0-60
I have a road test for a 1988 Trans AM GTA 350TPI.
0-60 7.4 seconds
1/4mile 15.9 seconds@90mph
225hp/4200rpms
330/3200 torque
braking 60-0=141ft
lateral acc-.87g
Just for note, I had a friend that was getting similar specs with his 88 GTA.
They also test an 88 IROC 350 that did 0-60 in 7.0 and the 1/4 at 15.5@91.7mph
Both tests were from a Motor Trend
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL,MSD boost-master,Holley 9mm wires,Ac delco R43ts plugs,custom chip,Ford SVO 24# injectors,Bosch O2sensor, Bosch in-line pump(w/stock pump), SLP 1 5/8" headers,SLP catback,short shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
0-60 7.4 seconds
225hp/4200rpms
330/3200 torque
braking 60-0=141ft
lateral acc-.87g
91 Formula
305 TPI 5speed
1LE/G92/WS6
They can't drive. Stock 1/4 mile time and trap speed for an 88 350 TPI car is high 14s@90-93MPH.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
Built on Wednesday
91 Trans Am WS6
Bright White
5.0 TPI auto
Trans Go shiftkit
Built on Wednesday
if MrJ hadnt said anything, I would have. Cuz there aint no freakin way a 350, even stock, will be pullin 15.9s in the 1/4. If thats the case, then I would be blowin the doors off 'em left and right. and 0-60 is somewhere around 6.5, cuz with my mods thats where I'm around.
88 GTA L98 auto 3.27 0-60 6.3 1/4mile 14.6@95
Those times the Forula quoted from MoterTrend were in the desert,with 100+heat.
1990 Trans Am GTA
Black/Black leather
350 auto 3.23 dual cats
SLP package
SLP torque converter
SLP shift kit
Fastchip PROM
245/50/16 GSC's
G-Tech
0-60 5.1 1/4mile 13.6@104
[This message has been edited by black5.7GTA (edited February 28, 2001).]
1990 Trans Am GTA
Black/Black leather
SLP package
SLP shift kit
Fastchip PROM
245/50/16 GSC's
G-Tech
i have run a best 0-60 time of 5.9 with my car, listed in my sig.
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,k&n oil filter,synthetic oil 10w30
theformula
Aftermarket Product Review
11-15-2000 10:23 PM
