Will 28 x 12.5 x 15 ET Street fit under an 86 Camaro?
I found a pair of E.T. Streets for sale and I was wondering if they're too big to fit under the car? If they do what back spacing do the rims need?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I have 5.5 backspace 10 inch rims. 28x9 ET Drag fit with lots of room. The ET Street tires are measured at the sidewall not the tread so your the total tire width is 12.5 while my 9" wide slick may be close to 11" wide at the sidewalls. 28x12.5 "should" fit but if they don't then a little massaging of the inner fender with a hammer will make them fit.
If I go to a 30" tire, I think the widest I can go without rubbing is 10 or 11". That would totally fill the wheel wells.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.662
<font face="Verdana, Arial" size="2">Originally posted by Z-BOSS:
I found a pair of E.T. Streets for sale and I was wondering if they're too big to fit under the car? If they do what back spacing do the rims need?</font>
Not that I doubt ya Stephen I would just like to hear a 2nd opion....
Got to get ready for Memphis in a couple of months.
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
I also run the 28x9 ET Drags (not sure of the back spacing off hand) and there is plenty of room. Like Stephen said, the ET streets are measured differntly than the ET drags.
Will they fit? You will need the right backspacing on the wheels, but it will still be close I think.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
www.koolmeister.com
Just fixing a bad typo so it would make more sense - Stephen
[This message has been edited by Stephen 87 IROC (edited February 14, 2001).]
Miles
88 427 Camaro
www.koolmeister.com
what kind of power are you making and what gears are you running?
that is a big damn tire, yes it will fit rather well actually. it's just that if you are stepping up from a normal street tire, usually between 25.5 and 26 inches tall to a 28inch tall tire will kill your gear advantage.
lata
tim
91 Camaro RS-LO3,Auto.
14.215@94.30 w/ 1.917 60'
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
lata
tim
Car: 87 IROC L98
When I was running 26" tires, I was using 3.27 gears. My powerband required about a 3.90 gear which just wasn't an option. When I switched to 28" tires, I also went to 4.10 gears. When I eventually go to 30" tires, I'll be using 4.56 gears. Each gear/tire combination works out the same in the 1/4 mile.
The difference in choices are that the lower gear has more torque multiplication to get the car moving and the taller tire gives a bigger contact patch on the ground when compared to a similar width smaller diameter tire. That's why you see very tall tires on Stock Eliminator cars. They're only allowed a 9" slick so the taller the tire is, the more rubber is on the ground. Then it's just a matter of determining the gear ratio required for your power band.
<font face="Verdana, Arial" size="2">Originally posted by NJ SPEEDER:
lata
tim
</font>
lata
tim
</font>
406 TPI with 342 gears
1992 Trans Am
Exterior Parts for Sale
04-04-2016 12:50 PM
Vintageracer
08-11-2015 08:13 PM
