Data Acquisition
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Data Acquisition
I use an Innovate LM2. There are far better data loggers available that have a lot more inputs but the LM2 logs everything I want to know.
Part of the fun for me is the electrical part of the build. Data Logging has always been something I think can be very valuable. I plan to log, among other things, engine RPM, Driveshaft RPM, two O2 sensors, 8 EGts, manifold pressure, throttle position, trans brake release, shift, oil pressure, crankcase pressure. Maybe trans line psi and someday maybe shock travel.
The Auto Xray device is a OBDII scanner that looks at the same parameters/sensors as the OEM ECM. Not the same as Data logging for a race car, no ECM, no OBD.
check out these guys too, they seems to be reasonably priced. everyone i've talked to said they're happy with the setup and it's very expandable.
http://www.racedatainc.com/
Thanks, I will check them out. I was hoping to get some recommendations.
I have an LM-2 and use it on our S10. But I've have some trouble with logging to a laptop and customer support is rather slow. Also, I was wanting something for a permanent install and a bit more robust than the Innovate stuff. I know the LM_2 can be a permanent install, but not impressed with the hardware.
