Can a car w/2.77 gears get into the 12.9X's??
Well what do you guys think?
Everyone tells me "NO WAY" but I think it can happen.
I'd like to try and if you guys got any info or done it or seen it done could you please let me know.
Yea in time I'll switch to a moser 12 bolt with better gears but till then I'm stuck hear.
Thanks!
89 IROC 350 Auto
MSD 6AL
Custom DUAL Exhaust
Edelbrock Performer 6085 Aluminum Heads
ZZ9 Cam
TPIS Level 5 Chip
And Free mods.
(stock intake, runners and suspension)
13.879 @ 98.90 mph (with 2.77 gears!)
Moderator of http://www.iroczone.com
Member of JFA Crew
Thanks!
89 IROC 350 Auto
MSD 6AL
Custom DUAL Exhaust
ZZ9 Cam
TPIS Level 5 Chip
And Free mods.
Member of JFA Crew
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You just need lots of HP. When I had my 383 I ran 11.8's with 3.27 gears.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
I've gone 12.18 with 3.27 gears. Just installed 3.73's (still a 9 bolt) and dropped about 350 lbs from the car. Will see how that does in a few weeks.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
Currently installing 3.73's into my 9 bolt (YES,it is a 9 bolt & YES they are 3.73's, not 3.70. 4.11's to follow soon )
www.koolmeister.com
Miles
88 427 Camaro
www.koolmeister.com
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
<font face="Verdana, Arial" size="2">Originally posted by 88 427 Camaro:
Miles
</font>
Miles
</font>
Miles,
Is it OK to get info about your 3.73 in a 9 bolt project??
Daz
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Daz -
don't know if this is what he is using or not, but TPIS just started selling 3.73 gears for the 9 bolt. Check out the new products on their website.
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
TPIS is actually selling 3.70 gears ie 37/10 not 3.73 ie 41/11. The 11 tooth pinion on the 3.73 is stronger than the 10 tooth pinion on the 3.70. I will also have a variety of gears available from 3.2 to 4.1 along with new carriers and some other stuff. If you want to know when parts are available, send me an email and I will put you on the mailing list. Right now, it looks like some of the 4.1 gears and carriers will be ready next week.
Miles
88 427 Camaro
www.koolmeister.com
Miles
88 427 Camaro
www.koolmeister.com
NufNuffZ28
You ask for some info on the exhaust I have so I'll tell you about it. It is a custom exhaust put on by a custom exhaust shop. I have to stay in emmision legal status so I have 2 cats and 2 mufflers one on each side or pipe. The pipes are 21/4" each and they follow the standard layout of the regular exhaust. My 2 cats are cheapo's from J.C.Whitney and fit under the same spot the regular cat would fit. I just need to put more insulation under the carpet on the passenger side since the wife says the floor get too warm in the summer time, hehe. Then both pipes run next to the driveshaft to the rear axle and over it. Then I have one pipe on each side of the gas tank. The mufflers are small cylinder types right before the bumper and next to the gas tank sides, not too close you know.
I've calculated it out that the 21/4" pipes flow just a little more than a 3" cat back system so I'm good to 350 -375 HP.
The sound is totally different from a cat back system and is a very deep rich sound, I think it can be compared to and Big Block sound, but that is me and I think the cam helps too. When I go WOT it is nothing less than LOUD so I don't do it too often and never around cops. The cat back systems gives and equal sound out of each tip but with mine and the cam it is lopey and you get the alternating sound coming from each pipe.
Some people say that with all the bends I'd have flow problems but no, plus all bends are manderal(spelling) bends. It takes a little while for the O2 sensor to get hot enough to put the car in close loop in summer time and really long in winter time, I can see the rpms change back and forth as it goes into close and open loop. But it does go into closed loop and stay there!
Also idling through parking lots I have been know to set of a few alarms and chrips from cars.
If I can get a digital camera I'll try to put the car up and take some pictures else I'll have to use my 35mm and send the pictures in a week or two. Ok?
Anything else you need let me know.
Please send me your email address cause the one you have listed didn't work.
Mike Ski
89 IROC 350 Auto
MSD 6AL
Custom DUAL Exhaust
ZZ9 Cam
TPIS Level 5 Chip
And Free mods.
Member of JFA Crew
Mike Ski
89 IROC 350 Auto
MSD 6AL
Custom DUAL Exhaust
ZZ9 Cam
TPIS Level 5 Chip
And Free mods.
Member of JFA Crew
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
im hitting 13.8s on 2.77's i imagine with heads, cam, and a bigger TPI or superram style intake it could be done.
88blkiroc, what mods do you have?
89 IROC 350 Auto
MSD 6AL
Custom DUAL Exhaust
ZZ9 Cam
TPIS Level 5 Chip
And Free mods.
Member of JFA Crew
89 IROC 350 Auto
MSD 6AL
Custom DUAL Exhaust
ZZ9 Cam
TPIS Level 5 Chip
And Free mods.
Member of JFA Crew
I'm hitting 14.0 at 98.93 with a 2.16 60ft with 2.77 gears in an '89 IROC 350 AUTO. All I have is headers, catback, no cat, coil, k&n's, ARAP chip, AFPR, and ported plenum. Stock intake, heads, cam, runners and suspension. I definately feel she had a 13.9 run in her......... I just got to work on those 60ft times with my street tires.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
<font face="Verdana, Arial" size="2">Originally posted by Stephen 87 IROC:
You just need lots of HP.</font>
Yep, all it takes is power.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Location: Coulterville, IL...Currently on Beale AFB, CA
If you have a machine shop make you a 1/4 inch ring gear spacer, you can run the 3.70 gear ratio for the "3 series carrier" in a "2 series carrier". If you have any questions, let me know.
-Brit
Black 89 IROC...355, Solid Crower Cam, TFS heads.
12.0 @ 120.3mph with a 1.9 60ft...all motor
-Brit
13.4 e.t is my best with a 2:77 ratio and that run was with a 2.24 60' time , 104 degrees out, on drag radials, stock lower control arms and torque arm. I think that with better suspension, a set of slicks and good weather, I would have reached the 12 second goal. I have since swapped in a set of 3:70 gears, so I will never know what the 2:77 could have done...
1991 Camaro RS/Z28,polished TPI, 355ci. Sportsman 11 heads, LT-4 Hot cam,Pete Jackson gear drive, on,and on, and on... 13.4 @ 105.98 with a 2:77 rear, no traction, no tuning, no practice. Car is pictured in Chevy High Performance magazine, June 2000 issue.
http://www.geocities.com/jasonsz28us/INDEX.htm
1997 GMC Yukon, 4 wheel drive, leather, loaded, Gibson exhaust, K&N intake, Boston pro series speakers..... That's it so far.
1969 Camaro,12 point cage, total project right now, I am planning an LS1 - T56 - and a Vette independent rear. Pro Touring crowd, look out! 8^)
hectre13
12-11-2023 08:14 AM
1992 Trans Am
08-08-2015 08:16 PM
