406CI Small block 83 Firebird with 30/9/15 MT slicks... 1/4 time?
#51
Re: 406CI Small block 83 Firebird with 30/9/15 MT slicks... 1/4 time?
yea so i finally went to the track
only to be turned away becase i didn't hook up the neutral safety switch...
so i hooked it up out there and boom shifter cable is kinda messed up. so he asks to start it in park, the shifter went to park the trans stayed in reverse.
So basically i ended up running over the tech when it started in reverse and he was standing in the way of the open door.
#52
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
#53
I can't say I am surprised at your post here. Take your time and go over the car slowly to make sure it is safe. There are plenty of people who can guide you here. Presentation has a lot to do with a techs attitude at the track. if things are neat and clean, tech will go much easier. When your car looks like a blind man assembled it, I can guarantee you will have tech problems.
The tech was impressed with the rest of the car. Checking the neutral switch was the last thing he asked to see.
He was cool about it considering I ran him over. He said get a new shift cable and im good.
#54
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
When are you planning to hit the track again, I am curious to what you will run.
#55
Car: 89GTA, 62' GSXR1000-SS
Engine: 406-HSR
Transmission: Nocturnal
if i were a bettin man ill call 14.80 first time out.. with spray 19.20 at 28(coasting)mph haha just messin.. make sure the bugs are worked out and keep us posted
p.s did you really run him over?
#56
Car: Z/28
Engine: 355
Transmission: Turbo 400
I would suggest a battery cut off switch also. I did not see one in the pics at the rear of the car.
#57
yea he basically got funneled into the open door and fell down.
anyways got an update. finally got it running again tonight after blowing a rear freeze plug. upgraded a bunch of stuff in the proccess of fixing it.
also got a NX nitrous wet kit with 2 10lb bottles
ill have pics up soon. I hope to make it to a drift and drag event on the 25th of Feb
#58
Car: 1991 RS
Engine: 5.0
Hey man everybody has to start somewhere. Its come along ways and before you know it you'll have everything sorted out. Good luck.
Actually I can't laugh too much. The neutral safety switch on my megashifter went out after I replaced the starter, and I started it in drive in the driveway and almost ran over my front porch years ago. Live and learn I suppose.
#59
The first time i put it in i just winged it in in a weekend. i was chasing down leaks for a week
This time i took my sweet *** time putting it together, making sure everything was done right. she started right up without any leaks so i think i got it mostly sorted out
damn it was a bitch because of the kickout rear sump baffled race oilpan.
ill show you guys what im talking about when i get some pics up.
9192camaro
16
02-03-2019 12:21 AM
theshackle
03-05-2017 06:37 PM
Fast355
12-02-2016 06:33 PM
