My TPI vs. LSX
#151
Re: My TPI vs. LSX
I'm curious what actual drivetrain losses would be on something in the 2000 hp range. I want to say I doubt you'd loose over 500 hp from 2300 to 1800whp.... that just seems like an incredible drop. Its common to see 15-18% on 400-500 hp vehicles but 2300 is a different game. I dont think the same % can be applied... if so that be 1955 whp
All this BBC talk really has me wondering why the Texas mile is dominated by Exotics (who talk down on GM, "mu llet-racers"), Ford GT's, Supras, Vipers and this year LSx seems to have stepped up.
Last edited by Z28FAST1; 03-24-2011 at 04:28 PM. Reason: cute mu llet is prohibited.
#153
Re: My TPI vs. LSX
Originally Posted by Z28FAST1
Yes, slight.... Nice try you compared 2300 flywheel hp @ 38 psi vs. 1800 rear wheel horse power @ 28 psi. On an engine dyno, they would be actually at similar power numbers. hence, the slight advantage....
#154
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
Re: My TPI vs. LSX
I think in some instances we're just getting off the discussion. What I was originally getting from the discussion was the competition between the two generations, and which was favored.
The talk of turbos and superchargers kind of take away which engine can be more powerful. the only way i see the two being compared while boosted is the reliability, or how much the stock block/stock bottom end can take.
#155
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: My TPI vs. LSX
well it's a ways off, but whitedevilTA and me are using the identical TC-76 turbonetics turbo, his will be on a 5.3 LS motor and mine will be on a zz4 short block 350 with stock l98 corvette Aluminum heads and HSR.
we will have only 25~ish cube difference, and both be using stock GM heads and blocks/rotating assemblies. (zz4 is an l98 short block essentially). also we both have 6-speeds so our cars will be VERY similar minus the lsx vs SBC.
It will be an interesting comparison
#156
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Re: My TPI vs. LSX
That said, do you know of the 69 camaro known as Big Red? Top open road race car back in the late 80's-90's beating all the top exotics doing well over 200 mph. I think it hit 222 as a top speed. 540" big block over 800 hp on motor. Someone could do this today i'm sure and nearly triple that power with boost and run 240+
#158
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: My TPI vs. LSX
Man, the first Gen camaro big red shows what americans do, all motor baby! Don't see any imports or exotics getting it done on bare nuts.
#159
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Re: My TPI vs. LSX
#161
Car: 1986 Trans am
Engine: 5.3 LM7
Re: My TPI vs. LSX
I'm sure it's possible with meth injection. We'll see how much power mine makes....if I don't hit my goal, I'm cranking up the boost and possibly adding meth injection too! LOL, it's addicting.
#162
Re: My TPI vs. LSX
standing mile? i can only imagine what some of the turbo bbc drag radial cars would run if they swapped out their trans/gear/brakes/wheels. i bet as they sit they could hit 200 back to a stop in 1/2 mile.
#164
Re: My TPI vs. LSX
Originally Posted by Convoy25
I think in some instances we're just getting off the discussion. What I was originally getting from the discussion was the competition between the two generations, and which was favored. The talk of turbos and superchargers kind of take away which engine can be more powerful....
The RFD SB2.2 Cylinder Heads
http://www.raceflowdevelopment.com/RFD-heads-SB2-2.htm
... and
The ARAO (Old Dominion) 32 Valve Cylinder Heads
http://www.youtube.com/watch?v=vRKTRLD2h8k
#165
Re: My TPI vs. LSX
Originally Posted by mw66nova
polly motorsports is a big cube bbc with twins last i heard....
http://www.youtube.com/watch?v=r9lDlL1BVns
#166
Car: 1986 Trans am
Engine: 5.3 LM7
Re: My TPI vs. LSX
#167
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: My TPI vs. LSX
Will be a blow through, non innercooled. A carb is like cheating since it cools the incoming air with the dense fuel charge, i will probably add a fuel cooler to help it out, but no methanol injection will be used.
#168
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Re: My TPI vs. LSX
Check out the dyno results.
https://www.thirdgen.org/forums/post...91-post17.html
#169
Car: 1986 Trans am
Engine: 5.3 LM7
Re: My TPI vs. LSX
#171
Re: My TPI vs. LSX
#173
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: My TPI vs. LSX
I see where one car was over 400rwhp from 5250rpm to 6650rpm where the dyno pull was stopped. That is a lot of horsepower under the curve. With the shift extension of the Yank SS4000 torque converter that car will not be under 400rwhp going down the track except at the immediate launch. That car might see a 60' in the 1.5's. No, not all cars had the airfilters removed. Also that car is an unlocked A4 on the dyno.
#175
Car: 1986 Trans am
Engine: 5.3 LM7
Re: My TPI vs. LSX
I'm curious to know what they made with the intakes still on which is where they would be for power under normal everyday driving. Did it really gain that much taking them off?
I also noticed you guys were on a dynojet. Were those numbers SAE corrected or no?
Wow shooting high! I'm setting my goal low since 9 times out of 10 if you set it too high it dissapoints you. Learned that from experience....and being dissapointed LOTS of times lol. I want 550 RWHP out of mine and if I can play with the tune and get more then I most definately will!
#177
Re: My TPI vs. LSX
#178
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: My TPI vs. LSX
I was running 100 KPA with or without the the air tube in place.
I only took it off to keep the playing field level. We continued to tune AFR because it was rich at WOT.
Here is a picture of my CAI it has a K&N 3 1/2" filter at the bottom:
#179
Car: 89 Iroc-z
Transmission: TH400
Re: My TPI vs. LSX
I guess that answers the question from years back as to whether the OEM TPI twin filter housing will support 400 hp.
I see that it's "no". That supports the math.
The cold air box 1989GTA has built is what's needed I suppose.
#180
Re: My TPI vs. LSX
I'm only basing my question on the engineering tables from K&N and the theoretical need for air flow vs hp. The math says there's not enough filter area in the twin TPI air box to support that much hp without the filter itself posing a restriction. That's not to say that you can't make that power with it, it's obviously been done (witness your car and the guys in SoCal). Put the smallest filter on a 900 hp drag race engine and it'll still surpass the 400hp mark.
It's just easier to do without it.
#181
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: My TPI vs. LSX
So, i am assuming all of these are built engines with heads or what? The one that was over 400 was a 368 cubed engine with AFR heads, i would hope it madeat least 400 RW,LOL. The LS1s dont even use a 4 inch bore and many make the 400 mark with just cam and bolt ons and some dont.
I have no idea what i would dyno on my 6.0, but when i find out i will let you guys know.
#182
Re: My TPI vs. LSX
#183
Re: My TPI vs. LSX
#184
#185
Car: 89 Iroc-z
Transmission: TH400
Re: My TPI vs. LSX
Perhaps with the air box removed, 400whp may have easier to come by.
The math/theory says one thing but not all engines are the same. Not all can make the same hp per cfm so if x cfm is available, there could be a,b, or c hp produced.
#186
Re: My TPI vs. LSX
But there's a reason why we don't run a little 4" x 2" open element air filter. We know bigger is better. I guess it's just to what degree.
#187
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: My TPI vs. LSX
What do you mean? Showing the graph?
#188
Re: My TPI vs. LSX
I've run with and without filters, saw no gains at the track. Changed to 3.5 MAF and 3.5" piping to a AEM dryflow filter and saw nothing once retuned. May have been capable of 10hp more but i never redyno'd it. Cracked the flexplate so never could get back on. I wanted nitrous numbers too.
#189
Car: 89 Iroc-z
Transmission: TH400
Re: My TPI vs. LSX
Well its good that it worked for you. For me I didnt see anything on a mid 11 second car. I even tried 3.5" cai with and without filter. My TPI intake had bottoms cut out and ram air tubing installed to the fog lights to force feed air in. 118mph winds must have had good air velocity through there to make up for the lack of csa
Heck I have 3.5" intakes on my turbo car with same AEM dryflow filters I had on the 3.5" CAI on the 383, and I didnt gain anything from what I could tell when I took the entire intake off the turbo which has a 4" inlet. But man those things really whistle with no filters on.
#190
Car: 1989 GTA
Engine: 369 TPI
Re: My TPI vs. LSX
"I'm only basing my question on the engineering tables from K&N and the theoretical need for air flow vs hp"
That is exactly why I built the air box I did. In my case, why have a monoblade and 3.5" air intake if the air filter is choking it? I have enough surface area with my air filter system to support 1300cfm. I based it on K&N's equations for airflow.
#191
Re: My TPI vs. LSX
i meant i would like to see the graphs overlaid to see how much more torque the tpi car was making lower in the rpm range than your car.
#193
Re: My TPI vs. LSX
All this time you guys have been bashing our efforts on TPI motors, you really have missed the point....they are "Small Block Chevy" engines and all they need to make power is "airflow" which is what we have have been trying to accomplish.
You have the advantage of getting the right parts on your engines from the factory. No one has bothered to produce the right parts for us so, we have had to do it on our own. (except for heads)
Granted, they will never be what modern technology has produced, but it is fun to see what we can get from old school parts.
Imagine what 3rd gens would have been like if GM had done it right.
#195
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: My TPI vs. LSX
no one is bashing sbc motors, just saying why dump thousands into a tpi when there are better higher flowing intakes out there that will retain EFI. I remember probably 10 years ago when I had a tpi motor in my car. After a base, runners, porting this and that I had a ton of money into it, dropped a performer rpm intake and 750 dp holley on there and picked up .3 first pass off the trailer. It only got faster from there, now there are several intake choices if you want to make power for a good price, we didn't have those options back then. No one locally tuned them then, and they certainly don't do it now.
#196
Re: My TPI vs. LSX
my LT1 is setup pretty similar to zone's 6.0. i have a smaller cam than him(nitrous oriented hydro roller, too), vic jr., and ported factory heads. 350 cubes, stock shortblock. made 425rwhp @6700 thru a th400, 9", and 28" slicks on the dyno. with a manual trans and street tires it would have been up near 470ish i would imagine.
#197
Car: 89 Iroc-z
Transmission: TH400
Re: My TPI vs. LSX
That would be interesting to see how it would do with a stick shift. My buddy's 406 with solid roller is up near 480-500whp now. 87 TA on this board, traps 130 on motor alone. Doing those numbers with a hydraulic roller is impressive. Theres a 406 sbc on chevelles.com that made 640hp on engine dyno with a hyd roller. That should make huge dyno numbers in a manual trans.
Your setup doing 425 is among the best i've seen an LT1 of stock cubes dyno. Some of those AI/LE3 packages are around 410-420 but usually stick shifts,not a TH400 with big tires and a 9" How much power do you think 9" and 28" tires eats on the dyno? The th400 eats a lot in itself.
#198
Re: My TPI vs. LSX
Thanks for the flowers
Not necessarily bashing, just believe its easier(for the casual hot rodder) to do it with an LS platform. You guys put extensive money and R&D into the TPI set-ups, I never said I wasn't impressed.
Now if only we had a track with good air, we could really see our cars shine.
#199
Car: 1989 GTA
Engine: 369 TPI
Re: My TPI vs. LSX
"not a TH400 with big tires and a 9" How much power do you think 9" and 28" tires eats on the dyno? The th400 eats a lot in itself"
Yep. That makes it more impressive.
