How far off from a 12.99 pass should I be
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1984 z28 camaro / 2019 accord sport
My setup
84 camaro z28
Early 80's 350 block bored 40 over stock crank and rods
Speedpro flat top pistons
Protopline iron lighting 180
Comp cam xe274
Comp cams ultra pro mag 1.6 roller rockers
Rpm air gap
Proform 750 double pumper
Proform electric water pump
Headman shorties
Dual exhaust
700r4 transgo shift kit 3000 vigilante stall
Posi 10 bolt with 3.42 gears
Some weight reduction
Bfg g force drag radials 255/50/16
Also other than heads do you see any weak points in my set up
84 camaro z28
Comp cam xe274
Rpm air gap
Headman shorties
Dual exhaust
Re: How far off from a 12.99 pass should I be
Ok cool how much would a set of trick flow or afr 195's help
1 Post
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
What weight are you at? I was going 12.2's with cast dish piston, bone stock bottom end with a set of hand ported 416's a 60103 voodoo, 3.73's and a th400. (2870 race weight)
darwinprice
17
10-11-2015 11:51 PM
