Stock rear end and suspension 12 57 pass
Car: 1986 Iroc-z Camaro t-top
Engine: 355 SBC
Transmission: 700r4 TCI const. Pres. Valve body
Axle/Gears: 3.73 posi/mosuer axles
86 iroc z with 350 hydraulic extreme energy comp cam .520 lift cam and brodix 200cc aluminum heads..about 10 and a half compression with forged srp pistons and a tunnel ram. If I put a better intake to match my rpm range it would run better but it's what I had to work with. I have gotten a 1.78 60 foot so far but have only raced it a few times(room for improvement)
http://www.youtube.com/watch?v=PikeVupD9T4&sns=em
Engine: 355 SBC
Re: Stock rear end and suspension 12 57 pass
Thanks I'll try and fix that
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Nice. I feel like you should have made a faster pass than that with your setup and 60' time. Do you have dyno numbers? If so what are they?
Im going with a similar setup except 200cc WP heads ,forged pistons and rods, as well as my vic. jr intake mani. I should be around 10.5:1 as well but carbed. I was hoping to run somewhere in the low 12's-high 11's.
Engine: 355 SBC
Yeah I'm having carburetor problems yet and it likes to stumble off the line. The tunnel ram gives me no low end but I'm thinking once I get like an rpm intake it should run 20s or 30s with my 373s. I managed to get it down to 2180 taking out any unnecessary brackets and a/c and about a miles worth of wiring. Anything that could be taken out in the engine bay it is gone other than that the car is still loaded down.. I also didn't put dual headers or header dumps and that could probably give me a tenth. If I really worked at it I could probably get a 12 second out of it but this is only my street car And only a few cars in my town could touch me. Those dang lsx motors get me though if they are built
Engine: 355 SBC
And I haven't dynoed it but my engine builder did a computerized dyno graph based on everything in my motor and it was like 480 hp at the flex plate give or take
Car: 1985 IROC-Z
Engine: 355
I am aiming towards 425-450 at the crank with my setup, so that rating sounds spot on with your setup. With that number you should be in the low 12's no problem.
Engine: 355 SBC
Yeah hopefully..I'd rather start out a little slower and work at it to make it faster. Gives me a challenge
hectre13
12-11-2023 08:14 AM
hectre13
08-26-2015 08:17 AM
AkDrifted
08-17-2015 07:45 PM
