Where to get extended wheel studs?
Anyone run extend wheel studs?
I just picked up a set of weld prostar wheels and tires and need longer wheel studs.
Whats the best place to find these?
What studs do you run with these wheels?
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
Re: Where to get extended wheel studs?
Rules state that the lug nut needs to thread onto the stud at least the diameter of the stud no added strength is added with more length. If the studs are shorter make sure you buy open face lug nuts so the tech inspector can see in them to see they are threaded on the requirement. In your case 12mm but the welds do have a thick center section that may require the longer studs to do this.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Don't forget the shank nuts with washers also.
Do you need to pull the rear axles to install 3.5'' studs?
I have 10 1/2 20 shank nuts with washers and 10 7/16 shank nuts with washer
Can I run stock studs with 1.380 inch long shank bolts?
Is there any problem to this?
Ah yea I know problem is
I have stock studs on the car
I have a box of shank nuts which are standard 7/16
I was going to swap studs to use those but I am thinking I dont need to do that now.
Its only like 60 bucks for new shank nuts and the studs are fine on the car.
stock studs are not long enough to pass tech or be safe with pro stars on the vehicle. 7/16 studs are small, I wouldn't run under 12mm or 1/2", but the knurl size of the stud may be different than the rotor opening if you don't run the 12mm ARP ones that are made for the opening
Car: 82 FIREBIRD
Engine: 355 CHEVY
Transmission: TURBO 350
Axle/Gears: 9" FORD, 4:11 GEARS WITH A SPOOL
Jegs... 12MM... make sure you get the longest ones they have....
New2Chevy
09-28-2015 12:35 AM
