Advice, going to track for 1st time but don't know where to put this stuff.
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
Okay, i'm going to Gateway in St. Louis this summer for the 1st time.. Their requirement's say i need a helmet, and a fire extinquisher(sp?) mount within drivers reach somewhere in the car. Where does everyone put their fire safety devices? heh, i don't exactly want to drill holes, but i also wanna be able to drag race. Any ideas?
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
-Gutted Air Boxes
89 IROC-Z 350 TPI
-Flowmaster Catback
-K&N Airfilters
-Ported Plenum
-Gutted cat
-!AIR
-Gutted Air Boxes
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Must be a track policy.
NHRA rules do not require a fire extinguisher in an ET bracket car. They are permitted and must be securely mounted if you intend to use one but under NHRA rules they do not force you to have one.
1) If you had a fire, I doubt you would be able to put it out with a small extinguisher or know how to put it out.
2) Track safety crew are better suited for fires since they carry much more equipment to deal with it.
Mount it on the tranny tunnel on the passenger side (under or in front of the park brake).
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.69
Best MPH on a time slip: 121.52 altitude corrected to 127.76
Altitude corrected rear wheel HP based on power to weight ratio: 504.5
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
Car: 1989 IROC-Z
Engine: 383
89 IROC-Z 350 TPI
-Flowmaster Catback
-K&N Airfilters
-Ported Plenum
-Gutted cat
-!AIR
-Gutted Air Boxes
89 IROC-Z 350 TPI
-Flowmaster Catback
-K&N Airfilters
-Ported Plenum
-Gutted cat
-!AIR
-Gutted Air Boxes
