new best 1/4 times with tpi
i jus went to track last night i ran a few 13.0@107.68 and my best was
reaction .793
60ft 1.820
1/8 8.257
1/4 12.824
1/4 mph 110.01
im pretty damn happy i had car dynoed 2 weeks ago and only got 263 hp at rw so i never thought id hit 12's i didnt hit the nos because i didnt have a trailer in case i broke something next time i trailer and spay 150 arf heads dropped me 7 tenths i ran a best of 13.5 @104.66 last year so whatcha think for a tpi?
1992 camaro RS w/ 350tpi
195cc AFR heads with compition port work milled to 58cc
1 3/4 hooker long tube headers
4" mufflex system
custom ED Wright chip
eddelbroc intake base and runners and much more
new best ET 13.5 @104.66 on stock heads
no times with new afr heads hoping for 12's on motor
http://www.nav.to/badass355tpi
reaction .793
60ft 1.820
1/8 8.257
1/4 12.824
1/4 mph 110.01
4" mufflex system
Car: 87 trans am GTA
Engine: tesla permanent magnet
Transmission: 93 T-56
Axle/Gears: moser 12bolt w/ 3.73
you asked me about the super-ram the other day i forgot to mention , that i had to go back to a 48mm stock TB since i sold my whole intake sys(to an *******!!)
what size cam do you have? are you happy with your AFR heads?
how does that 4" exh. work with your car. no body around here has that and i've never seen one on a car.
87GTA super-ramed 355, A4 ran high 12's with old school setup and radials, hoping for low 12's or better /91 TA daily driver LB9 A4 2.73,
good numbers!!!!
looks like there is a littel left though. withthe power numbers you seem to have you should be able to cut like 1.75ish 60ft's. if you can get that down you will prolly run mid 12.6's or maybe a high 12.5 with the same mph.
keep up the good work.
lata
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
lata
tim
14.209@95.46mph
Best 60' 1.917
Car: 84 Z28 Camaro
Engine: 350ci
Very nice ! What type of tires do you use at
the track?
Tom K.
84 Z-28 M5 305 L69 HO
pulleys,coil,3:73(stock)
Jet chip, fan switch,
Al dshaft,1.6 rockers,
LCAs and brackets,BFG DRs
14.20 @ 96.74 2.02 60ft
the track?
Tom K.
AFR heads definitely pull there weight, my friend went from 8.40's to 7.70's with a set of AFR' and advancing his cam (he had a '79 carb'd Z28)
updated sig.
87GTA ,10.5:1,4-bolt 355,afr 190's, super ram ,stock poerted base,58mmTB,24 lb FMS inj. ed wright chip, .510/230 (nr) 1&5/8 hooker shorty's, flow master single 3", 2800 ameri-torque non lk-up, 3.73. best to date with stk 48mm tb and lack of traction in 1st gear netted me a 12.9 @110mph /91 TA daily driver LB9 A4 2.73,
updated sig.
Iroc8t8
08-26-2015 08:14 AM
NBrehm
08-25-2015 11:49 PM
Sanjay
08-12-2015 03:41 PM
