How is my shifting?
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
How is my shifting?
Car has a Pro 5.0 shifter. I think once I get the tune dialed in, and the 9" installed I am going to play with the devil and get some slicks. The street tires and clutch slipping sucked.
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Re: How is my shifting?
http://www.youtube.com/watch?v=zZa-t...6hQ44g&index=1
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Shitty. I am not worried about my E.T, just trying to figure out how much room I have to improve on my shifting.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Looks like your shifter is clunky and of very smooth. I use a stock Hurst and a short stick with my Trans. Was great, after the rebuild it was like butter. Keep at it, but from what I can tell, that shifter is not in your element yet.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You need more gear. RPMs are still climbing in fourth gear as you cross the finish line. Of course a deeper gear will make traction even worse. Shifting at a slightly higher rpm will do the same thing unless you're already shifting at maximum rpm.
I can't comment on your shifting ability. H pattern shifters with a clutch is not an ideal drag strip transmission to begin with. It's hard on gears but once you get moving, it's faster to shift without using the clutch. Every time that clutch pedal goes down and the throttle lifts, you're coasting, not accelerating.
Very short throws would really help.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I'm getting a 9" with 3.90 gears or so installed this year while I am deployed. Car is also getting LCARBs and Slicks for the track next.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Should go with deeper gears, but 3.90 will be ok with a 26 inch tall tire. Just keep banging gears. Only way to get better.
Car: 1989 Trans Am GTA
Transmission: M28 T56
3-4 looked a little delayed, like the 3-4 upshift syncho's might have been worn, or you just took some time to get it into 4th.
Otherwise your shifting looks like every other guy I've seen shifting a H-pattern box that didn't want to hate on the transmission.
You can start power shifting it without the clutch, but its HARD on the syncho's. And its very possible to shear teeth off if you screw it up.
I say if you want ultimate drag times, go auto. If you enjoy driving manual, shift it fast, but use the clutch. Stock or stock rebuilt transmissions don't like clutchless shifting.
just to make sure i understand what is being said .
there is a way to shift a synchronized transmission without using a cluth to release one gear and engauge another gear without lifting off the throttle?
I have never seen that.
You can leave your foot on the accelerator on the floor , pushing or pulling on the shifter for the next gear and then stab the clutch to release the gear and it will go into the next gear.
I would like to see a vid where the clutch pedal is not depressed on a conventional synchronized trans while drag racing
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Car: 84 Transm
Engine: 350 sbc
Transmission: t400
Axle/Gears: ford 9", 3.90
Getting the fastest shifts can be hard on components. But if you want the fastest shift. First off, dont let off the gas when you shift. Hold light force on the shifter towards your next gear prior to your shift into your next gear. As the clutch releases, you will feel the shifter free up. Use strong fast force to continue into the next gear. Be fast! Also, when you shift, just stab the clutch as fast as possible. Straight up and down without delay. Practice makes perfect.
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
I found it easier to start with 1/4 pedal then move to 1/2 power shifts and so on.
darwinprice
17
10-11-2015 11:51 PM
