15x10 w/6.5 BS
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
15x10 w/6.5 BS
Well, going to look at a set of welds tomorrow, think they might hit the spot, between xpndbl3 and Matt, i think they will be the right choice as long as they clear the LS1 rear calipers.
28x11.5 or so will be the tire i will look for, or a 295/65, i really need a 28 inch tall tire, especially for the street with this 4.30 gear set.
Car: 87 GTA
Re: 15x10 w/6.5 BS
6" bs will fit pretty dang easily. 6.5" WILL require some trimming & hammer work. With the 50-series sidewall, a 10" wheel should work fine. With a shorter sidewall, say like a 325/35 on a 17" wheel, a 10" wheel would not be wide enough. That is why the BFG 295/50R16 works a 8"wheel, the tall sidewall.
Car: 82 firebird
Transmission: Automatic
Re: 15x10 w/6.5 BS
I'm new to the boards but have been reading them for the past two months. I just massaged my rear inner fender well to fit 15x10's with a 5.5 bs. The tire I fit was the Mickey Thompson Sportsmanpro's with a 13.2 section width and 11.6 tread. A 6.5 bs would take a lot of work with a 15 inch wheel. Check out this link https://www.thirdgen.org/forums/whee...els-315-a.html
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 15x10 w/6.5 BS
LOL, ninja edit, i want some 295/50/16 for the stock 16s on my car, perhaps in the future, i know the nittos i had (245/50/16) did ok, but they didnt do good enough.
Re: 15x10 w/6.5 BS
from a long time ago:
https://www.thirdgen.org/forums/orga...28x12-50s.html
https://www.thirdgen.org/forums/orga...bs-anyone.html
much lower in the rear now:
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 15x10 w/6.5 BS
Yea, i was looking at those posts and you STILL have no posted pics of your handy work.
I did just dig int he garage and i have 2 sets of spacers i got off of some old third gens i have had in the past and it seems that 2 sets, as in 2 plates on each side will give between 7/16 and 1/2 more towards having a 6 inch BS, think i will surely do that to help with the rest of the work.
Xpndbl3, any tire rub? I am assuming 6 hours of work the answer would be no.
Re: 15x10 w/6.5 BS
Nope no tire rub, just make sure your hand fits EVERYWHERE between the tire and the wheelwell. Cut out a bunch of metal and hammer the rest, bunch of welding, etc. I don't have the rims off to snap pics, maybe next week. I had another 3rd thread that had metal working pics, but can't find it anymore....maybe it's gone now. Regardless some of my hard work is getting cut out mid-january because i'm putting in the wolfe racecraft rear 2.5" diameter springs kit with adjustable height. Should compliment my racecraft front coilovers nicely. No more cutting springs or dealing with a-arm dropping to adjust what I want to accomplish
I also "may" cutout the rear torque arm area too because mine is hanging up on the floor ever so slightly. We'll see how far I want to take this, I have to be in the world of wheels car show in beginning of march, so I can't tackle too much.
Car: 87 GTA
Re: 15x10 w/6.5 BS
....I did just dig int he garage and i have 2 sets of spacers i got off of some old third gens i have had in the past and it seems that 2 sets, as in 2 plates on each side will give between 7/16 and 1/2 more towards having a 6 inch BS, think i will surely do that to help with the rest of the work.....
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 15x10 w/6.5 BS
Yea, sure you saw the pics of mine catching the DS tunnel, i hope the LCARBs i have on the way fix the issue, looks like it will, might even help the 60 foot, but i will never know since i did the jet extensions, raised the fuel level and will be going back with the LCARBs on already.
Otherwise, get us pics if you can, your handy work is needed by myself and many others so we can go into the project knowing what to expect.
It will be fine, i have long **** studs, it is a Moser 12 bolt and the studs are long enough that i have to use open end lugs as it is.
Car: 87 GTA
Re: 15x10 w/6.5 BS
Yep, you'll be good on the lugs part. I'm still not a fan of spacers, much less stacking spacers. If I had to go that thick, I'd take a pair to a CNC shop & ask them to mill me 1 (for each side) the thickness of 2, out of 6056T6 billet aluminum.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 15x10 w/6.5 BS
I seriously think i am going to stack them, bolt them down and weld them, that way the are 1 piece and now two. Thanks for the idea Stephen.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 15x10 w/6.5 BS
Here they are, ended up with them for 400$, they have only been used for mock up and are still clean as ever, just need rear tires now.
Re: 15x10 w/6.5 BS
Spacers are a bad idea, especially on the rears and even with the longer/heavier studs that moser installs. If you _really_ need to run more than 1/4", and not something thick enough to run bolt on spacers (usually around 1.25" thick) then get some custom machined that _exactly_ fit the stud and hub locations and diameter. Allowing any relative motion between the spacer, wheel and/or hub/rotor hat/stud is just asking for broken studs.
Technically I don't believe they'll pass tech either, but I'd be surprised if someone noticed.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 15x10 w/6.5 BS
Even with the shank nuts for theses wheels? I would imagine they would allow for zero movement with them anyway, sure i am wrong.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 15x10 w/6.5 BS
LOL, that is the plan, i will resort to spacers if i have to on the street, i will not use them at the track at all.
Re: 15x10 w/6.5 BS
uh....spacers are a bad idea. here's where i cut the bumpstop, and i beat the area by the lca in as far as i could get it.
do i have to call you a women again, or are you going to take our word on it the first time and not try it even though we say it's a bad idea?
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 15x10 w/6.5 BS
So, you cut the bump stop, then the plate you installed has a notch for the axle tube it seems right? I was ready for the LCA area beating, i had to do it on a friends car, did you also remove as much metal as possible before going to the BFH like i had done? Or did you just bang it in as far as it would go? Otherwise, no other issues besides by the LCA and bump stop/spring pocket?
Was i that called you a woman(not women) if i remember correct Matt, LOL. I just wanted someone with a 6.0 to comment and a direct answer to weather or not the valve height was the same as a 243, which i found out the 5.3 head is just different in nature before TSP drops the valve down.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 15x10 w/6.5 BS
Not mine but I did something similar many years ago when I was still running a small tire. With 15x10 and 5.5" of backspace, I was able to squeeze 29.5 x 10.5 slicks under the fenders. The tall tire also needs the front of the wheel well modified.
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
Re: 15x10 w/6.5 BS
How did you get that 29.5 to work with out modifying the outer lip? I am mini tubbed and still need to modify the rear of the outer lip to compensate for the growth of the tire. Or did you leave the car the stock ride height?
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Re: 15x10 w/6.5 BS
not sure about all the year cars but my 85 has the seat belt retractors in the lower front inside corner of the wheel wells, makes it a bear to beat it in right there with the triple layer floor and re enforced seat belt mount area
Car: projects.......
Re: 15x10 w/6.5 BS
I love my plasma cutter.
lol
The calipers will probably require some grinding to clear, but many have done it. - Cheapy parts-store universal spacers suck, but I have run single pattern billet spacers on more than one occassion, even on my car. Our spare wheels/tires are offset 1/2 further in; they clear fine, but I already hate how far the tires are tucked under the car, so I run spacers with them - 5/8 studs though.
lol
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 15x10 w/6.5 BS
Oh yea bro, calipers were ground down when I put the 12 bolt in the car. Pretty sure they will work fine, I really did t want the pro stars since everyone has them but that deal was hard to pass up.
Matt, that looks sick tucked that far up, any reason for the 9 inch wid tore instead f a 10 or more? I am guess it just fits easier with less tread section, but at minimum I want a 10.5, my car would hook hard as bell with a 29 inch tall tire though.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 15x10 w/6.5 BS
Ok, sure looks bad *** with rubber tucked like you have with no springs, really sets a third Gen apart from the rest. I am going to assume to make a 325/50 fit is no easy task then. Won't know till I try, will see if anyone has a set for mock up bfore I take the plunge, they would make for a killer street tire for goofing off with the pusssy **** mustang crowd.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 15x10 w/6.5 BS
As long as I can use a 295/65 I can live, but if the 325/50 tucks, I will have what I have been wanting.
Re: 15x10 w/6.5 BS
Stick shift with no adjustable shocks and a 6 speed? This just for screwing around on the streets? I don't see the point in wanting more rubber since it probably won't make much of a difference. In fact some of the local street racers have found a narrower tire with more pressure on the tread available hooks better than a wider tire actually on unprepped/poorly prepped roads.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 15x10 w/6.5 BS
Thought a 295/65 was 29 inches tall, 30 is cool if I can tuck it but 29 is already pushing it right matt?
The 28 inch tall tires are for the street, blowing the 26x11.5x16s off on mor occasions than I like, so a 28 should help in conjunction wth the LCARBs and removing the front sway bar, that is what I am banking on anyway. I am looking for QA1s for the rear, sure they will help as well.
Re: 15x10 w/6.5 BS
I don't like QA1 products, had too many fail from street driving on buddies cars. Personally I'd look into the mustang adjustable rear shocks from strange and then just buy the madman mounts to turn the lower shock mount 90 degrees and have at it. That's my plan if these coilovers don't fix my traction issues 100% in the spring. Probably should pop some weight out of this car too, since she's a pig. But I do enjoy my heat, wipers, and radio though Along with both front heavy corbeau seats.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 15x10 w/6.5 BS
Sounds like a plan, except i think i could fab my own mount for the mustang shock setup. I found some 325/50/15s locally that i think i will take the plunge to buy, kind of exciting to get the wheels on the car with a 6.5 BS and not have meat hanging out the wheel well.
Then i will just be waiting on my Ebay lug nuts to come in, LCARBs are on the was as well as a A/F ration meter from innovative.
Found a MSD 6010 box on Tech that i should have on the way for the 86 TA, i am spending too much money lately, LOL.
#42
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 15x10 w/6.5 BS
Looking at the Spohn pieces that in my opinion are way over priced, if i can find something cheaper and just make it work myself, sweet, i would love coul pvers on my car
http://cgi.ebay.com/ebaymotors/Spohn...Q5fAccessories
But i would just need something that is about the same weight i assume, well, being fully adjustable, maybe not exact.
#43
Re: 15x10 w/6.5 BS
I'm going to install the wolfe racecraft 2.5" rear spring setup in the next month, it runs around $180 for it with springs. Still running the 50/50 rears unless something strange pops up in my launch that causes me to need the strange double adjustable rears. We'll see how it is now that I have the racecraft front coilovers on the car, so the nose should pop up better at the hit than staying locked down like before.
#44
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 15x10 w/6.5 BS
Cool, keep me posted, i have always relied on RS suspension to transfer weigh on the front with stock springs and stock replacement struts, the rear though, i have never really known what to do, the LCARBs are the first thing i have ever ordered to try to change how the rear reacts to launch.
#47
Car: 87 Firebird Formula
Engine: AFR headed SBC
Transmission: TKO 600
Axle/Gears: 9" Moser with 4.11's
Re: 15x10 w/6.5 BS
Cool I picked up their LM-2 and installed it just need to wait for spring to use it now lol Hopefully there nice pieces. If anyone has experience with mine I wouldnt mind hearing what they think of it. Thanks guys and good luck Zone on your project. Seems like you got some nice goodies going at it this winter.
Link to mine:
http://www.innovatemotorsports.com/products/lm2.php
Link to mine:
#48
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 15x10 w/6.5 BS
Sweet man, you have EFI i assume to have all those features? Being carbed, i just need mine for direct read out and then the data-logging on my lap top to get her dialed in to perfection.
#49
Re: 15x10 w/6.5 BS
Actually I have a carbed setup just got a good deal on it so I went with it. Plus it is nice to have all the other features for that just in case reason lol
#50
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 15x10 w/6.5 BS
Totally understand, i am buying so much i am cutting corners on stuff like that so i might get the turbo project running on motor, then built up the rest of the plumbing and what not before i install the turbo and IC.
