Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Project 10sec lq4 91rs
Old 04-24-2012 | 01:00 AM
  #151
3rdBird's Avatar
Car: 91 Pontiac Firebird
Engine: Killer SBC, w/ RV cam
Transmission: AutoMatic, w/ shift kit
Axle/Gears: Posi-Traction
Re: Project 10sec lq4 91rs
Cool build, you lost me when you put a carb on it. Why run DIS, cam/crank system, then put a carb on it?
Ford/Chevy, I understand, to each his own.
Why play with power valves and jets, when you can just "key stroke" your jetting, timing, fuel trim,RPM,WOT,MAP,ETC
Not hating, love the build
Old 05-03-2012 | 03:14 PM
  #152
91_B4C_RS's Avatar
Car: 1991 B4C Camaro RS
Engine: 370 lsx ls3 heads victor jr w/carb
Transmission: TH400 w/brake coan 8"4500-4800 stal
Axle/Gears: Moser 9" locker w/ 4.11's
Went to the track last night with new drag bar and lowered instant center
The good.
60' improved .040 best was 1.500
The bad
lost almost. 4 tenths in 330'On through 1/4
And 2-3 mph
The worse
Rear end makes very loud noise at decell. Rear diff feels crunchy while turning wheels by hand
Da was 300'to higher than last time I ran 10.97@ 124 yesterday I ran 11.39@121
Old 05-03-2012 | 04:10 PM
  #153
91_B4C_RS's Avatar
I wonder if that rear got tight and was holding me back a lil
Old 05-03-2012 | 07:30 PM
  #154
adamemerson's Avatar
Car: 96 Z28 & 89 RS
Engine: Lt1 & 383 Stroker
Transmission: 4l60e & t5-5speed
Thats a good lookin motor
Old 05-04-2012 | 07:20 AM
  #155
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Sounds like its time for a spool. I'd guess the rearend was holding you back this time as well as the DA.
Old 05-04-2012 | 01:19 PM
  #156
91_B4C_RS's Avatar
Spool fir sure contenplating going to a 4.30 gear.
Old 05-07-2012 | 12:06 PM
  #157
itsjustabird's Avatar
Car: 91 firebird
Engine: sb2.2 headed sbnos
Transmission: tsi glide
Axle/Gears: 4.30
Have you had a chance to pull the rear apart yet?
Old 05-07-2012 | 04:25 PM
  #158
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
i wouldn't do a gear change till you got it running really close to right. then once it's dialed in, gear accordingly
Old 05-07-2012 | 07:14 PM
  #159
91_B4C_RS's Avatar
Not apart yet. Prolly gonna have to wait till after the wedding. I do have a set of 3.89's up in the attic. Hell maybe the gears are ok that I have in it. Never know
Old 05-08-2012 | 01:18 AM
  #160
91_B4C_RS's Avatar
Work a 16 hour shift, cant sleep? what do you do???
passenger side bearing cap. cracked. bearing still looks good surprizingly. the adjustment mechanism is ****ed too.
looks like it spool new bearings reset up the gear.
what do you guys think about this gear pattern?
how much further should i move pinion in?
Old 05-08-2012 | 06:15 AM
  #161
1badeagle's Avatar
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Dude that really blows about the cap. I have a 4.30 gear in my 9" with a detroit locker. Go for the 4.30 if you have a taller tire.
Old 05-08-2012 | 10:04 AM
  #162
91_B4C_RS's Avatar
Can't find a single place the sales the adjustment nuts ir the bearing caps.
Old 05-08-2012 | 11:55 AM
  #163
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
What kind of 3rd member is that? If its a regular stock ford 9" I would spend a little money and step up to a strange s case or similar
Old 05-08-2012 | 01:53 PM
  #164
91_B4C_RS's Avatar
its a factory thirdmember. too cheap to upgrade right now ;(
Old 05-08-2012 | 02:45 PM
  #165
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Don't quote me on this but I don't think you can just get a new bearing cap, I think there machined to whatever center section there in. Might be better to get a junkyard one.
Old 05-08-2012 | 03:16 PM
  #166
91_B4C_RS's Avatar
I check for new replacement ones no luck.
If you can come across some send the link my way
Old 05-09-2012 | 11:19 AM
  #167
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
think you can get a new center for pretty cheap if you don't care about strength rating
Old 05-09-2012 | 01:51 PM
  #168
mw66nova's Avatar
Engine: 7.0L
those yukon thru-bolt carriers looks pretty decent and aren't too pricey
Old 05-09-2012 | 01:57 PM
  #169
91_B4C_RS's Avatar
Im looking around as we speak. What do you guys think about the gear wear pattern?
Old 05-09-2012 | 04:57 PM
  #170
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Any chance the wear pattern is from the cap failure?
Oh, and a Strange housing should be in your future.
Old 05-09-2012 | 05:10 PM
  #171
91_B4C_RS's Avatar
Im pretty sure that pattern is how it has wore in In the past. it does look like it needs to go in a lil but how much? I don't have a away of measuring pinion depth
Old 05-09-2012 | 10:30 PM
  #172
xpndbl3's Avatar
Car: 1984 Z28
around here we have a local guy that for $100-150 will regear a 9" for us. Since it's cheaper than the gear itself I just pay it out lol
Old 05-10-2012 | 08:50 AM
  #173
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Glad I got a chance to catch up on this thread, started following at first, but I hope you have plenty more left in that girl!
Old 05-10-2012 | 01:46 PM
  #174
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
If you can't do the measurements and such yourself, I would have someone do it for you. Otherwise buy the proper equipment to do it correctly.
Old 05-17-2012 | 01:50 PM
  #175
91_B4C_RS's Avatar
wDid some investigation on why the bearing cap broke. some dumbass (91_b4c_rs) used new bolts for the carrier bearing adjuster hold downs. well the bolts were just slightly too long. long enough to dig into the adjusters. good thing was it really REALLY locked down the adjusters to the extreme so they couldnt move lol. bad thing is i pretty much created a jacking bolt putting pressure on the bearing cap. Live and learn.
Anyway.
got the rear back together just have to button up a lil odds and ends. be back on the road/track
new parts
Speedway motors chromolly 31 spline lightweight spool weighs in at 6.0lbs
Another factory 3rd member
new bearings
reused 4.11 gears
Old 05-17-2012 | 01:56 PM
  #176
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
One thing i will always give props for on a 9 inch, the infinite use of the housing no matter what happens to a center section. That is a mean looking spool.
Old 05-17-2012 | 07:29 PM
  #177
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
this isn't always true....sometimes you can see daylight through the back cover after a catastrophic event. it's rare, but i've seen examples lol
Old 05-17-2012 | 08:07 PM
  #178
xpndbl3's Avatar
Car: 1984 Z28
glad you're back on track for not much money tossed out there. I cringe if I were to hurt my thru-bolted moser center....doubt I could afford a new setup for this season.
Old 05-17-2012 | 08:48 PM
  #179
mw66nova's Avatar
Engine: 7.0L
for this season?^^i'd be glad to see you out before the end of 2013 at the rate you're going!
Old 05-17-2012 | 09:45 PM
  #180
xpndbl3's Avatar
Car: 1984 Z28
ya ya ya I may have 2 days off from my new business next week, so there will be solid progress. Of course this week I was supposed to have 3 free days, and I ended up doing 9 days of work in 7, so we'll see how that goes.
Old 05-18-2012 | 02:05 PM
  #181
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
I mean damage is center section only, LOL. That is not always the case.
Old 06-14-2012 | 10:51 AM
  #182
91_B4C_RS's Avatar
New best time and mph then 6.899 1/8 at 99mph. 10.82 @125mph.
Old 06-14-2012 | 05:20 PM
  #183
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
Just read the whole build! Lol great looking car and glad you are getting it squared away.
Old 06-28-2012 | 10:59 AM
  #184
91_B4C_RS's Avatar
Went to tnt at lucas oil raceway last night. Made some suspension changes. Lowered instant center( lca position), set pinion at -4*and adjusted my homemade drag bar. Car leaves level now and seperation/ fenderwell gap is the same at launch as well as ride hieght. Also my front end shimmy after launch is gone
New best 60' 1.49
1/8. 6.809
mph 100.72
1/4. 10.72
Mph 126.24
I have a video of a 10.88 pass i made. Spun a lil i will post soon
Old 06-28-2012 | 12:01 PM
  #185
91_B4C_RS's Avatar
DA 2659 ft
Old 06-28-2012 | 02:14 PM
  #186
mw66nova's Avatar
Engine: 7.0L
wow, awesome news man! you are now faster than me
Old 06-28-2012 | 02:38 PM
  #187
built91Z28's Avatar
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Awesome car and time! I have dreas of my car launching like that one day
Old 06-28-2012 | 08:52 PM
  #188
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Very nice, got me ready to see what the TA will do with the 6.0.
Old 06-28-2012 | 11:48 PM
  #189
91_B4C_RS's Avatar
thanks man its taken quite a bit of time to get it to 60' like that. lots of trial and error. lol
me too man should run hard at the track with a big stall
Old 06-29-2012 | 04:33 PM
  #190
91_B4C_RS's Avatar
http://youtu.be/jmiesbTq3mk
10.81 run spun off line 1.59 60 ft dont have a good vid of my best pass of course lol
Old 06-29-2012 | 05:13 PM
  #191
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
If only i had a trans brake like you
Old 07-11-2012 | 10:49 PM
  #192
91_B4C_RS's Avatar
engine expired today.
took it for a spin after work drove for about 20 min, decided to lay into it from a 20 roll. stabbed the throttle shifted into 2nd at 6800 rpm, then car turned off and sounded like it dieseled a lil. pulled over tried to restart it. all it did was click click. engine wouldnt turn over. no holes in the block no oil on the ground oil looked good.
got a tow home an stared to tear it down. found timing chain wedged under crank gear and pan locking the engine up.
pulled heads they look good besides, found 9 bent valves, pistons were hit, #6 was hit so hard that it was sitting **** eyed in the cylinder. pulled the rest of engine down found...
-rod journal on crank thrashed all bearing look good and even the broken rod shows noheat damage
-2 ****ed up pistons
- 1 pulverised rod in 4 pieces (#6)
- 1 messed up rod from collateral damage.
- big hole in windage tray with a bunch of parts in the pan.
- cosmetic damage on inside of block from parts bouncing.
- 2 cylinders are scored and have bottom of cylinder chucked a lil ( almost looks like a block that has had the cylinders clearamced for a stroker lol)
- cam has 2 lobes that r a lil jacked up. gonna have to trash it. lifters still look great!!!
- jp single roller timing set still looks brand new. found all the pieces from the timing chain i can almost put it back together (see pic)
- bent pushrods
-2 bent rocker arm bolts
Old 07-12-2012 | 12:00 AM
  #193
mw66nova's Avatar
Engine: 7.0L
as said elsewhere, sorry to hear this man...totally sucky...
Old 07-12-2012 | 05:27 AM
  #194
jbenge's Avatar
Sorry to hear you lost your engine. Going to build another similar engine or just install a junk yard 6.0 to hold you over?
Old 07-12-2012 | 10:44 AM
  #195
91_B4C_RS's Avatar
Probably try to put it back the way it was. Or do a stroker.
Old 07-12-2012 | 03:07 PM
  #196
khulsebus's Avatar
Car: '89 Camaro
Transmission: 4L65/70E
Axle/Gears: 9 Inch, 3.70 gears
that sucks big time, sorry to hear about it. time to start dreaming up a new combination i guess.
Old 07-26-2012 | 07:42 PM
  #197
91_B4C_RS's Avatar
instead of having the cylinders repaired on my block, and be afraid it would blow out, i decided to buy another donar engine
2006 silverado lq4 complete engine. runs but low oil pressure. bad cam bearing.
$500.00
some one is picking up the 317 heads for $150.00 saturday
off to the machine shop .030 over and cam bearings.
GOOD NEWS. was able to save the cam from old engine. the lobe damange was a molten piece of metal that bonded to the surface. chiselled it off and hitthe lope with 400 grit, then 1500 gritt . smooth!!!
Old 07-26-2012 | 07:45 PM
  #198
mw66nova's Avatar
Engine: 7.0L
woot man, glad you're rebuilding. going back to a 370 or going to stroke it?
Old 08-12-2012 | 06:11 PM
  #199
91_B4C_RS's Avatar
Mini update.
6.0 block is back from machine shop. Got new cam bearings, bored. 030 over, hot tanked, and a coat of black paint.
- Got my scat 6.100" forged h beam rods with arp rod bolts, 2 racetec pistons, and a ring set, comp double roller chain, 3 pushrods, and. Ordered a set of lightweight ls3 valves this time.
- cleaned crank up and set it in using oem replacement speedpro bearings, ended up with less than . 001" main bearing clearance with plasticguage. TOO TIGHT!!. took bearings bavk to advance auto and ordered a set of 152m1x coated 3/4 groove bearing. +.001" oversized.
Went ahead and opened piston ring gaps up to. 020" top and. 021" 2nd ring. From. 018"/.018" due to an aquired zex parimeter plate.
Old 08-17-2012 | 11:30 AM
  #200
91_B4C_RS's Avatar
Back together
Quick Reply: Project 10sec lq4 91rs
