anyone wanna guess on e.t change with gears
stock rs, t.b.i 305, already has 2800 converter, last time out ran 16.29-16.35 with 2.73 gears, just added 4.10's with a eaton posi hoping for
6 tenth's...g-tech picked up 8mph, was shifting into 3rd just before the
mph stripe, now in third at 4500 rpm with using the g-tech...will be running it this sunday in the 1/4 mile for real times
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: anyone wanna guess on e.t change with gears
6 tenths seems a bit lofty. hopefully you didn't put too much gear in it...those tbi motors don't take kindly to mods without pcm tuning.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Sounds good to me, since his mph will be so low anyways I think it'll stay in the powerband
motor is 145k stock, i runs synthetic oil, dont let it get hot, if i could'a done 4.88's or 5.13's i would have, it's not a daily driver, just drive it to the track and back, i figure 3000 rpm at 65 mph would be do'able in 4th gear locked up, right now it's 2600 at 65mph with 275/60's
one problem i did encounter when playing with the g-tech was fuel shut off came on just before the 1/4 mile, speedo was buried, so i'am changing the driven gear from 37 tooth to a 44 tooth to slow down the speedo a little, i dont care if it not accurate just dont want fuel shut-off to kick in before the 1/4 mile mark
well do to high winds track only ran 1/8 mile...times went from 10.39 to 10.06 in the 1/8th mile...speed was the same 65mph....60ft went from
2.31 to 2.04...this with a 20-25mph headwind....so 10.06x 1.57= 15.79 1/4mile time.....on paper anyway
Zachattack0925
08-12-2015 09:54 PM
Zachattack0925
08-12-2015 09:52 PM
