NHRA/IHRA helmet requirements
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
What is the minimum rating requirement for a helmet (NHRA and IHRA)?I also could use a list of ratings best to worse(even motorcycle helmets).
edit:I just read the archives that Snell85 is minimum for NHRA(phased out next year)but what about IHRA?
Daz
looking to buy a Snell95 rated helmet
87 IROC L98 t-top
[This message has been edited by Daz (edited March 24, 2001).]
Daz
87 IROC L98 t-top
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
NHRA minimum rating is still Snell 85 and yes it is phased out next year. You should be able to buy Snell2000 helmets now.
M rated helmets M95 etc are tested on flat surfaces such as concrete and have a nylon lining.
SA rated helmets SA95 etc are tested on round surfaces such as roll bars and have a cotten lining.
Other than that, the brand you chose is up to you. As long as there is a snell rating inside the helmet it will pass a tech inspection. A $80 M95 helmet will do the same job as a $400 SA95 and since you don't require an SA rated helmet you can save some money.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.662
ZZ3Astro
08-13-2019 12:57 AM
