Staging question
Staging question
ok, I fully accept your chuckles at this stupid question but I went to my first drag race the other day and I was wondering what is the differance between the two lights or just one at the top of the tree. What exactly is the differance and what are the benifits of staging the two diffent ways? I am crossing my fingers that their is a differance so I do not sound like a total dumb*ss. Thanks in advance guys.
Not a stupid question at all. It is intimidating the first time you go, but you'll get the hang of it!
The first single light is the Pre-stage light. It tells you that you're close to being fully staged(ready to race). The second set of two lights is to tell you that you have fully staged. Basically, most people hit the pre-stage lights and then creep foward to trip the second set of lights. Both sets of lights should be on at this point. This signals the tower that you are ready to race. Once both sides of the track are fully staged is when the light tree starts.
Some people like to do what is called "deep" staging. They will trip the second set of lights and then creep even more foward to turn the pre-stage lights off. So instead of the laser being at the front of your tires it is at the back. This will make the clock start sooner than if you had to roll all the way through the lights while you were taking off. This gives a better reaction time. I would suggest though tripping the staging lights and stopping as soon as possible because it will give you more time to get rolling before the clock starts.
Hope this makes sense.
88 firebird formula - 13.9 @103mph, 2.6 60ft
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
T56 - SIX-speed
open 3.73's
3 inch Flowmaster catback
I love pissing those LS1's off
My Formula
350 Vortec TBI
Edelbrock headers
T56 - SIX-speed
open 3.73's
My Formula
if you are going for ET's you will want to "shallow" stage. that means getting as barely into the beams as possible.
the easiest way to do this is to roll slowly into the prestage beams and stop as soon as they come on. then while applying some pressure to the brakes(just enough to hold the car still) give the gas a series of little pops, just enough to rev the car a little, when you get it right you will feel the car creep forward an inch at a time, this is good to practice in an empty parking lot.
just bump it until the full stage lamps just come on. this givews the car the most "roll out", which means the car actually has more space to roll forward before it leaves the beams and starts the timers.
later
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
later
tim
14.209@95.46mph
Best 60' 1.917
The difference you see in ET from an extra 3 inches of rollout could not be more then .02 seconds. I'd try both and whatever method gives you your best reaction time, without red lighting, do it.
I'd think even if you were just trying to get your best ET you'd want your best RT too?
Some people seem to do better shallow staging and hitting it a hair after the 2nd light comes on. I like to deep stage and hit it right when the 3rd light comes on.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I shallow stage and as soon as I see the last yellow light reach it's brightest (yes you can see them come on and go off) I go. By the time you and the car react, you should cut a good low .5xx light. It just takes practice to know how much of the third yellow to leave on.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
I now get it. It is so worth the 2 hour drive, drag racing is great. I only wish I could pay to play, right now I can only watch because I cannot afford to break something. One day though, I will definitely get into this.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Just turning on the 2nd light is the right method for a responsive race car. For highway-geared daily drivers, the deeper staging can be beneficial.
I went to test & tune last night with my '57, which not only has highway gears, but is heavy, too. My typical staging method has been to turn on the staged light and roll just a little more, but not turn off the prestage light. With the new Holley and my final .499 light on Sept 1, I wanted to try the more "normal" lights, just turning on the staged light. Although I didn't Rudolph all night (7 runs), my lights were more in the .540's to .570's (acceptable in most situations - certainly better than a .499). On my second-to-last run, I deep staged and let that yellow get real bright - .507 RT.
I don't know why we spend so much time talking about this. Everybody knows all there is to drag racing is flooring it when the light turns greeen...
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
[/B][/QUOTE]
But keep in mind if you wait for the actual green, your R/T will suck!
[/B][/QUOTE]
<font face="Verdana, Arial" size="2">The difference you see in ET from an extra 3 inches of rollout could not be more then .02 seconds. I'd try both and whatever method gives you your best reaction time, without red lighting, do it</font>
<font face="Verdana, Arial" size="2">I'd think even if you were just trying to get your best ET you'd want your best RT too?
Some people seem to do better shallow staging and hitting it a hair after the 2nd light comes on. I like to deep stage and hit it right when the 3rd light comes on</font>
It wouldn't matter at all what your RT was in relation to ET. You could have .800 RT, and a 12.00 run will still be a 12.00 Deep staging is really only benificial in Bracket racing, and when after your your best ever ET, you want to stage as shallow as you can. This has come up several times when I've driven some of friend's (or inexperienced driver's) cars, and they wonder how I am getting such a good 60' time compared to their's
82 Z28 383, Ported 215cc Dart Iron Eagle Heads 72 cc Comb. Chambers, Comp custom grind Hyd roller cam, Speed Pro .250" domes, Wheeler Motorsports 4340 I beam rods, Eagle 5140 steel crank, Weiand Team G intake, Holley 830 DP, hedman headers
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET:11.60 @ 114.56, w/ a 7.34 1/8 @ 93.50, and a 1.622 60'
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
Bassett Racing
[This message has been edited by Basett_Racing (edited September 24, 2001).]
toronto formula
11-10-2015 06:17 AM
