3rd gen weight...is this right ?
#51
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 3rd gen weight...is this right ?
Luckily I don't race in a class that has weight restrictions. I can make my car as light as possible if I somehow could. Ballast in the nose to help keep the front end down is common in very fast cars. Go check a ProMod car someday when the body is off it and look at all the lead weights bolted to the front of the frame.
Keeping the rear glass to "add weight over the tires" is the wrong attitude. It may help some traction in a poorly setup chassis but it's still extra weight that the engine needs to move down the track. It's all about power to weight. If you want to go fast, removing the weight is easier than making more HP. If I really wanted to go faster, I'd sell off my car as a rolling chassis and drop my engine into an altered. A dragster would be nice but I have no place to put it.
#52
1 Post
Car: 1989 Firebird Formula
Engine: 385
Transmission: Full Manual TH350
Axle/Gears: Moser 9" 3.70
Slightly off topic, but Ray, were you at Norwalk in early October? I believe its your car I have many many pics of, and a video making a pass. If its you, that is one clean car. Pictures don't do it justice. I've seen it in person, and it made my jaw drop. Looking at your pictures on here, it looks to be the same
#53
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
Im not arguing that it is always necessary...however, most cars work best with 51-52% on the nose, using the suspension and chassis to hook the car instead of the tire alone. 55% or more on the nose wont fly with a lot of HP on a lightweight radial car...car will wheelie or spin alot.
We have several all motor cars that run faster heavier with the ballast in the rear...nothing else changed...including an n/a 468 3500lb chevelle that goes 9.1s @ 146 with a 1.23 60'
I have talked a lot with the local x275 guys bruder, rhodes, marinis, etc and they ALL use ballast...
#56
