Squatting the rear of the car
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I had noticed, i will post some pics later, but i actually saw that my car squats so hard dumping the clutch at 6000 when i was trying to launch really hard, even though it bogged, but the TQ arm actually contacted the body and split the sheet metal, anyone ever have this happen before?
Car: '82 Z28
Re: Squatting the rear of the car
My spohn torque arm clearanced the floor before I put in the control arm relocation brackets.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
i forget do you have some LCARBs on it? if not, its definitely time
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I'd inspect or replace your tranny mount first.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Is a new energy susp piece.
With stock ride height i would nee that?
I ride alone at the track, but yea, they migth have noticed before me, LOL.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
No biggie, my car is just a beater, so i actually thought it was cool that my car does hook that hard at the track, but it isnt good.
Yea, a stiffer shock is the first on the list but i dont know what kind that are decent but not expensive.
So, assuming removing the front WS6 sway bar will not help this?
remove the front sway bar and weld on some relocation brackets and you'll be good to go, put them in the middle hole and hit it. ![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
Stiffer shocks are probably not needed until you do the above first so save your pennies. Or buy some air lift bags before the shocks.
My .02 of course, so take it for what you will.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
It rolls out hard as hell, but bogs, i am sure it needs jet extensions, as hard as the front end does come up, the fuel has to be sloshing to the back so hard that the rear metering blocks are just not getting any fuel to the jet openings.
Thanks for the advice guys, LCA relocators are on the to do ASAP list.
But, i just scored a 1000$ wad from my dad for an early Christmas deal, so a set of ported heads are coming WAY sooner than i planned, LOL.
Got some more mustang **** to whoop on.
Car: 84
Engine: 360 210 alumium heads
Transmission: th350 3600 stall w/shift kit
Axle/Gears: floater Ford 9" 4.56 full Lw spool
My car did the same thing but mine did not put hole in the floor pan just rubbed it. I was running stock torque arm with solid trans mount. I think it was the whole arm flexed and the car squatting. I was running low 12's with the stall converter and slicks. I would also suggest the LCA relocation and a after market arm. The LCA's help a lot
Car: '82 Z28
I bet it is squatting that bad. Mine would hit the bump stops on a footbrake launch before putting the brackets in. After putting them in, no more squatting and the wheel to fender gap actually stays the same or gets a little bit bigger.
Before:
![](http://bdrperf.com/camarosite/images/rds/3469-whchevysm.jpg)
After:
Before:
After:
![](http://bdrperf.com/camarosite/images/rds/rdsgrayz28.jpg)
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Looks way better, thanks for the pics.
Thanks for all the input fellas, i really never knew it would be something to use on a stock ride height car, so as soon as i can, i will be getting a set. I got the cash for heads right now, so that is the primary focus as well as the drive shaft and LCARBs. Otherwise, removing the front sway bar and the front impact bar are happening really soon, i have to see how much it will help on the street, i think a couple bags of concrete for the hatch to see if i can really launch on a couple mustang guys locally talking ****. They jump out and i have to reel them in.
evilcartman, what was the 60' on those shots?
my 4th gen would 1.53 off a 6k dump and never did anything close to that. lowered with eibach pro springs, stock shocks, no relocation brackets, but it did have a fairly short body mounted torque arm. front swaybar was still on there.
Car: projects.......
Car: 1987 IROC
Engine: 350 vortec
if its the jegs/alston style arm, those give a ton of A/S% themselves, usually making the LCARBs not needed
Car: '82 Z28
Don't remember the 60' times but probably 1.80 something in the first shot and high 1.60 to low 1.70's in the second shot. I'm running a Spohn torque arm mounted to the crossmember. The shorty arms really change things up. Guy I used to help out was running one on his 4th gen bird launching at 7000 and he'd get a ton of fender/wheel separation. He had to raise the lower shock mount so it wouldn't extend to the end and unload the tires.
Car: 91 Pontiac Firebird
Engine: Killer SBC, w/ RV cam
Transmission: AutoMatic, w/ shift kit
Axle/Gears: Posi-Traction
Mine hooks pretty hard, 1.4-60'. The torque arm at the diff hit the tunnel so many times it finally ripped thru. I notched the tunnel and welded it back up. It almost looks like its supposed to be like that.
Car: 1987 IROC
Engine: 350 vortec
why not put some relocation brackets on that thing? i bet you get well into the 1.3x range with them when you get rid of all of that squatting
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
What torque arm are you using?
I put a much bigger hole in the floor when my BMR adjusting link broke (not its fault).
I have LCARB's on both cars. I was running the stick car in the upper hole when the adjuster broke. When I get it sorted out, I'm going to try the middle hole, because it was still slipping pretty good off the line, whether 4000 RPM or 5500 RPM launch.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Should have video to see if the LCARBs help out or not, hope nothing breaks:
![Name: dde1b347.jpg
Size: 347.3 KB](https://www.thirdgen.org/forums/attachments/organized-drag-racing-autocross/399646d1501438174-squatting-rear-car-dde1b347.jpg)
The truck matching the car was actually unintentional.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
It is the pic i guess, i should remove them for weight reduction, LOL.
Was a great night, i got my 7.2 at 97 MPH, i wanted a 7.1, but they kicked me for no fire suit, biitches. Was on a 1.6 60 foot, so i wanted to drop to 10 PSI and hit it again, but they said my leather jacket was not good enough, LOL.
Nothing broke or made funny noises, so i dont know if i could be happier picking up 3 MPH and a few tenths from a carb adjustment and swaybar removal.
The LCARBs seem to be working, here is the video, i got sideways launching and had to just ride it out, it just didnt want to hook like usual on 12 PSI, i usually run 10, but wanted to step down and didnt get to make a 10 PSI run, which would have got me a 1.5 60 because i would have launched at 6K.
So, 6.9x is the near future goal when the 243 heads go on, i am sure i will see it happen, love the wide band, the LCARBs seem to have been a great 60$ investment, thanks for the support and suggestions fellas:
![](http://i157.photobucket.com/albums/t74/ZONES89RS/th_2f89f3d3.jpg)
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
You aint lying man, DS is on the to do soon.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Finally, thanks to input from my fellow TGO members, thanks again guys.
#42
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Yea, i love it with the 6 speed, i can cruise anywhere and get 20 MPG if i just drive like normal.
#44
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Mine is at 7200, it hit pretty bad the first pass saturday so i hit 4th the second pass(vid) when the shift light came on instead of riding it out in 3rd.
hectre13
12-11-2023 08:14 AM
1992 Trans Am
05-10-2023 07:19 PM
novaderrik
08-10-2015 12:44 PM
