is my car supposed to b this slow?
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
alright i got the "good" eingine i guess....but when i went to the strip my best time was a 15.997@86.04mph
do any of you other people have the L69's STOCK or near stock?....i wanna know what you guys are runnin....and how you made them faster....thanks!
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
best E.T. (dont laugh) 15.997 @86.04mph
http://www.geocities.com/K_towngangsta
Car: 87Z
Engine: ?
Transmission: A4
Thats close, my stock tpi ran 15.4 at 88mph. Not any more though.
87 Z28 305 TPI, Auto, LT-1 cam (@.50 418/430, 194/199, LSA 111), roller timing set, 2.73, Gutted air boxes, K & N fillters, Dyno Max 3" cat back, 8.8 mm spirals, air foil, BFG Drag radials,170* Stat and TB bypass.
Old Best 15.414 @ 87.47.
new best 15.006 @ 89.55.
w/ drag radails 14.6 @ 93
“Fallen But Not Forgotten”
Car: 84 Z28 Camaro
Engine: 350ci
No, they are not supposed to be that slow.
The first thing I would do is work on the
carbs secondaries. Read Damons and Eds tech articles on how to do it......
Tom K.
84 Z-28 M5 305 L69 HO
pulleys,coil,3:73(stock)
Jet chip, fan switch,
Al dshaft,1.6 rockers,
LCAs and brackets,BFG DRs
14.20 @ 96.74 2.02 60ft
Tom K.
Car: 1984 Trans Am
Engine: Vortec 355
hey 84305HO
what board are those articles on? this one or the carb one??
Don't feel bad.. I only ran a 16.1 with my 85 L69 5 speed with 3:73 posi. only mods are K&N, gutted cat, and hooker catback exhaust. I only got to make 2 passes though and my clutch linkage broke. I couldn't get traction and my shift points were wrong... I think I should be able to get high 14's out of it once I get the hang of it.
I had a 84 Camaro Sport Coupe that had an L69 that the previous owner put in. It had an open 3.08 rear and an Auto. The best I could get out of it was a 16.07 in the 1/4. Sounds like your times are about right.
Car: 1984 Trans Am
Engine: Vortec 355
well mine has 3.73 gears
so wouldnt mine b faster than that?
Car: 4
Engine: 6
Transmission: 5
The L69 Z28s ran low 15s off the showroom floor. The T/As are slower because they don't have the dual snorkel intake and they weigh more. Still, you should be able to get it to do about 15.5 just by repairing whatever is wrong with it.
Start with a tune-up including finding the optimum timing; rebuild the carb; make sure the cat or the rest of the exhaust isn't plugged up.
As far as mods, a set of headers such as TES or SLP would be the first thing, closely followed by a cam. I'd recommend a Comp XE262 with 1416 1.6 roller-tip rockers, and new valve springs. If you pop the heads off and do a simple bowl job on them at the same time as those other 2 things, you should pick up a good 65 HP.
ICON Motorsports
[This message has been edited by RB83L69 (edited June 13, 2001).]
ICON Motorsports
There are so many variables here that could be affecting your et. I would start by looking at your 60' times as they will reveal how much tire spin and how your launches are. How hot was the tempurature outside when you raced? This is a big factor and can account for 2/10's of a second, give or take. Which would bring you down to 15.7, which is to date my best time with my '87, stock IROC-Z with a 305 auto TPI. I have the new Catco high flow cat with the Flowmaster System, K & N filters. If you are using a Hypertech chip, take it out and run your car and I think you will see a 2-3/10's of a second improvement. Unless you have ram air, the chip could be hurting your times. It did with mine, I have the slips to prove it. I have been told the same thing by the veterans at the track. All the other "stock" cars similiar to what you and I have run in the mid to high 15's. On a hot night expect even to get 16.0. Don't worry about it, your times are right within where they should be for stock or near stock. Do you have an auto or manual. A manual is good for a little better et's as well.
novaderrik
08-10-2015 12:44 PM
