first autocross
Car: 87 TA
Engine: 305 tpi
Transmission: auto
first autocross
Just thought I would share with everyone my first autox exprience. First what I have done to my car, subframe conn., tubular lca, adj. phb, wonder bar, edlebrock stb, lowering springs, kyb gr-2, new poly bushings everywhere, bridgestone g007, 3:42 peg leg, stock motor, stock tranny, ls1 rear brakes. All that put me in STX.
I am the 87 ta, my buddy was in the 89 rs in SM. Wife had dibs on the video camera. I ended up fairly consistant with one freak run that I ruined with some cone kills.
Now the list of stuff to fix before the next time I go, tires as these lost all grip after they heated up, and seats with more support!
http://www.fvscc.com/results/2010_summer/event2_fin.htm
Car: 83 Camaro
Engine: 4 Bolt 350, Bowtie aluminum heads
Transmission: TH350
Axle/Gears: 3.42, superior axles, Torsen diff
Re: first autocross
So....... Are you hooked yet? It is addicting
After my first event I started to get serious. AWD Dodge Stealth twin turbo. By the second event it had fuel system mods and larger turbos, By the third event it had a set of adjustable coilovers and some soft Hoosiers on another set of rims. Now I am having a blast with the Camaro. Unfortunatly the Stealth was faster then the Camaro.
Car: 87 TA
Engine: 305 tpi
Transmission: auto
Re: first autocross
I was hooked after the first run! Infact I am still giddy about it Any advice on tire pressures? I had a couple people tell me inflate to max before and work down. What is better for autox more air or less?
Also the longer corners kinda got me, if I pushed it I felt like I was going to flip over, my imagination, prolly because of sliding around in the seat so much.
Car: 87 TA
Engine: 305 tpi
Transmission: auto
Re: first autocross
http://www.youtube.com/watch?v=4Xa8JSgUcuc
not my cars, but you catch a glimpse of my silver ta in the pits with the hood up. The track setup was great for what they had to work with.
Car: 83 Camaro
Transmission: TH350
Re: first autocross
Big heavy car on street tires? You will probably end up at 40-42 PSI to keep the sidewall from rolling. Out a couple dabs of shoe polish where the tire curves into the sidewall, you will be amazed at how far they roll over.
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Re: first autocross
Go to harbor freight and get a temp gun after a run shoot the tire tread in 3 places (inside, middle, and outside) these readings need to be very close to one another. check all 4 tires, once you get the temp readings as close to the same you are at proper inflation and maximum grip.
Car: 88 Trans Am
Engine: 305 tpi
Re: first autocross
Yup, That's right around where I was when I was on street tires.
I had more air in the front than the rear to hook up better.
Even with some stiff sidewall Hoosiers, I still used to get a decent amount of sidewall flex as shown here. (skip to 56 sec. mark)
http://www.youtube.com/watch?v=8w46nhZDQnI
KeithO
09-25-2001 06:28 AM
