Easiest/cheapest way to gain 4mph?
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
So i went to the track for my first time and my best run was 14.455 and my highest speed was 98 but most were 96. I was curious if there might be a cheap/ easy way to gain that 4 mph. i was thinking pulling the seats might help but i doubt it'd be that big a difference. i just really want one of those sweet 100mph Club stickers before I join the Navy.
Car: 84 firebird, 85 transam
Engine: 350 SBC Or 7.07 Tonys,305stock
Transmission: Big Ugly, 700r4
Axle/Gears: 4th gen rear disk 3.42 lsd,9 bolt
Re: Easiest/cheapest way to gain 4mph?
Take your tools out of the back all the loose change out of the astray and get your self to race weight ( take a leak) and now for the seats .two in the back and one up front could come out and give the car a tune up. What was your 60foot time
Engine: L98 and L03
not spraying it as it has over 230K on the car. cleaned car before I left and didn't have tools, even vacuumed and minimized race weight . had 1/4 tank of gas and no dinner. best 60' was 2.21. Stupid me threw away my time slips at work today
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
tbh just shed weight first the stuff that doesn't matter. then some stuff that can be put back on after the race is over >.>
Car: 1991 RS
Engine: 5.0
If you haven't done them yet, do a search for free mods. These are simple things you can do yourself that dont cost a dime. Like gutted airbox, throttle body coolant bypass.
Car: 1972 SS Nova, 1991 Camaro drag only
Engine: Stock 350, 355 w/12.5's
Transmission: 350 auto's
Axle/Gears: 3.55, 3.73
Have you thought about the spare tire in the back?
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
Remove the front sway bar once at the track. It will help with you 60' times by allowing more weight transfer and remove front end weight as well. You will be surprised on how much your 60' gains you on the big end.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
possible tune for 250 bucks of tuning equipment could also go a long way
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
run only 4 quarts of oil. its in Don terrill's horsepower secrets book.
Car: 91 RS Vert, 87 SC T-Top
Engine: LO3, LG4
Transmission: 700r4's
Axle/Gears: 2.73, not sure yet
this may be the dumbest idea in the world but could i use the spare tires off these cars as skinnys up front?
they're not very light either. i do have some weld skinnies for sale.
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Ya, you're right. One of the stupidest ideas I've ever heard of. You need to refrain from even thinking of going to the track for a few years, untill you get some common sence. And that was lite comparred to what I was really thinking.
the mustang guys used to put real tires on t-bird/cougar mini spare wheels since they came with nice, minispare sized aluminum wheels that matched the factory wheels.
Heck, put a pair of minispares on the front of your car and drive it around the block, by the time you come back you'll be terrified by the idea. The car won't want to steer, stop...
Engine: L98 and L03
k so free mods, shed weight, more timing, and skinnies/slicks combo. free mods are already done, next step shed weight. I forgot these cars even had spares. Maybe I'll find a jack while i'm pulling it out and bee able to lift the car and get the sway bar out too. Any tips on launch technique for street tires to help more with the '60? (only raced once so i know mine is bad) also should I run the car warm so it can go into closed loop or keep it cool so it has colder intake air?
Car: 1985 IROC-Z Silver
Engine: Vortec 5.7L
Transmission: WC-T5
Axle/Gears: 3.23 disc brake 10 bolt
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
Give me a break. You gain next to nothing weight wise with a longer positive cable. If putting the battery in the trunk didn't help then why does every strip car have it mounted in the trunk? Its not just about how much the car weighs, but where the weight is located.
Car: 89 Iroc-z
Transmission: TH400
It helps. Alot of strip cars put it there in the trunk to do a couple of things. Makes it easier to wire in a cutoff switch with teh battery real close to the switch. Frees up room in the engine bay for stuff like fuel cells, coolers, and turbos
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
It does do all that too, but when people originally started to put batteries in the trunk it was for weight transfer. I personally picked up almost .2 back in the early 90's with my radial tired 80 camaro when I put the battery in the trunk.
Engine: L98 and L03
i'm not gonna be moving the battery as I want this car to retain a bone stock appearance since it's1 of 592 91 B4Cs. since we're on the topic of improving the '60 could i get suggestions on proper launch technique? right now i have 300 tread wear street tires and i always spin them on the launch whether revving it up or gassing from idle. i know there's room for improvement
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I got 5mph going from 3.23 gears to 3.73 gears. 88mph to 93mph
It also dropped my ET from 15.7 to 15.2.
This was when the car was an auto.
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
When I race on a true street radial I will stall it up as much as I can, then on the last yellow I initially just take the foot off the brake and let the car lunge forward only applying as much gas as the tires will allow until I'm at full throttle. Using this technique I was able to cut a 1.7 60' and run an 11.7 @119mph. I never did get to run that car on slicks, but the same motor only with a bent rod in my 84 firebird with same gears and converter on slicks went 1.6 60' and 11.2 @121
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
If you haven't already done so, convert your airbox into a ram-air set-up. I know on the IROCS it is easy to do. I had to fab up a system on my T/A pulling air from the passenger fog-light opening and picked up 1.23 mph in the quarter and .43 mph in the 1/8. You will see the bigger gain the last 1/8 mile of the track though.
I think there is a tech article for the camaro/irocs.
Engine: L98 and L03
Ok I finally found the time slips from that night. Please tell me where you think improvements could be made.
R/T: .642 <-I know here but that doesn't factor into the race does it?
60': 2.210
330: 6.073
1/8: 9.310
MPH: 75.82
1000: 12.107
1/4: 14.455
MPH: 96.29
I would really appreciate some help if there is an area that looks off. Oddly enough my best MPH was my worst ET. how does that happen?
60': 2.210
330: 6.073
1/8: 9.310
MPH: 75.82
1000: 12.107
1/4: 14.455
MPH: 96.29
that 60' looks like you're smokin the tires
Yea, I don't know what kind of tires you are using, but even a " stock " car will benefit from a drag radial. Being consistent is the name of the game.
Also, the R/T totally depends on your reaction. You could let the green stare you in the face, and the clocks wont start till your front tire breaks the beam.
Get your 60' down, with at least a DR.
Car: 1991 RS
Engine: 5.0
Traction will drop your sixty foot. But if you want more MPH your gonna need more power. Maybe higher flowing air filters, a cutout, a quick at home port job on the intake, some 1:6 roller rockers. Not sure what your budget is but these things can help add up to what your looking for with trap speed. And like Orr said, get it tuned by someone or learn to tune yourself. There is definately some power to be found here. Good luck.
Car: 1989 Trans Am GTA
Transmission: M28 T56
I say spray it, a 50 or 75shot should do it.
Other than that, go with the tune up, weight loss suggestions.
100lbs is worth 1/10th of a second.
My B-body LT1 is only 260hp, just 15hp more than the last year of the L98 in an F-body. With headers, exhaust, and a CAI its putting me in the 102mph bracket while still pulling 5* timing (datalogged run).
So a 50 or a 75shot would put you right there if your car is already running in peak form.
60': 2.210
330: 6.073
1/8: 9.310
MPH: 75.82
1000: 12.107
1/4: 14.455
MPH: 96.29
60': 2.210
330: 6.073
1/8: 9.310
MPH: 75.82
1000: 12.107
1/4: 14.455
MPH: 96.29
I'd say you really don't have the power to eek out another 4mph there. With weight loss and traction you could grab a 13 second slip, but the engine doesn't have the power in its current form.
Engine: LO3, LG4
btw, if you read my other post, it says i wouldnt do it in the quarter. Just the 1/8.
Hey, I think that a lot of serious and semi serous drag racers have thought about it at one time or another if they ended up with an extra pair of matching ones, but like I said, if you ever put them on the car and tried them you'd forget about the idea right away.
The quart of oil low thing is actually an old school serious drag racers solution also, it prevents any oil from getting whipped up and whipped around by the crank using up some power. With a stock, normal volume pump and an engine with near stock drainback it won't run dry, as a matter of fact, a quart low is the range of the "safe" zone on the dipstick. I wouldn't try road racing it like that, but it will be fine at the dragstrip. Many of us have done it, many, many times.
