Adjustable LCAs
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Adjustable LCAs
Just got some non adjustable LCAs, does it matter if i dont have the adjustable set? I got them for a bit of labor on some heads so the price is right, but should i spend the cash on being able to move the rear forwards and backwards? I just think the PH bar and TQ arm being adjustable is enough, but wanted to see what my fellow TGO members say...
And here is a Gif for wasting your time lookin at my thread.
-Z
-Z
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Adjustable LCAs
Adjustable LCA allows you to align the diff. If the diff is square in the car with non adjustables then they'll be fine.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Adjustable LCAs
Man, i wouldnt even know where to get that stuff if i wanted to. I think i will be fine, i am just glad to ditch the stock stamped pieces, finny thing is i think i went backwards in doing everything and then getting the cheapest suspension part last...
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Adjustable LCAs
I have never dealt with this company, but they do sell everything you would need, should you want to do it. Just make sure your welding skills are good.
http://secure.chassisshop.com/categories/5920/
Re: Adjustable LCAs
My camaro was off .2 degree on the chassis rack with the adjustable LCAs at stock length, with them adjusted 1/2 turn or so I am now .02 degree off from perfection. If we sneezed at the LCA it would change one way or the next and this is about as good as it gets. Car would kickout a little in the burnout box and off the starting line, now it's straight as an arrow. I could probably let go of the wheel and make a pass it's so uneventful now.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Adjustable LCAs
I will be happy with 1.5s or so in the 60 foot, so i doubt i will get to 1.3s in this car.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Adjustable LCAs
I already have adjustable TQ arm and PH bar. But the LCAs were free with some labor on some heads. Not to mention ditching the old as ***** bushings in the stock lowers. Could not justify having spent 600$ on TQ arm and PH bar just to have boxed stock lowers, LOL.
Since it is a street car, i didnt think the adjustable LCAs would be important but i needed you guys input, think i am good with what i have then, thanks fellas.
Car: 1991 RS
Engine: 5.0
Re: Adjustable LCAs
I say run em for now and see what happens. You can always upgrade later if you feel the need.
xpndbl3-You might be on to something with this no hands racing. I mean all these other sports are getting extreme. Maybe its time for drag racing to step up. Whos down for some no handed passes...anybody? K nevermind.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Adjustable LCAs
No hand on the wheel with a 6 speed, that would be bad.LOL
Re: Adjustable LCAs
Really, adjusting axle location with adjustable LCA's is not the right solution. If the axle is not located properly in the car with both control arms the same length that means that either the LCA brackets on the axle (or actual axle) are bent or the body is messed up and should be fixed. Different length LCA's will cause the 2 sides to react differently when reacting to bumps or weight transfer.
These things originally came about to adjust both sides evenly to better center the wheels in the wheel openings on cars like the Impalas that come from the factory with the wheels closer to one side then the other.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Adjustable LCAs
Well, evidently, after running the 28x14.5x16s, they can be seen closer to the rear, so i need adjustables, its all good though, gives me a reason to find some and then put the non adjustables on the 86 TA, LOL.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Adjustable LCAs
I keep forgetting, i will try i to send it later, i always am busy with other shitt, no thinking about it.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Adjustable LCAs
LOL, well, you waited too long to stop doing that.
LT1Formula
10-08-2015 08:34 PM
