Stuck in the 10s with my 355
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
Well...we swapped my 4.10 gears for 4.33s because I have been 500rpm shy at the stripe all season...and thought that would put me in the 9.90s.
After making 5 passes spinning at Capitol Raceway with no track prep hardly...i lowered my launch rpm and added 25# more to the rear...and only netted a 10.14 @132.56mph with a 1.39 60'.
Weather wasn't good and we had 5 rain delays and finally got rained out before I could make another try leaving harder...but in good air it was a 10.04 pass according to the weather station.
So...the 255 radials are done....bald...worn out. Were putting 275 Hoosiers on today so we can finish the season. Over the winter we will change to 4.56 gears which should work better.
I wanted to go 9s on my little tires!!!
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
Re: Stuck in the 10s with my 355
Lol..thanks matt. I had a set of hoosiers already.
Its just a 12.5:1 355
brodix track 1 heads
solid roller cam
Just put the 275oa on the car
solid roller cam
codeysabatini
11-10-2015 04:07 PM
darwinprice
17
10-11-2015 11:51 PM
