Vortec TPI Results
1 Post
Car: 1989 Iroc Z L98
Vortec TPI Results
I have been searching for Vortec TPI 1/4 mile results and haven't found many. Anyone here have #'s from an L98 with vortec heads and TPI?
Re: Vortec TPI Results
years ago with vortech heads , scoggin dickey base , modified runners , a small cam , stocker gears and converter i went 13.50's on bridgestone tires
@ 102 mph i think 150,000 plus miles on engine
I would only expect maybe 2-3 tenths gain just doing a head and intake base swap. To get full advantage from it you would need a tune. Mostly to tweak the fueling and timing. However it wouldn't require one to run. Especially if you have a AFPR and a wideband or the abilty to read the o2 @ WOT.
-Jim
I probably could have gotten there with more tuning, and gears. The car felt like it had more in it, but I came into some extra cash and went for the AFR's. Next purchase will be a rear. With the 28's and 3.27 I was going through the traps @ 5300 in third.
It's not just tuning, the car went through the traps @5300 in third. It still has the 3.27 rear and I run 28" tall tires, it needs more gear. The car also has a HSR, not tpi on top.
-Jim
-Jim
60' was only 1.8 too, never could get any better. Once I make my mind up on what transmission is going to go into the car it will get a better converter.
84z96L31vortec
08-20-2017 12:16 AM
Fast355
12-02-2016 06:33 PM
Sanjay
08-12-2015 03:41 PM
