Forged factory crank vs aftermarket
#51
Car: 84 Transm
Engine: 350 sbc
Transmission: t400
Axle/Gears: ford 9", 3.90
Re: Forged factory crank vs aftermarket
First of all, I would never consider a stock cast crank. GM's forged crank is not a bad piece. Before aftermarket cranks were readily available stock forged cranks were totaly acceptable and they got the job done.
look, alot of how any crank lasts depends on the setup and how much abuse it will see. I would never consider any stock crank for a heavy nitrous motor. Its the instant hit that snaps cranks. But for an NA motor they will handle pretty much what a stock block will handle. A transbrake shouldnt have much affect as the motor is already preloaded when its released. As we all know, good rods and a good balance job is critical.
E85 is irelevent. If I left my motor completly the same and switched from E85 back to race gas, with a proper tune the motor would see similar abuse with either fuel.
And Gary, I dont know what you do and dont know. And not to slam you, but if you want anybody to take you serious having an avatar of a minivan is not going to cut it.
#52
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
this.
#53
TB2.Point well taken.All I'll say is like always,you can't judge a book by it's cover.LOL
There a dozens of members here that at first I didn't think they knew much.But since been around for awhile I found how wrong I was and gained my respect.
#56
Car: 84 Transm
Engine: 350 sbc
Transmission: t400
Diggler, if you can get away with it. More power to you. I know other guys doing the same thing. My buddy ran a 3rd gen camaro 400 sbc with a cast crank and nitrous in the low 10's and his never failed. If you can do it, it allows you to put that money in other places to go faster. But that would put me out of my comfort zone for sure. My concern is not for the crank, thats cheap, but if it does fail the other expensive components that it takes with it.
#58
Car: 1982 Camaro
Engine: 555 BBC
I had no issues with a stock cast piston 400 dart heads with a 300 shot back in 2000. I got a good amount of hits until the rings broke. It was good time but was a known time bomb. I had several cast cranks nitrated that had the sauce added and never boke one. I'd say they were around 600-700 hp with the nos. The cast pistons/rings were another story.
#59
wow i ask if a factory forged crank is going to hold up and this turns into a bitch fest.
im going to kepe the crank, and my speedpro pistons granted they arent srp's or some other high dollar forged slug but they will work.
when i switch to the afrs and vic jr efi ill pull the rods and swap them out for a better piece and swap the 224/224 cam for something a lil larger
my car will see the track 2-4 times a year and one trip to the salt flats a year
the way i look at it the car will make the same power with the afrs vs the stock heads it will just take alot less boost presure to do it.
even though i could crank the boost back up with the afrs and make a ton more power im going to sit this car in the mid 9's and be done with it with either set of heads
#60
#61
ive also been neglecting to update it at times so some parts of the build arent posted there, one of these days ill go back and update it
right now ive been forced to halt the build.
i just opened up a small business and without warning the building i live in was sold which was totally unexpected so im currently looking for a place to move, once i get moved ill get my sponsorship set up here and at ls1tech and get back to working on the car
#62
1 Post
Car: 88 gta
Ok so how about this thread:
http://speedtalk.com/forum/viewtopic.php?f=1&t=21462
I understand the debate here. But if most of our cranks are allegedly nodular iron and not cast, I would think the cranks can take some serious abuse.
Now you can get a forged steel crank for about $200.
I say check your stock crank and rods for cracks, then remove the flashing, shot peen the rods and crank. If you wish, go as far as nitriding and maybe Cryo.
The guys in the above link, are turning stock cast iron 350 cranks in excess of 7k. So you do your thing.
Oh yeah, and most forged cranks, reguardless of material composition, usually respond well and the same as cast or nodular cranks to shot peening and cryoing. Nitriding is dependent on the material composition, the other two are not.
#63
Gawl you guys drive me nuts.You want to go faster,but don't want to buy the equipment to do it. Now you of course have two choices. Either you can invest in treating a pc of junk so the first spun bearing confirms that it is a pc of junk or you can go belly up and buy a(that you need) crank that is salvageable. Oh those two choices are take a oldtime drag racers advise or not.
#64
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Since I swapped to then gen III and IV platform, I do not have to spend money on so many go fast parts. I have seen expensive parts break as well, but stock sbc cranks have lived through quite a bit.
#65
#66
ironic this thread pops up now... i am in process of pulling my "ticking time bomb" out of my car and selling it to a guy who is putting it in his street car. i never had any trouble out of it. still has 60+psi oil pressusre, runs good, and doesnt have any leaks. fired instead of investing a couple grand extra in forged engine parts, i put that money into the chassis/converter. worked great.
#67
Does anyone have any proof of this "cryo" crap working? People with the ability to put liquid nitrogen on things have been charging other people for the privelege of freezing their things for decades.
Ive even seen guitarists pay more for vacuum tubes (component in guitar amplifiers) that have been "cryo-treated" because it makes it "sound better". There's hardly a singly industry out there that doesnt have its own "cryo-treat" scam connected to it somewhere.
I need some cryo-treated cheeseburgers.
#68
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Good question. Snake oil and snake freezing?
#69
actually cyro treating does have some merits in a few aplications, i can recall a few parts in the top alky dragster that were treated and would last an extra 2-4 passes. and for anyone who knows the tad class being able to get 2-4 extra passes out of some parts could mean the savings of alot of money each race season
#70
But to spend money to treat a stock forged crank doesn't make sense when that extra costs could be applied to a much better unit overall in a aftermarket quality crank.No,no,not a Scat or Eagle.
#71
Car: 92 camaro
Engine: 409 sbc
Transmission: TH 350
Axle/Gears: 4.10, mini spool, camaro housing
So I guess I should note that our old blown combo that ran low 5's and the 496 that ran 5.3x's were both GM 2-bolt main blocks, the blown combo was even a GM steel 427 crank.........
Yeah, for sure not the best parts out there but they got the job done just fine w/o issue.
As for the topic, I'd agree with what Diggler originally noted; the GM steel crank is good for about the same level as a stock block should reasonably be pushed to - somewhere around 900hp. I would definitely upgrade the rods though, too cheap of insurance not to.
#72
Car: 92 camaro
Engine: 409 sbc
I have an Eagle 4340 crank and Eagle H-beam rods all balanced in mine. Its held up fine for me at 13.1 with some spray.
#74
the only reason we did is with the tad we were buying the top top of the line strongest parts out there and was still pushing the limits on them,and or breaking them,and it would help them last just a few passes longer.
the money saved from them lasting a few extra passes was much much more then the cost of having the stuff treated
#75
We run a 632 Alky BBC on the bottle.Best time in the 1/8th is 4.56@150.None of the parts are treated.Just the appropriate parts to get the job done.
#76
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Well, comparing to a top fuel engine that runs on the edge of hydro locking, there is surely a benefit.
#77
im talking about sub 500 ci cars that are going 5.2-5.4 in the 1/4, we get certain drive line related parts cryoed and we buy the best parts available
#78
#79
I surely miss the time when guys decided to build a car,(and no we at that time didn't make alot of money),bought the best you could understanding it was just apart of the deal. It was a cornerstone of hot rodding and drag racing. Not the current thing going on putting a assortment of the cheapest pc's of junk they can find.
#80
My advise is for you on the next teardown have the crank mag'ed right behind number 2 main journal and have it measure on all journals for taper from side to side. Those have a history of cracks behind number two and breaking in the same area. The taper allows you to torque the bearing,but they don't make good contact. If you have a machine shop that can measure the cranks index,it is another thing those are not very good.
#81
#82
Trying not to get too far off topic.Thing is those guys going faster without the required investment put all of us at risk when that plan fails ending up with a oil down........
I think I am pretty constant advising people what to buy given their goals. I don't think I am a person who is bench racing in my posts trying to push them into over spending. I do think I am a guy who thinks alot about how the amount of money spent in the long run and the reliability is effected. And with a good aftermarket crank rebuild ability I think has a greater opportunity and no less better overall quality.
#83
Car: projects.......
A GM sbc engine block can handle 900hp? I was assuming 600hp was about the limit. My 2 bolt 400 block im afraid would crack like an egg at even 800hp. I think Dart said the SHP blocks were good for 650hp. Im sure there pretty reserved on that number. I figured I would go with an SHP if I ever wanted to slap a blower on my 400.
In the 400 blocks, the "509" 2-bolt is actually considered the "best" stock block. The 4-bolt blocks are all techincally weaker than the 2-bolts in the 400's because the main caps are too thin where they're machined down for the outside row of bolts; they're known to crack the caps between the bolts.
I've seen several high-mid 5 sec 3000-3200 lb n2o cars running the stock "509" 400 block as well as 350 4-bolt blocks, beyond that they don't tend to live well. - A buddy hurt a couple worked 509 castings when getting into the lower 5's, he's now been 5.0x's and is pushing for high 4's in X275 on a Dart SHP w/o any issues.
As for the BBC's, we've went 4.70's @ 3000lbs on a stock block for several seasons w/o any issues. In fact, that block now has a bracket combo in it and is still running just fine.
#84
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Have been enjoying beating the gen III and IV engines with cam only, I will never go back to the gen I. I replace nothing but the valve train and that does. It include rockers. The sbc was a fun learning experience though and I have fond memories. Call it luck, but several of my junkyard gen III/IV swaps have yet to break. My sbc engines gave me issues here and there.
Wish I could aford a bbc though, always wanted to do a 496.
#85
#86
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Yep, just comes with the times, I would hope a 2000+ engine would work out better than 1970-1995 tech. Although I can tell the vortec sbc and lt1 stuff bridges the gap with the ability to take abuse from the old stuff to the LS. At least my experience.
#87
my experience is there isnt as much of a difference between the 2 gens of engines as everyone makes it out to be. you've got tons and tons of people that really arent that good of a mechanic working on sbc's/LT1s and they just can't keep them together or whatever. they go to a bone stock LS engine and don't mess with it..... and bam they have no more trouble. musta been that crappy old sbc that was causing all the trouble.
#88
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
I mean stock for stock. The capability aside, the pre vortec engines seem to give up more than the powdered metal lower ends. Just my experience. Slapping a cam and nailing 7200 has been a blast, but I have a couple sbc engines I built 3-5 years ago that are still beating the streets and chewin tires, no doubt what the can do!
#89
1 Post
Car: 88 gta
hey, If anything I was just putting out appliable options of what you can do. Isn't that one of the points? I mean if you drop $600 into mangfluxing, shot peening, possibly nitriding and lightening/balancing a stock crank...Generally your still farther ahead.
I understand doing it right, but by who's standard is this? Magazines that are owned by those after market companies?
I figure by dollar amount, forged crank=$400+ forged rods=$200-$1000+ pistons lightweight=$300-$1000+ Rotating assemblies can be had for average of $800.
Out here, Nitriding=$150, Shotpeening=$150, Magnaflux=$75, Lightening=Starts $75 and balancing is $75-$300
All in all its a matter of perception and personal interest.
#90
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
I am just addicted to what we call "grenades", see how far the stock stuff can go.
#91
lol i quess u could call my motor a grenade.
i say i split the block before i break anything else though.unless i get carried away with the tune and get to agressive with my timing or lean it out to much then its going to be a piston/rod
#92
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Well, it is a blast pushing stock parts to the limit. I love the ability of the LS, but for boost, the ol sbc 5 bolt per cylinder hold tons of boost.
#93
1 Post
Car: 88 gta
Yep thats my goal, see what the stock can handle. Besides 305s' are a dime piece and I want to experiment a little at a time. But ya know, it seems so damn hard to get an ls/lt cam for this engine for under a $100. It would be nice but my cam is the stock one for the 305-350 vette. So everything I find is less duration but more lift.
Just gonna see what the stock crank and rods can take.
#94
#95
Car: 84 Transm
Engine: 350 sbc
Transmission: t400
So if a stock 350 4 bolt block is good to 900hp. Is that completly/partially filled with hardblock? How much does it help? And at what hp should this be done at? Ive been considering filling mine up to the freeze plugs before I start spraying.
Or is it the main caps that give up? How much extra will billet caps help?
#96
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
#97
ya 4.8/5.3's are almost impossible to beat for performance on the dollar. if you can get one into the car for cheap, that is the way to go nowadays.
as for the stock block, i know a mid 70's 4 bolt main with arp studs is good to 900 with no fill. plenty of people have done that, and some have gone well beyond that but its a gamble at that point. and the mains will scoot around and do some crazy stuff.
factory forged crankshaft is good to about the same point. they are really good cranks, but not 4340 alloy.
#98
Diggler. I have been looking at the LS's. Seems the consensus the stock iron blocks are ok to F/W HP of 800. Then a aftermarket block is heavily suggested.
Guys you if you like can bookmark my user name. Why??. Well I think this whole thread is at the end of the day about money. I'm the best buddy you can find anywhere. I promise I will never suggest you take that chance to lose everything and at the end of a use of anything you will have something to sell. Been there done that.
#99
Interesting thread... Lots of varying opinions. Everyone knows someone who breaks parts either stock or aftermarket and also know a guy who cant break a stock motor at ridiculous power levels. Just seems to me not everyone is able to make stock or cast parts live when pushed to high power and rpm levels...else youd hear about it often. Not many can do it that way due to many reasons. Machine work quality, tune up, faulty parts etc
Whatever the case build to your budget. Most forged cranks and h beams with good bolts will last longer than the block they are in. A factory 350 block at 900 hp is a touchy subject. It depends on the casting used for the block, the machine work done and how that power is made. Nitrous high rpm motor is gonna stress mains alot harder than lower rpm turbo will. My research led me to a dart block when doin my turbo build. Just too many stories of blocks cracking or caps walking on factory blocks at the power levels i wanted
I know 87_ta says his dart shp block caps are starting to walk alittle and thats a nitrous 7200 rpm motor with splayed 4 bolt caps. That should be stronger block than any factory 350 done 50 yrs ago....or id hope so with todays metallurgy and foundrys.
I get crap for my build all the time from my budget jy lsx friends who are making big power on stock truck motors for thousands less $$ than i have in mine haha but i feel confident in my internals and block to handle everything i could want and to do it for a long time. I was able to afford it and i dont regret it. Just wish i did it right the first time instead of throwin small heads and cam in it first build. I knew id want more and had to rebuild
But if machine work is good and tune is good and safe, and rpms are kept in check, i dont see why a stock crank cant be used for moderate goals. Circle track guys have broke them but they may see 7000-8000 rpm alot and thats more stress than what most drag racers go thru or street strip guys
#100
1 Post
Car: 88 gta
Well most of the time before the stock crank goes the rods will bend or break. One of the discusions I had with a machine shop was me explaining concepts. One is well if shot peening can improve the cranks rigidity from 7-18% then that means it can handle that much more. Flex is what kills the crank, rigidity is resistance to that.
Now this convo was on my 35pd tech iv crank. Which breaks around 5-6k. So I applied the math to him like this now that should be the breaking point.(5350-5900)--(6440-7080). I also added in that if I nitrided in addition, I should be able to hold it at 5500-6k all day.
but most common failure with gm is rod failure.
