EFI car, 1/4 times get slower as car gets warmer, what to do about dial-in??
I am considering trying to do some real racing instead of just T-N-T all the time (low roller, 35 bucks to enter)
The problem I have is that my car is a fuel-injected automatic, and it gets consistantly slower the warmer it gets. I can reduce the temperature increase with fan switches, trans cooler, etc. but it will still be there.
I usually ice the intake between runs to cool the car off and also let the trans sit and cool down. The problem is as bracket elims go on, the time between runs gets shorter and shorter, so my car gets slower!
Should I set a higher dial in and try to let off on my cool runs to slow down, or should I try and keep the car warm all night?
-=1987 Formula 350=-
Member Greater Cincinnati F-Body Association
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
you should get a good tranny cooler mounted where the fan can help cool it between runs. you may also want to look into an electric water pump. wire to come on when the key is in the run position(just to a switched power)and put a second switch on the fan so you can turn it on manually when sitting in the lanes. with the water circulating it will cool the engine off much faster.
getting the tranny to cool down all the way between rounds is something i haven't figured out yet. the best advice i can give on that is to find the biggest cooler and largest diameter lines you can find. the more fluid volume is has the more temp it can drop just sitting.
hope this helps
lata
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
hope this helps
lata
tim
14.209@95.46mph
Best 60' 1.917
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
That's the nice thing about bracket racing. It's not heads up and you can dial in whatever you think the car is going to run. If the car starts to slow down then you change your dial in to how slow it's going to be. If you make it into the final few rounds, they don't give you a lot of time for cool downs so you'll have to know how fast you run when the car is hot as well.
All everyone sees on TV is the top classes of drag racing and people don't realize how hard a bracket race really is. All they see is heads up racing and whoever gets to the end first wins. If you notice that classes like top fuel, funny car and prostock all run very close to the same ET in each class. These cars are so setup identically in each class that it's only the body style that sets them apart.
At least in a bracket race, your 14 second Camaro may go against a 16 second pickup or a 18 second Firefly. Each has an equal chance of winning since speed means nothing.
Dial-in slower as you need to.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
[This message has been edited by Stephen 87 IROC (edited June 17, 2001).]
Best 60 foot: 1.546
theshackle
03-05-2017 06:37 PM
beachrodder
08-25-2015 08:05 AM
