What does your car weigh?
Car: '88 IROC-Z medium orange metallic
Just curious as to what other cars weigh. Mine seems a bit heavy. Two scales at different tracks show 3600 lbs.
Engine bay is stripped. Just the engine, radiator and ignition system. No power steering. Dash is stripped of all of the vents. Stock wiring harness is gone. Body is all steel except a glass hood. Only change to the interior is the removal of the back seat. Added some weight with a TH400, steel 8 point roll bar, sfc's and Spohn torque arm but still dont think it should be 3600 lbs.
Re: What does your car weigh?
Did you weigh it on MIR's digital scales? Mine was 3450 with me in it. I weigh 180. 100% full interior. Heavy comp engineering sfc's, no ps/ac, but ac box and evaporator still in place, everything under the hood down to the cruise control still there, no roll cage.
Car: 86 MCSS-87 Z28
Transmission: Auto OD-5spd
Axle/Gears: 3.73 both cars
3360 lbs 51% front 49% rear Mild steel cage, Th400 trans, frame connectors, pretty much stripped otherwise.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
LS1/4L60E car: 3440 going down the track with me in it. (3390 going down the track with my son in it...).
somewhere round 3050-3100 with me in it. had plenty more weight i could have taken out.
crash bars still in doors
electric hatch pulldown
rear bumper support
rear seat mounts
front bumper support frame snouts
power window motors
power locks
headlight motors/hardware
stock type steering gearbox/linkage (rack is probably lighter)
rear bumper support
rear seat mounts
power window motors
power locks
1 Post
Car: 1989 Iroc Z L98
I think the best bang for the buck weight reduction on our cars is aftermarket seats. I am in the process of doing this right now, my driver's seat was just over 50 pounds (cloth power) and my passenger seat was 35 pounds (cloth manual). My summit seats are 12 pounds each, should be at least 50 pounds of weight savings including brackets.
What wheels and tires are you running? I know there can be significant weight savings going to 15" weld wheels.
3260 (car only)
~DaVe
~DaVe
1 Post
Oh and for my cars, my old car was a 1982 Camaro Berlinetta with:
Fiberglass hood, aluminum heads, no HVAC, no interior, no front sway bar, etc
It weighed 3050 without me in it, about 3300 with me in it.
My current car is a 1989 Iroc Z 5.7 L, I have taken a few steps to reduce weight, it must have been a pig before because now I have it down to about 3350 pounds, although I am hoping closer to 3300 after I replace the seats.
Thanks for the replies. I'll see about weighing it on a more accurate set of scales. Based on the responses the car shouldn't be that heavy.
Car: 1990 GTA
3808 with me in the car, full interior, floor dynamated, Spohn SFC's and control arms, I weigh 208lbs, A/c and everything is still in the car.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I weigh my car at the start of every year to get the race weight for the season after all the winter modifications are done. Spring of 2011, my race weight was 3030 pounds with 1780 on the nose and 1250 on the slicks.
My car is still up on jack stands. I just fired the new engine up yesterday but the weight shouldn't be a whole lot different from last year. I didn't do much over the winter except replace the engine.
I weigh around 180 pounds but I don't really care what the car weighs by itself except when it's in the trailer. Once I'm in it, that's the total weight the engine has to move down the track.
Car: 1987 Camaro
Engine: 406
Axle/Gears: Moser 31 spline / 4.86
3230 last time I weighed it before the tubular k-member, a-arms and coil overs. That was also with the old body kit on it. That's 3000 lbs without me in it.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
3150 without my in. Front, rear, and door impact bars gone. Carpet gone with light weight stuff i put in, was with jegs race seats, rear seats in place. 6.0 iron block and T56, 12 bolt Moser, all tubular suspension, CE heavy sub frames with weld wheels, glass 4 inch hood.
Add me and it is 3450.
Car: 1991 Camaro RS
Engine: BBC 509 Merlin ii 9.6:1 pump gas
Transmission: ATI pro th350 sfi case. TSI 5500 st
Axle/Gears: Strange S60 4:10s
3060Lbs without me in the car (wet full tank)
3240lbs With me in the car(race weight) Always 5 gal app. in the tank.
Car: 1991 Firebird
Axle/Gears: 3.42 w/auburn racers diff
1991 LO3 With A/C T5 all stock Full interior (spare tire and jack in hatch) full gas tank weighed at a certified scale for fruit trucks.
3400Lbs without me in the car.
Car: projects.......
The camaro was 2950 with me in it ready to race. Should be down around our allowed 2700 when it comes back out.
Mustang is 2550 with me in it & could easily be another 100-200lbs lighter with a few bolt-on light weight components.
I'm right around 190lbs.
3580 full interier full tank of gas an full cooler of beer , plus about 50-75 lbs of tools at the time .
Thanks for the replies! Working on moving the battery and some suspension mods to get this PIG moving.
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Fiber glass hood and aluminum heads. 1/4 tank of fuel and no driver the car comes in at 3250lbs.
That's with SSM sub frames and Founders PHB/LCAs..
AC and emissions delete
Ya know these cars wt is too damm much.Glass front end,doors,seats,deck lid with lexin,and now your talking.Oh ya..........for me a diet.......eeeeuuuuu!!!.
Other than the hood, a glass nose is a waste of $. Less than 10# difference from a gutted clip. Same goes for the deck lid. - Lots more places to take out more weight for less cost.
I do know there is a big difference between race glass and standard replacement glass parts.Do the race glass parts require maintenance being thinner and cracking??.Yes-yes they do.But I would think the race glass is alot more light than just 10#.
One thing for sure.I am amazed at what these things wt stock.We have had a number of them,but all where shelled out to the extent of pretty much all that was left of them was the roofs and the sides where glass panels on a tube frame that met a super gas wt or just a touch less.
Car: Camaro
Engine: 305-150/254 combo
Transmission: TH350 or T200
Axle/Gears: Srange 12 bolt; 5.14 or 5.38
Mine comes in at 3000 lbs in G/SA. It has stock front seats, stock interior with rear seat removed for the m.s roll bar, stock front suspension, etc. When I started bracket racing this car it weighed just over 3600 lbs until I put it on a diet.
I got crazy respect for you guys in those classes.What you guys do is just outstanding!!!.
Car: Camaro
i like my full interior and power windows
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
Depending on class I weight 3250-3400lbs with me in it. 25.5 chassis with 80% interior intact
It's not. - The stock fenders & bumper are still on my '86 for that reason. I can easily pick the complete clip up by myself when it's off the car(pops on/off like a lift-off 'glass nose would). Our full tube '85 stang has a light lay-up glass clip and it is actually heavier than the camaro's clip.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Mine is 3480 with me in it (I'm 190).
I took a lot of weight out with aluminum heads, notchback hatch, no a/c; but added quite a bit back in - subframes, heavy (upgraded) suspension parts, 12 bolt, system... I am pulling some of the system out and that is going to save 30lbs and still sound good, along with some other items.
My 85 is 2705 full of fluids and fuel with no driver. It's gutted with lexan windows. Still a couple of hundred pounds to go if I replace the rear hatch and K member.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Car weighed in at 3280 without me and a 1/4 tank of gas with the old 700r4... Changes are...
heavy 4th gen seats, SFC, Strut Tower Bar, Wonderbar, Aluminum heads, AC delete...
when you go to do a k-member, give TRZ a look. they have a really nice one available with a removable center bar. with a car that gutted im assuming it has motor plates or will have motor plates when you do a k-member, and TRZ's piece is only available that way i believe.
Biggest reason to do a tubular k-member is space. Opens up a lot of room to work around the motor.
The rear glass window is stupid heavy though, but if he's already got a lexan replacement in then definitely not a lot left to take out. - Everything adds up in the end though. "start taking off ounces & the pounds fall off"
#44
i must have one of them hevy K members. cuss mine was 21lbs more then my tube steel K Member.. and the A arms are just about 5lbs more ea, then my Tube steel A arms..Just me?
and the Recaro profi seats..wow, seats are about 10lbs ea before rails
and F.I.A. rated
#45
took my car out for the street night with full size wheels/tires and all the interior back in and near full tank of gas....3510lbs!
i went and bought some 165/80/15's for my skinnies this week, and am getting some drag radials for my rears to get off the heavy iroc wheels, lol
#46
Well if you want light and got money:
http://cgi.ebay.com/ebaymotors/Chass...item337a3b1c64
That does go against what I have said about buying rollers,but still..........
Want to add you do want to buy one with a cert sticker on it.
#47
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
3,650 empty because its a fully loaded options '92
#48
1 Post
Car: 91 Camaro RS
Engine: 6.0 lq9 ls bored to 408
Transmission: T56 6 speed
Axle/Gears: strange s60 4.10 with a spool
im 3610 with me in it at the track.
it was 3590 with my 10 bolt but since s60 it jumped to 3660. and somewhere i pulled 50 pounds out somewhere. i would like to say it came off of me but we all know thats not the case. i tip the scales at 190 or so
car is full interior only thing missing is the back seat backs. i have a 8 point cage and my ac is out but i still have a few components of the system in place.
may try to drop it by a 100 or so pounds at some point here. my bigger focus is to move the battery to the trunk and remove my front sway bar soon.
#50
Car: 86 firebird
Engine: 385 dart pro 1 heads 13 to 1
Transmission: th350 4800 stall
Axle/Gears: 33 spline nine inch
2880 withe me in it. No interior. 1 racing seat. 8 point. Glass hood. Aftermarket k member. Small block aliminum heads. No accessories all brackets cut off. 9 inch. Th350. Headlamps gutted. Still have to lose some stuff. Goal for next year is 2800 even. But it only sees the track.
