15x10 w/6.5 BS
#51
Re: 15x10 w/6.5 BS
Let me know how that datalogging goes, I might sell off my UEGO and run that. Actually if the datalog software uses the 0-5v reference signal off the gauge I'd be interested in trying out the software included with that to see how I like it. Mine has the datalogging wire but this company didn't offer any software to hook up to tach and the reference wire to record. I'm curious about it.
#52
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: 15x10 w/6.5 BS
Will keep everyone updated on it, it kind of sounds too good for 200$, so i hope it is what it says.
#53
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: 15x10 w/6.5 BS
I had 325/50/15's on mine with 15x10 on a 6.5 BS. The yellow areas either should be dealt with, or I slightly massaged there. The red areas needed a good beating. This being the passenger side. The driver side doesn't require any beating on the rear of the wheel well. As you see it here is how I ran it.
#54
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 15x10 w/6.5 BS
Awesome man, that is exactly hat i needed, i should have my 325/50s tomorrow. I am anxious to see how it hooks, especially if the LCARBs help.
#57
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 15x10 w/6.5 BS
Yea, for real, all you automatic guys talking down on my lowly 6 speed, shame on you, LOL.
LCARBs came in today with the wide band, I was going to ask if i should weld them in, but judging by fast82z's pics, he did, so i guess it will not hurt. Pity they have such a nice back powder coating on them too.
#59
Re: 15x10 w/6.5 BS
Years ago I had welded mine in with a 110volt welder, this past season with the transbrake I figured I might as well grind the welds down and hit it with the 220volt one I have now, and definitely got much better penetration out of it this time around. Perhaps a local frame shop could buzz them in with a big mig/tig if you don't have one.
#60
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 15x10 w/6.5 BS
Hmmmm, i have a friend with a 220 i can use, so i can just bolt them in and drive over there and use his, my 110 dies get pretty good depth for what it is on the highest setting, but i want a 220 pretty bad.
#62
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 15x10 w/6.5 BS
So, you cannot just bolt them in if you wished? These damn things didnt even come with instructions, i have seen them before so i know how they mount, they are the Ebay pieces, 55$ or something like that.
#65
Car: 87 GTA
Re: 15x10 w/6.5 BS
The only bolt-in, no weld ones I know of....Have a mount that reach the shock mounts. Without the shock mount tab, a LCARB won't stay in place & I certainly wouldn't want to try to drive like that anywhere.
#66
Car: 86 camaro
Engine: 385
Transmission: glide
Axle/Gears: moser 12 bolt spool 4.11
Re: 15x10 w/6.5 BS
i just got done putting a 295/65 on mine. 15/10 with 5.5bs the edge of the tire comes to the edge of the fender. looks good
#67
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 15x10 w/6.5 BS
Pics man, pics....
Yea, i am going to try to get them on tomorrow, weld them up good and then test drive it after the wide band goes in.
#69
Car: 87 Firebird Formula
Engine: AFR headed SBC
Transmission: TKO 600
Axle/Gears: 9" Moser with 4.11's
Re: 15x10 w/6.5 BS
Zone do you got the new tires on now as well? What was the final size you decided to use?
#70
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 15x10 w/6.5 BS
I am counting on it, i just plan on much less and more controlled launches.
Waiting to pick them up, 325/50/15.
#72
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 15x10 w/6.5 BS
Yea, pics if possible, i think the 6.5 BS was a good thing for me, just need to get the tires so i can mock up and get the work dont to the wheel wells.
LCARBs are on, seems to hook a touch better, or like it is trying, on the street, like it is attempting to plant the tires rather than spinning and let the tires try to grab.
O2 wide band setup is working well, i am pretty close to where i wanted to be at idle and WOT.
#74
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 15x10 w/6.5 BS
I am fixing to go to work right now, but later i will try to remember to put the info on the output wires for you, i am not 100% on what all it is capable of, it has a output and input wire set, i dont know what the input is for, but the output reads onto my lap top. The there is a yellow and brown wire i had to close off since i was not using them.
#75
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 15x10 w/6.5 BS
Found out these bastards still hit my calipers and i had to grind and use two of the mentioned spacers to make it clear, later i will do some more grinding so i can eliminate the use of the spacers, but they give me an idea of how much i need to remove from the calipers.
#77
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 15x10 w/6.5 BS
I dont know how to be able to rip a copy to send toy uo man, been asking a friend and he told me he would have to look at it, i am not very big into computer tech, i only burn CDs, LOL, who uses CDs anymore?
#79
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 15x10 w/6.5 BS
I have it on my lap top, i will see if i can get it on my PC.
C409
12-17-2016 09:35 PM
supermaxxbasher
05-19-2005 12:34 AM
