350 TPI auto, stock converter 60' times??
Car: 90 Formula
That pretty much sums it up. No 500 hp cars please. I am more interested in the guys with drag radials but whatever is fine slicks or street tires.
Thanks.
1990 Formula 350
Hooker Headers, Random Technology Exhaust, K&N, Airfoil, MSD 6A Ignition, Aftermarket chip, 3.42 Gears, Metco LCA's w/ brackets, F Body Perf. Panhard Rod and Strut Tower Brace, KYB AGX shocks in the rear, 1999 Formula Wheels, White Face Guage Overlays
Thanks.
1990 Formula 350
2.09 sec with my 91 gta 350 auto, comp ta tires the cheap HR ones were on the car when I got it last month, Car ran 14.44 at 95 mph stock except for slp cold air, temp sensor relocated, airfoil and afpr and dynomax catback
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
1.99 on my Firehawk SVX's that was on my 13.89 run
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM ClarkeMustGoNow***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Tony
Car: 90 Formula
Thanks for the replies. In case you were wondering, I just wanted to see where I was at the first 60' compared to everyone else. I think I can improve. With my setup on BFG Drag Radials I was able to hit a 1.935 and run a best of 14.09. I can't seem to tach my car up enough to get a real good launch because it starts to spin (my brakes are drums and they are horrible). My times should improve once I get my transmission to shift out of second before 5000 rpms. But I guess a stall and some slicks sound good right about now, too...
1990 Formula 350
1990 Formula 350
3504mula-
I don't think you need slicks or a new stall converter. If you are in the 1.9's in the 60 foot times, you can't be slipping that much.
I had the same problem with my car, the 2-3 shift was just too slow and by the time it finished it was over 5000 rpm and almost felt like the brakes came on for a second.
I'd put in a Corvette servo if you have not already done that. After that the 2-3 shift finished at 4800 - 4900.
Car: 90 Formula
91 Firebird-
Thanks for the reply.
I know I don't NEED a high stall or slicks,but I would like to be launching at more like 2200 rpms. I think it would help out a lot. I don't know if drag radials would handle that launch.
And I didn't know a vette servo changed your shift points. How hard is that to install? Is it inside the transmission?
Thanks for the help.
1990 Formula 350
1990 Formula 350
<font face="Verdana, Arial" size="2">Originally posted by 89mustang:
Wow you guys must be happy with those times. My stock 89 Mustang could only hit a 2.3 with 2.73 gears and stock tranny.</font>
later
tim
91 Camaro RS-LO3,Auto
New Times Coming Soon!
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
<font face="Verdana, Arial" size="2">Originally posted by 3504mula:
91 Firebird-
</font>
91 Firebird-
</font>
i think the stall speed would be a big help though. there are 2 ways to choose the best convertor.
the method i use is to match the flash stall to the rpm at which peak torque occurs. this will bring hte car out with all it's power on full song as soon as you whack the thing.
or you can choose a convertor that you can foot brake up to the peak torque rpm. this will have the car all wound up on peak power at the line.
hope this helps.
by the way i pull 1.91-1.92's with a stock cammed 305 TBI on hoosier quick time pro's.
later
tim
theshackle
03-05-2017 06:37 PM
