Airbag!!
Car: 1987 Z28 Convertible
Transmission: 5-speed
Airbag!!
I don't mean the type on your steering wheel, but the type inside the right rear coil spring. Anyone use one? If so, what kind of pressure seems to work at the track as well in daily usage?
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
Former Paxton (6-psig): 12.57 @ 111 mph.
Former Paxton (6-psig) & former 50-hp nitrous: 12.04 @ 114 mph.
ATI D1SC (5-psig):
12.26 @ 113.55 mph
ATI D1SC (10-psig): Projecting high 11's.
Future ATI D1SC (15-psig): Gotta catch them pesky 26-psig boosted TTA's!!
http://willie.camaro-firebird.org/
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
Willie
ATI D1SC (5-psig):
12.26 @ 113.55 mph
I can partially answer your question. I run one, and I usually run 15# in it. But I rarely drive the car, and when I do, its just to a car show or to a cruise-in, so I just creep around it. With the spool in the rear and the 4" skinnys on front, any handling is non-existent on car anyway. But it does improve my launch greatly. I blew the line off of mine one night and lost the clamp, and to get the car to even hook, I had to drop my air pressure 4#, and the 60' still suffered from what it was running previously.
82 Z28 383, Ported 215cc Dart Iron Eagle Heads 72 cc Comb. Chambers, Comp custom grind Hyd roller cam, Speed Pro .250" domes, Wheeler Motorsports 4340 I beam rods, Eagle 5140 steel crank, Weiand Team G intake, Holley 830 DP, hedman headers
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET:11.63 @ 113.25, w/ a 7.39 1/8 @ 93.04, and a 1.626 60'
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
New Best ET: 14.91 @92.9
Bassett Racing
Bassett Racing
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I've got an Airlift 1000 kit, I'm using one bag and my dad has the other, both in the right rear. I deflate it for street use, but at the track its up to 30-40 PSI.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
Eric-86sc
02-25-2016 09:02 PM
