what to expect from new engine?
I am building up a new 305 engine for my 86 camaro with tpi now it runs the best of a 15 flat the new engine is going to have 350 lb9 heads, federal mogul forged pistons, comp. camshaft 211 intake and 221 exhaust, 10:1 compression, and i will add on a bigger throttle body prob. a 52 mm. what can i expect to get out of the 1/4 i also have a 150 shot of nitrous but what will i prob. run without the nitrous i think the rear gears are 3.08
thanks
thanks
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
350LB9 heads huh......no such thing. you must mean L98s or vette heads. thats a pretty big cam for a 305 with 3.08 gears. probably mid 12's on the nitrous and around a low 14 on the motor, its hard to say
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 280 grind. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter
13.24@104
13.24@104
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I really don't know why everyone wants to make a small bore 305 engine into a race engine. It's easier to build up a 350 than a 305.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block buildup now in progress for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car
91 454SS daily driver
95 Homebuilt Harley
Best 60 foot: 1.662
87 IROC bracket car
95 Homebuilt Harley
my bad it was l98 heads the came off an corvette dont know which model because the were given to me, and im almost 100% sure im getting 373 gears for christmas and a new trans.
