, and correct it for DA to sea level using dragtimes da calculator, which is universally accepted as accurate. here's the link:http://www.dragtimes.com/da-density-...calculator.php
i will use the stock/midly modified results across the board for standardizing.
new corrected times:
Muffler type: Moroso Spiral
1/4 MPH: 125.4
1/4 ET: 10.99
1/4 MPH: 127.4
1/4 ET: 10.83
so the gains seen in this scenario was +2mph and -.16 in ET. once i get 30 scenarios, i can then apply the central limit theorem that says if the mean values of the sample are normally distributed, then the mean values of the population are normally distributed. i can then do some hypothesis testing to see if all mean's are essentially equal, and if i have any outliers (like the one pass mentioned in another thread...lets see if it's mathematically believable).
DA: 2400'
1/4mile mph: 121.8
1/4 et: 11.31
DA: 3200'
1/4 MPH: 122.4
1/4 ET: 11.26
1/4 MPH: 125.4
1/4 ET: 10.99
1/4 MPH: 127.4
1/4 ET: 10.83
yes, i'm just using my best time for each, trying to keep just the muffler being the changed variable. it's pretty tough getting data together for this actually, lol. i think i had 6 passes or so each night one muffler to the other. i'm comparing DA's, and correcting et/mph for sea level, then converting to HP based on weight and mph. there are so many variables that it would take several months to get this straigth if i didn't assume some things as constants. i wish i had thought of this 6 weeks ago, as i'd go way further in depth, but with only 2 weeks left, i need to just get my data and start going, lol.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Wish I could help Matt. Never ran the dang 89 once I went from 1 chambers to bullets before I wrecked it. Would have been 1/8th mile anyway. But I also swapped clutches. Would have made the data wrong.
Good luck, will be in for final results.
Apparently there's a lot to be gained (or lost) with attention paid to this area.
How to Build Max Perf Chevy Small-Blocks on a Budget (Performance How-To): David Vizard: 9781932494846: Amazon.com: Books
(Why the link is shown twice I can't explain. There's only one book)
I've scanned a section from the exhaust chapter which I think is relevant to your research.
I'll check it out, thanks man. Currently, I have enough data to do a nom-parametric method, whiz is what I may do. If not, my paper will be on some sort of sports probability, but I'll still do the hypothesis testing on here to find out what we're looking at.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
From 5 years ago:
Flowmaster 80 series crossflow (3" in, dual 2-1/2" out), ran a best of 14.61 @ 93 MPH, worst of 14.88 @ 93, with some 14.7's @ 94. Best 60' 2.11. Calm winds, DA 8200', 5/8 gas tank.
A week later, with Magnaflow single 3" in/out, rest of the exhaust and car the same. First run DA 7200', 1/2 tank gas, 5 MPH headwind, ran a 14.33 @ 95.17. 60' 2.07. Next TT, DA 6800', 5 MPH headwind, 14.31 @ 95.47 MPH.
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
ive been doing alot of research myself on the exhuast setups this might help with your project
http://ls1sounds.com/faq.htm
look at the bottom of the page they have dyno chart showing power gains or losses with different muffler
also decibl read outs at idle and wot
Is it muffler construction i.e., glass pack (like a Cherry Bomb) vs chambered (like a Flowmaster), that you're interested in as a comparison or muffler cfm?
In 57Kid's example, it appears to be a flow related increase in output that produced the numbers he's presented. If I understand correctly, a Flowmaster and a Magnaflow are roughly of the same design (internal chambers or baffles) hence my flow related comment. The results he experienced are similar to my experiment with a single cutout located directly before my stock location muffler. The increased flow achieved in bypassing the muffler saw almost a tenth reduction in et and over 1 mph gain in last years 1/8 mile testing.
8.124 @ 83.82 1.81 60’
8.070 @ 85.14 1.81 60’ 3700 lbs race weight.
This is different from what might result from a glass pack being installed in the same location. The glass pack acting as more of an extension of the full exhaust system thereby changing the pressure wave characteristcs as seen at the exhaust valve and the resulting "tune".
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
Why do you say the test can't be with a supercharged engine? I'm pretty sure the exhaust system has no idea what is going on in front of the intake valve.
The main thing to know about exhaust systems is that if it flows good at high rpm, it won't flow good at low rpm. And if it flows good at low rpm, it won't flow good at high rpm.
There's no such thing as a perfect exhaust system.
Gunner242
12-25-2015 04:49 PM
