28x14.5x16
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
28x14.5x16
Didnt think they would fit so well, but at 10 PSI they are still not making a total contact patch on the street, they surely hook better than the 26x11.5s, so i will use the for street business, need to see what the 2 bags of concrete do in the back with these as well, really trying to make the car roll from a dig, pretty card with a manual trans and 4.30s, so the 86 TA will be allot easier, cannot hook that well on motor and i am wanting to hit it with he 150 kit, LOL.
Fit better than i thought they would.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 28x14.5x16
The price was right, they fit ok and they are not actually 14.5 inches or i would have not bought them.
Did have to do some BFH mod to keep them from touching the fender well by the LCAs.
Hooks way better than the 26" ET streets, i wonder if lowering to 8 PSi will be even better.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 28x14.5x16
That is what i was thinking, but they are LTs, so the side wall is pretty thick, but i dont think my ballz are big enough to find out.
1 Post
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Re: 28x14.5x16
8 is awfully low to go when running it out the back door, it may want to start dancing with you.....
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 28x14.5x16
I know, only reason i thought about attempting it was because of the LT configuration of the tire, at 10 PSI, it actually drives very well compared tot he shorter 26" tall ET street that is not a Light Truck tire, still dont think i will try it.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 28x14.5x16
I dont think it is bad as it is, but a 1 inch wheel would surely make them work like they are supposed to, but i dont have any 16x10 third gen wheels.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 28x14.5x16
Will look sweet man.
Well, ran a friends truck on the street, my car bogged because it hooked, i was trying to launch at lower RPM like i was used to, LOL.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 28x14.5x16
I didnt either, i know they make a regular radial that size.
Car: 1991 RS
Engine: 5.0
Re: 28x14.5x16
Guess that was kind of an obvious question. What I meant to say was, how much of a difference? I would assume this is to fill the space between a drag radial and plain old radial tires.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 28x14.5x16
If you mean as in regular street radial VS drag? If so, the regular radials are just hard in general and that causes traction issues with power as the compound is not designed for high power applications, they are to last and hold up in near any weather condition. The drag radials are street traction oriented, and usually, but not always, hook up at the track, depending on manufacturer and specs.
So, yea, huge difference depends on the tire size and who makes them.
