Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
3rd race with the LS1/T56 (I know, this is getting boring)
Old 08-05-2010, 09:55 PM
  #51
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The '57 (396, 4000 stall, 3800 lbs, 4.11 gears, 13.0 ET @ 102 mph) pulled high 1.7's.
This Camaro, with ZZ4/CC-q-jet, 2500 stall, 3550 lbs, 3.23 gears, 14.0 ET @ 95 mph, would do 2.0 60's (I think it had a 1.997 quirk run one night).
Old 08-05-2010, 09:59 PM
  #52
TGO - 10 Year Member
skinny z's Avatar
Re: 3rd race with the LS1/T56 (I know, this is getting boring)
I always thought it would be a lot of fun to race a stick car.....
Old 08-05-2010, 10:32 PM
  #53
five7kid's Avatar
Engine: LS1/LQ4
Except for the breaking stuff, it has been fun. Especially putting a .039 package on a tranny brake car.
Old 08-06-2010, 09:03 AM
  #54
Shagwell's Avatar
Car: projects.......
Originally Posted by five7kid
The Moser torque arm is a straight-across tranny cross-member mounted type, makes exhaust difficult. Just no free lunch, huh?
It might be possible to merge the QP links with the BMR, to end up with something like shagwell makes. Or, local outfit that does roll cages & exhaust might be able to fab up one to pick up the QP brackets.
What you have will work, it just needs an extra leg on the 9" bracket. If you were to put two tabs in the middle of the tq arm mount surface and two on the axle tube just outside of the center chunk you could run an adjustable link with rod ends that would stabilize the side-to-side flex of that mount. If that were stable, the tq arm rod ends would only be loaded in thrust as they are intended.
Two rod ends, a threaded tube, and 4 plates. Fairly simple solution.
Old 08-06-2010, 01:04 PM
  #55
fenton06's Avatar
This is what I would do...I also don't think these were intended to be used with an adjustable torque arm like you have mentioned because when I spoke with the owner he really emphasized the pinion angle adjustment with a stock tq arm. I work at QP and actually cut the steel for those mounts last week interestingly enough
Old 08-06-2010, 01:28 PM
  #56
Shagwell's Avatar
Now that I'm really thinging about it, you could also fairly easily fab up a tab that bolted on with the pinion support and was tied to the bracket. - It really wouldn't take much to tie it securely to stop any side-to-side movement/flex.
Old 08-06-2010, 01:55 PM
  #57
five7kid's Avatar
Engine: LS1/LQ4
I had thought of both of those, in fact. Bolting to the pinion support seems simpler, although I wasn't sure if adding stress to that part of the carrier housing was a good idea. Bracing to the axle tube should also work.
Old 08-20-2013, 11:02 AM
  #58
dennisschreuer's Avatar
Car: 87 RS Camaro
Engine: LS6
Transmission: Tremec 6 Speed
Axle/Gears: FAB 9, Floater, 370 True Trac
Still using that Torque arm?
Looks like I have to fab one up for my FAB 9 housing.
You would think that these would just be available....
Dennis
By the design it does seem as though they intend it for a stock type arm.
Like I said, I'd keep the BMR arm as intended, and just re-work that mount a little to make it solid. You could indeed keep it adjustable as Matt noted, but there's not really a need with the tq arm being adjustable.
I do my 8.8 conversion similiar, but I build a custom tq arm that fits directly to it.
Old 08-20-2013, 11:55 AM
  #59
five7kid's Avatar
Engine: LS1/LQ4
No. My issues centered around the way QP did their TA mount. It was not stable side-to-side, so stuff kept breaking/bending. Would probably be fine for a stock TA or something only street driven.
I ended up going with an S&W torque arm & mount. Extremely stout piece. Reused the BMR cross member for it.
Then I sold the car this past spring.
Hotrodboba400
12-10-2019 07:07 PM
91L98Z28
Southern California Area
09-19-2015 09:35 AM
xXIROC ZXx
Wheels and Tires
09-15-2015 11:18 PM
89-S-dime
09-04-2015 10:34 AM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: 3rd race with the LS1/T56 (I know, this is getting boring)
