Tire Width
Tire Width
Can I fit 315 street slicks on my 92 camaro. I went to the track with brand new 255 dunlop sp sport 5000 tires and had 60' times of over 3 second, and I only had 3.08 gears with posi. I need traction!
98 NOS'd Camaro 3.8
92 Camaro RS 350 c.i.
98 NOS'd Camaro 3.8
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
315-wide tires won't help as much as Drag Radials would. Yes, you can fit them with the right backspacing and such, but the edges of the tires will -just- line up with the outside edge of the quarter panel. Last fall, I was able to pull 60-foot times of 1.9x seconds with my nearly-bald Comp T/A ZR's (255/50ZR16), although I also have a 2400 stall converter and the track was quite sticky. I'd say you need to either refine your launch technique (more or less burnout, don't bring the engine revs up while on the line, don't go to 100% throttle until you're out of the hole, etc). With 275/50R15 Drag Radials with too much air pressure, my new 355 engine, and the converter now stalling at 2600 rpm, I was able to pull 60-foot times in the mid to high 1.8 second range.
Greg Westphal
'87 IROC 355TPI/A4
Greg Westphal
'87 IROC 355TPI/A4
Cleaning up my launch is plan B, because when I drop the clutch and go full throttle, I can hit lights consistently between .503 and .508, but when I'm nice to the car and ease out on the clutch my r/t's jump to high .6's or worse, so that's why I wanted traction first.
Thanks for the info.
98 NOS'd Camaro 3.8
98 NOS'd Camaro 3.8
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
If you want traction at the track then stay away from the street tires and buy some real slicks. Buy another set of rims and change them at the track.
<font face="Verdana, Arial" size="2">If you want traction at the track then stay away from the street tires and buy some real slicks. Buy another set of rims and change them at the track.</font>
82 Z28 383, Ported 215cc Dart Iron Eagle Heads 72 cc Comb. Chambers, Comp custom grind Hyd roller cam, Speed Pro .250" domes, Wheeler Motorsports 4340 I beam rods, Eagle 5140 steel crank, Weiand Team G intake, Holley 830 DP, hedman headers
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET:11.60 @ 114.56, w/ a 7.34 1/8 @ 93.50, and a 1.622 60'
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
Bassett Racing
LiquidBlue
Wheels and Tires
32
12-10-2019 04:06 PM
