Drag tq arm?
Car: 86 Camaro
Engine: 468 12:1 CR
Transmission: 400
Axle/Gears: Moser 9in, 4.56
Drag tq arm?
Hey guys i been lookin at and reading about them, but wanted to get your opinions on which one. jegster, burkheart, madman, bmr, spoon... heck i dont know.. I know the jegs, burk, and madman are short one. anyways thanks guys!
mods in a nutshell are, n/a 468bbc, 9in
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
Re: Drag tq arm?
i have a burkhart piece and its really nice, it hasn't been to the track yet though
Re: Drag tq arm?
I have the jegs adjustable piece and really like it. You need to figure out if you want the adjustability of multiple mounting heights for the torque arm in the front to change your instant center, that will limit your decision. Or cut/reweld the jegster mount to offer the same thing for instance.
Car: 1987 IROC
Engine: 350 vortec
Re: Drag tq arm?
another little anecdote:
the make of torque arm doesn't seem to make as much difference as making sure that you have a good set of shocks
Car: 86 Camaro
Engine: 468 12:1 CR
Transmission: 400
Re: Drag tq arm?
you have the one that bolts up to the tunnel??
Car: 86 Camaro
Engine: 468 12:1 CR
Transmission: 400
Re: Drag tq arm?
looks like i am leaning toward the burkhart, as it is the most reasonable priced for the needs
1 Post
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Re: Drag tq arm?
https://www.secureway1.com/alston/in...?productID=216
Alston Race Cars arm, LCARB's and summit 3 ways. On a 28x10.5S it hooks hard.
The shorter torque arm will be harder on the tires IIRC.
Car: 86 Camaro
Engine: 468 12:1 CR
Transmission: 400
Re: Drag tq arm?
Havent talked to Madman yet but his piece is nice. I am thinking hopefully it will run in the low 11's to high 10's. What do you guys think?
Car: 86 Camaro
Engine: 468 12:1 CR
Transmission: 400
Re: Drag tq arm?
The crappy pic of the white one on the trailer is mine, the other is just some random pic from the local of some Fast A$$ 3rd gens....
Sorry for the large pictures.
Car: 86 Camaro
Engine: 468 12:1 CR
Transmission: 400
Re: Drag tq arm?
Re: Drag tq arm?
I'm really surprised at how many fast cars out there have the jegster TA...
Otherwise, I'm not a big fan of the madman or spohn stuff, but there have been plenty of fast cars out there running them (for that matter, it seems like there are fast cars running almost any of them, including all sorts of cobbled and modified versions). The fact is that as long as it's rigid it doesn't seem to really matter what the exact geometry is, the basic design is long enough that even significantly moving the pick up point doesn't change the IC/antisquat.
Re: Drag tq arm?
i really like the looks of the burkhart piece, and the price is nice too. i'm hoping to replace my non adjustable jegster with one. if my arm was adjustable, i'd probably just modify it for IC adjustment.
more pics of your car...i'm a fan of white sport coupes
Car: 1987 IROC
Engine: 350 vortec
Re: Drag tq arm?
the burkhart piece is really nice, and Chuck is a stand up guy. He can even help you set it up on the phone
Re: Drag tq arm?
the front mount of the torque arm is a vertical line on a suspension layout graph. moving the front mount up or down will still put your vertical line in the same place on the car. if you think about it, the only thing a torque arm does is push upwards or downwards on its front mount. if you move that mount up or down 2", it will still be pushing up or down on the same spot on the car. i would say the adjustable front mount is more for getting the arm level with the various ride heights you could have.
Re: Drag tq arm?
Re: Drag tq arm?
ladder bars push the car foward. torque arms do not. they work completely different.
you guys may not believe me, but a few years back madman got on one of these forums and made a post on a thread about setting pinion angle... said to park the car on level ground and check pinion angle. i have to wonder how many people did it like he said.... one of my friends did, and he wound up with around -14 degrees of pinion angle. if you have a pretty low car you might come out ok using madmans (wrong) method. but if you have a stock ride height or slightly higher than stock, you may wind up in the same shape as my friend did.
another friend bought madmans adjustable torque arm when it first came out. there was no slider link in there so it bound up. basically just a ladder bar in the center of the car. which worked at a different arc than the lca's, since they were different lengths.
honestly i wonder if he is just a welder/fabricator that has been around alot of cars and knows what setups people are running and goes off of that info? imo, if you want to learn something, talk to racers who TUNE THEIR OWN STUFF. never trust an overhyped internet hero. i got burned by a nationally known LT1/LS1 tuning internet GOD a couple years ago. turns out, he didnt know all that much.
Re: Drag tq arm?
also, i know im not "fast", but ive been 1.30 so far on 275s in a car that might make 600rwhp on a good day. i think it will hit a 1.28 or so if i can keep the front end down. i do not have a front adjustment on my arm. honestly about all ive really been adjusting on the thing is getting the rearend square in the car and swaybar adjustments. the rest has been with the shocks.
Re: Drag tq arm?
so by that sketch, the IC is the vector perpindicular to the plane of the lca's through the torque arm mount...
so then the question becomes, what is ideal? and how do i get there, lol. would this be why the lca mounts on "Racecraft's" rearends have like 6 or 8 settings? do you have a link to more info on this?
Re: Drag tq arm?
yup, your lca's are the big tuning key with whatever arm your running. you will see guys tuning them in degrees. thats why racecraft has so many settings. you can also adjust rear ride height to change lca angle slightly. your ideal setting will be determined by the cars weight/weight distribution, torque, tires, shocks, and track conditions. generally, you just need to hit the tires hard enough to plant them initially and then the shocks take over from there. lowering the rear mount of the lca's will make you hit the tires harder. also shortening the arm will hit the tires harder.
im not sure what book that diagram came out of, but i believe it to be correct.
Car: 86 Camaro
Engine: 468 12:1 CR
Transmission: 400
Re: Drag tq arm?
Front end shot, and the mini tubb has begun (wolf 4th gen kit).
Still not shure on which TQ Arm im going to go with...
Car: 1987 IROC
Engine: 350 vortec
Re: Drag tq arm?
burkhart FTW. for what its worth.....its VERY similar to the madman on my friend's car
Re: Drag tq arm?
the difference between one of our TA's and ladder bars is that our ta's have a sliding link in the front, which prevents it from exerting any force for and aft, so the mount location has no effect on IC without making the arm longer or shorter. The adjustment points on them are only there for adjusting pinion angle.
As far as not being a big fan of Madman, well, they've had something on the order of 15 years to figure it out now, and I don't know if that's still the case but even only a few years back they didn't have a clue how a the TA rear suspensions on our cars worked, and almost everything they did and posted had something wrong with it. Back then there were some cars that went fast with their stuff, but often it was modified from the form that it came from from madman to make it work and they still took credit for it, or basically their stuff had such screwed up geometry that the rear suspension couldn't move enough to get out of whack, so you essentially ended up with something that worked like a rail rear suspension (in other words none, on a rail they bolt the rear axle right to the frame). I wouldn't be surprised if their current stuff exhibits some small bit of evidence of knowledge, but I wouldn't give them credit for figuring anything out on their own.
As far as the original question... lets face it, that car is slow enough that it will work fine with stock stuff.
As far as what works on a faster car... well anything that maintains something resembling the stock action (allowing the front joint to move, I still prefer sliding but there are some pivoting setups that work OK) and is stiff enough not to flex at the power level you're at will work fine, once you get a reasonable pinion angle the TA isn't going to be used for tuning any at all anyway, you can tune with LCA angle, springs (though I would argue if you have things right, you should only really need the springs to hold the car up when it is not accelerating, the anti squat in the suspension will hold it up without the springs when it is accelerating), sway bar, shocks, tire height and pressure, front suspension...
no green
01-09-2016 09:22 PM
LT1Formula
10-08-2015 08:34 PM
