My TPI vs. LSX
#51
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Re: My TPI vs. LSX
How did you come up with the idea that my car only trap speed at 106mph? My old combo trapped 112.24 with 340whp. I dont know what it's doing now with atleast 43 more whp. You guys just dont know that those same cars runs slower in SoCali because our air is not that clean. Plus we get a lot of cross winds at out track. Anything is possible.
#52
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
No. Speaking only for myself, I'm a street racing hater.
If it was on a track, with real data, with the mods of both cars known, perhaps then.
But, this is the "Organized Drag Racing and Autocross" forum. This thread is a "kill story".
Go find the other guy and both of you go out to California Speedway. Let us know how it comes out.
#53
Engine: LS1/LQ4
After getting back from Topeka, I was sorting things out such as 2-step setting & tire pressure, and the fall air started getting better, so it started picking up to the low-13's consistently up here. Just before the last weekend of racing, I finally got the auxiliary tranny cooler mounted, and the car picked up even more, and finally got consistent (surprise, surprise). The best it ran was a 12.889 @ 106.4 MPH at 7200' DA with a 16 MPH head wind (according to the track data). Using only the new NHRA correction factors of .9405 (ET) & 1.0563 (MPH), that's 12.12 @112 MPH at sea level.
I also haven't done any PCM tuning yet.
This is the same car that I took on a 1000 mile round trip to Nebraska last month to visit family. It averaged 23.2 MPG for the trip.
I hope to get it on a dyno for some tuning before the racing season starts. It'll have a little more cam and stall this time around.
Oh, the NHRA correction factors for 2100' are 0.9830 & 1.0165 for ET and MPH, respectively. Take your data from 2100' and multiply by those numbers to get what you would have run at sea level. To determine what you'd run at 2100' based on your sea level data, divide by those factors.
#54
Re: My TPI vs. LSX
LS parts are still expensive as **** aside from the stock parts.
once you move beyond a cam, your hp/$$ will move back over to about where the sbc is.
i have em both, im not biased.
#55
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: My TPI vs. LSX
"Oh, the NHRA correction factors for 2100' are 0.9830 & 1.0165 for ET and MPH, respectively"
Some do not believe the correction factors. I suggest they take their cars to Littleton Colorado and run them. Last time at the Los Angeles Invasion the DA started out around 3200' and by the afternoon it was up to 3500'. That prevented a 11 second run with my old motor. I hope for better air this time around.
#56
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Re: My TPI vs. LSX
#57
Car: 1986 Trans am
Engine: 5.3 LM7
Re: My TPI vs. LSX
Yea but the beauty of the LSx is that you don't need aftermarket parts. A set of stock ported LS6 heads are plenty for even a decent size cam and thats a pretty potent combo. To me heads like the $2K trick flows and that are just a waste of money since the stockers with some porting flow so damn well.
#58
Re: My TPI vs. LSX
Sounds like a life. You guys def have the better weather than we do on the east coast. I don't mind 4 seasons though. Makes you appreciate summer even more. Are you in CA? I don't know the actual smog laws there but I find it very hard to believe it is that difficult to swap in an LSx motor into another car down there and get it approved....
Either way, I guess anything can happen on the streets
#59
Engine: LS1/LQ4
It is kind of fun watching the flatlanders up here for the first time, tearing their car apart in the pits after their first pass...
#60
Re: My TPI vs. LSX
#61
Re: My TPI vs. LSX
I came up with 106mph because (and I might be mistaken but) I'm pretty sure it trapped 106mph at LA Invasion last year with your current set-up? I know there was only one TPI car trapping over 110mph for a fact. What did you trap/run?
Todays technology with Gm, Dodge and Ford engines with decent bolt ons the cars runs a second faster. Mostly in the low 12's. Cam changes in the same cars will run in the 11's. All the new stuff is getting very very hard to beat with old tech. Aw but its fun trying. Well the best part is that our cars are paid for. So it feel good to beat some of those cars with monthly payments of $550-$800 not including insurance. But to see a TPI car break off a few of these new cars is an eye opener.
#62
Re: My TPI vs. LSX
i will honestly say that about the only reason im running an LT1 in my race car is because of all the snooty LS1 people. it is enjoyable outrunning someone that doesnt think your old technology engine can get out of its own way.
#63
Re: My TPI vs. LSX
LSA engines putting down 550rwhp with a pulley upgrade and tune is the way of the future.
#64
Car: 1986 Trans am
Engine: 5.3 LM7
Re: My TPI vs. LSX
And honestly when I'm done I can't image I'll have much more than $4k in the motor and I def didn't do it on the cheap like it could have been. Try beating a 600HP engine without spray for that price!
#65
#66
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: My TPI vs. LSX
Throw a set of 18* heads on the old school engine and all bets are off.
#67
Re: My TPI vs. LSX
sbc has a better oil pump/oiling system.
#68
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: My TPI vs. LSX
Actually i think they CNC job on the LS heads can be as cheap as 900$ if i read right, pretty sure it was CNC, might have been hand port though, but either way, you get over 300 CFM, but you find used heads that flow that on tech for as low as 600$, then there is the L92/LS3 head that is the budget beast flowing 330 stock for 600 used all the time.
My fav part of the late LT1 and SBC was the good rods they started putting in them.
#69
Car: 84' Corvette, 96' Caprice
Engine: LT1, L99
Transmission: T-56, 4L60e
Axle/Gears: 3.07 POSI, 2.93 Open
Re: My TPI vs. LSX
I completely agree. Way too many "MY LSX can outrun anything!" guys.... I like the idea of being the underdog. Not to mention the LT1 looks cooler IMO. Also SBC heads can be ported for as little as $600-700. Lloyd Elliot does $800 starting i think... $900 for LE1..
#70
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: My TPI vs. LSX
That price is no different than the LS heads. The LT just has too many limitations and aftermarket for them is lacking.
(here we go LTx VS LSx) LOL
I will go old SBC before LTx if that is my option, but i am a carb guy and the LS with a carb looks the coolest, no distributor and no provision for one makes it a really good looking setup. Not to mention i love the coils on valve covers.
#71
Engine: LT1, L99
Re: My TPI vs. LSX
#72
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Re: My TPI vs. LSX
edit
nevermind, thought you said something different about ls motors, but you were talking about lt1's.
LT1's are decent motors...reverse cooling is the main advantage. Guys can get away with abit more compression on street setups than older sbc's it seems
#73
Car: 1986 Trans am
Engine: 5.3 LM7
Re: My TPI vs. LSX
This debate gets old after a while. I think we can all agree that LSx by far has the best technology therefore making it excellent for making power easily. LT1 is a great cheaper alternative that will essentially "bolt in" to our cars with not much having to be changed. They still make power, but do not have as great heads as an LSx. SBC is.....well it's been around since the 40's so I think we can say it's proven the test of time. My brother's heads/cam/carbed 350 in his bird will hang right there with a stock LS1 4th gen and I'm sure with more rear gear he will edge one out no problem.
And I will agree with ZONE......coil packs on the valve covers are pure sex IMO!!! Love the look.
#74
Engine: LT1, L99
Re: My TPI vs. LSX
I hate how ppl constantly say "A heavily modded 350 gen 1 will hang with a stock LS1" Not true. A built right 350 gen 1 will make a stock LS1 it's bitch. I like LS1's but I hate how all LS guys talk down on the gen 1's. That's my main reasoning for staying LT1. Too many cocky LS guys... If were talking all out race motor then yes an LS is top dog but not everyone in the world sports 6-700hp on a DD. Most have a cam, intake, exhaust. All gen sbc's can play with ease at those power levels....
#75
Car: 1986 Trans am
Engine: 5.3 LM7
Re: My TPI vs. LSX
#76
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: My TPI vs. LSX
honestly, it doesn't sound like your brothers is a "built right" gen I. too much cam/head/intake for the compression. add a VS carb and goofy gearing and you've got the recipe for a turd.
oh, and the SBC wasn't widely available till 1955, not the 40's
#77
Car: 1986 Trans am
Engine: 5.3 LM7
Re: My TPI vs. LSX
My brother is ordering a wideband to fine tune it and he has 4.10's to go in as well so were going to get it as close to a 12.0 car again as we can. Gotta yank that cat out too. The best time car has gone how it sits minus the cat is a 12.8 @ 108....so just under a bolt on LS1 car.
The car drives surprisingly well mannered on the street even under 2k RPM's with the vic jr. and big cam. Def not a "thrown together" combo. Only reason for the low compression is because it has a stock ZZ4 short block in it. It's got way more potential but it needs a little massaging to get it there.
#78
Car: 89 Iroc-z
Transmission: TH400
Re: My TPI vs. LSX
My 99 TA has bolt ons. Ran 12.75 at 106.9... 2.73 gear on nittos so only a 1.87 60 foot.
My buddy's afr 190 head L98 with stealth ram, with 280xfi cam and my tune went 12.2's at 111.xx on a 1.70 60... not high compression, no fancy bottom end
My 99 isnt the fastest bolt on LS1, but shows even moddest mods on a mild 350 can hang with bolt on LS1 cars. That combo isnt special Cam only LT1's are in the high 11's on the right car. LS1's are in the 10's. HUGE difference in head flow.
#79
Engine: LS1/LQ4
It is very difficult to try to be logical with a person who has already made up their mind. They really need to justify their decision, so logic simply isn't acceptable.
Years ago, I had a co-worker that decided to buy a new '88 Camry. A year later, there was a water cooler discussion about the quality of domestic vs. import cars. He stated he hadn't had a lick of trouble with his Camry. However, I knew he had it back to the dealer at least 4 times in that first year, which I pointed out to him. His response was that those were minor things that were taken care of under warranty. Well, Consumer Reports would get an "excellent" from him, while the guy who bought the '88 Le Sabre would complain and complain about having to take it back to the dealer just once to get some minor thing fixed. Still, he was convinced he had the superior car in that Camry.
One of the most awesome cars at our track (in my mind) is a '70 Nova, full steel, full interior, no mini-tubs, etc. (does have a 6-point). When he drives it from the pits to the staging lanes, it doesn't sound all that wild. With a Gen I 355, 750 Holley, TH350, it runs 10.9's up here, low 10's at sea level, through the mufflers. No spray. When you look under the hood, about the only things that stand out are the belt timing drive and crank trigger.
But, that car is trailered to the track, in an enclosed trailer. Could I have done what he did to my SBC (Gen 1) Camaro and get similar results? Probably (although the Camaro would weigh more than his Nova). Would I be willing to drive it daily? Probably not. I was prepared to do upgraded Vortec heads, double pumper, more cam, more stall, more gear to get another second off of its previous ETs, but that would have reduced its streetability. As it was, I chose to go LS1, and with a little more stall and gear, with all-factory parts except headers and air inlet, no tuning, it took more than a second off the ZZ4 ETs, and gets as good or better fuel economy.
The issue here isn't which platform is "best". This started with a claim of a "kill" by someone who is a "hater" of one of those platforms. And the claims can't even be substantiated. It is the OP who has an attitude, and several other attitudes have come out of the woodwork in the process.
Build what you want. Frankly, Scarlet, I don't give a damn. I do appreciate useful information when I ask a question. What I don't appreciate is being told that the choice you made is fundamentally better than the choice I'm considering only because my choice is different than yours.
And, quite frankly, the racing I do doesn't depend upon how fast you are (assuming you can meet the ET for the class) or how much money you spent on your car. I've been beat by people with a slower and less expensive car than mine, but I've also beaten a whole bunch of people who are faster than me and have spent a bucket load more money on their car than I have (and I don't have the extra expense of a trailer). To say nothing of beating slower more expensive cars.
If you're happy with your car, enjoy it. If you aren't happy with your car, don't come in here and put down those who have a different platform and are happy with their car.
And I still have no tolerance for street racing. It is illegal, it is dangerous, and it is stupid.
#80
Engine: LT1, L99
Re: My TPI vs. LSX
I agree with you there, but I don't care much for the Gen1, Gen II putdowns by most LSX guys though. That's the only thing that drives me nuts. If you like you LSx say so but you don't have to rag on Gen1's and Gen II's. Not everyone has the thousands of dollars required to do an LSx swap. Lowest I've seen an LS go for around here is 1k and that was just a block with internals....
And no this wasn't aimed at members on here specifically, but if you trash Gen 1's and Gen II's then it's aimed at you... C'Mon guys mustang lovers are worse than us at **** talking, haha. Don't stoop to their level...
#81
Engine: 7.0L
Re: My TPI vs. LSX
No offense, but he didn't build it. He bought it from a freind of ours already built. The engine at one point made 374 RWHP....hardly a turd. It has a cat in right now and way too low gearing for the set up as well as rich winter jets which is why it performs how it does at the moment. Back when the car had a T5 and 10 bolt it went 12.0 @ 114. The kid changed the set up to a viper T56 and a dana 44 rear with 3.55 gearing. With the vipers LOW 1st gear and the 3.55's it'll almost do 60 mph in 1st gear which is terrible.
no harm intended friend.
#84
Re: My TPI vs. LSX
There are bolt-on LS1's deep in the 11's, I doubt there are bolt-on TPI's in the low 12's let alone high 11's?
You can throw money at a Pinto an make it faster than a Vette....but mod for mod the LS1 over LT1 over TPI/Gen 1 SBC.
With junkyard 5.3 and 6.0s going for cheap ($500-600 complete drop-outs), the LSx is dollar/hp the best choice hands down.
The LT1 and TPI market is limited and diminishing, try to tune and LT1 or TPI in So Cal I know of 1 or 2 remaining tuners.
BTW, what kind of numbers does your car put down with the mods in your sig?
#85
Engine: LT1, L99
Re: My TPI vs. LSX
The L98/TPI supporters always compare H/C/I full bolt-ons vs. a LS1 with minor bolt-ons.
Not everyone is putting down the Gen 1 SBC or LT1's but they are just valid recommendations based on experience to fellow 3rd gen owners that are ready to invest $$$ looking for better performance.
#86
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: My TPI vs. LSX
So personal reference on my end is justified.
#87
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: My TPI vs. LSX
Stock 6.0 with stock ls2 heads milled and un ported went 9s all motor pump gas with a carb conversion, never seen any old sbc or otherwise go that fast on pump gas, all motor with stock parts cam only.
#88
Engine: LT1, L99
#89
Car: 89 Iroc-z
Transmission: TH400
Re: My TPI vs. LSX
My factory Bolt on TPI car at 3450 went 12.9's on lean tune. Drop that down to 3000-3100lbs and you'll see mid 12's. Not bad for weak heads/cam. LT1's have dyno'd 330whp with bolt ons in a 6spd. Drop them down 3000lbs and its near 11's. Weight makes a difference. Cant compare gutted LS1 to factory weight LT/TPI stuff.
But yes, mod for mod, to a certain point, LSx is best bang for buck. IF you are talking brand new race build from block up, sbc will likely wipe the floor clean. Theres alot that can be done with SBC since guys have been using them for 40 years...the experimentation has been done. 15-18 deg heads on a sbc can create an interesting mule
#90
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: My TPI vs. LSX
what are you running these days? 3050 raceweight right? So a pretty light combo, also do LT1 motors still have the rpm limit stuck at 6700? 6800? I think I recall my buddy talking about that due to the opti signal.
#91
Car: 89 Iroc-z
Transmission: TH400
Re: My TPI vs. LSX
My buddy just made 767whp on a LS2 cam only with 11 psi of boost on E85. Stock head bolts. 10 to 1 compression. Mustang dyno LSx motors do have potential
#92
Engine: LT1, L99
Re: My TPI vs. LSX
No it's or OEM rotor style. MSD fixed this problem with their cap/rotor kit.
#93
Re: My TPI vs. LSX
No idea, never had it dynoed. But with terrible 3.23 gears, a dead posi unit (one wheel peel), a slightly undersized carb, bald *** tires, and a crap tune (as I can't tune carbs) she ran a 13.5 @106 mph. with a 2.2 60'. It was my first build and I just haven't done anymore to her since I was 18.
I can no longer justify a older sbc build that will make just over 300 fwhp when a 5.3 will do it stock, I can do the swap carbed for about 1500 and that engine will run hard, we just went 8.0 in the 1/8th with a stock long block and stock cam with a 5.3, carbed. Full weight mustang with roll cage, but no Ac, ect.
#94
Engine: LT1, L99
Re: My TPI vs. LSX
Just like every other LSx guy... I'm done with this thread. I forgot the LS1 was touched by the hand of god... Get over it, no LS guys can accept that a LTx of Gen 1 can run with their god motors. LS motors are great but the owners act just like mustang owners... They are blinded and won't see anything under the LS platform...This is what TGO is turning into, go LS or get bashed... I'm unsubscribing to this thread...
#95
Re: My TPI vs. LSX
Diggler argued for the LT1 and backed up his statements with his personal vehicle. You on the other hand came up a little short after making such bold statements.
#96
Car: 1986 Trans am
Engine: 5.3 LM7
Re: My TPI vs. LSX
just wanted to say for the record that what i said in my previous post about it being a turd was worded poorly. i in no way intended offense with my comment, but merely was trying to state that you guys currently have a bit of a mismatch (which you admited when you said you're looking to change some things up to get it to run better).
I admit I have never owned an LTx equipped car but I have owned numerous gen 1 cars and LSx cars. I love the LSx...it is a strong runner and the technology is great. Even my brothers hurting 350 right now surprised a few of my 4th gen LSx buddies when he was on thier quarter panel until 4th gear when they let out. A V8 is a V8. They can and will be built to make serious power. My brothers mild set up when it is tuned in correctly I am sure will easily hand it to all of my buddies bolt on LSx cars.
The problem is that when you build an LSx, since it is the "hot thing" at the moment, there is a plethora of info on what combos work, how to tune, etc. Basically, copy someones build and you will have a strong runner. The problem with the Gen 1 motors is that you have kids that will take a truck 350 with 8.5:1 compression, throw some mismatched heads, cam, and autozone carb on it, and wonder why it made 275 RWHP. There is not the same info on the internet on how to correctly build and tune a gen 1 motor, be it carbed or FI, as there is for the LSx engines. Most people simply have no clue what they're doing with the older engines which is why they have such a bad rap. I can't even begin to count how many kids with the above set up I mentioned go around saying they have a "450 HP engine" and then get stomped by a stock mid 90's mustang or something. Hell the guy my brother bought his car off of picked up around 60 RWHP by swapping from a 600 to a 750 carb on the dyno. Then he gained another 20 or so after having the distributer curve custom set for his specific combo.
#97
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
Re: My TPI vs. LSX
my 00 SS weighs in at 3439. take out the spare tire ~3409
#98
Re: My TPI vs. LSX
the LT1 cars are limited to 7100ish if you choose to stick with the factory pcm/opti. its easy enough to replace with a megasquirt/sbc dizzy/sbc intake, though. dont know why it never caught on with the LT1 guys..... one of the first few things the LS1 guys do is put a $1200 f.a.s.t intake/tb on.
#99
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: My TPI vs. LSX
Here is a stock long block record(LS):
9.98 @ 132-- 346in.--SSPerformance--2900#--HYD--STOCK 241's (Current "Cam Only" Record Holder)
Pretty light but even rocking stock 241s? Damn.
#100
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: My TPI vs. LSX
This one is stock cubed with heads, still light, but these are NA numbers:
9.66 @ 131-- 346ci-- TSP -- 2865#-- Hyd-- PRC 227 Heads
