1/8th mile tomorrow night 4/9
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Just cannow wait to see what my car will do, i am hoping for sub 7.5s in the 1/8th, would make me happy as hell, dont see why it couldnt do better, my last 383 with stock ported GM heads and a 288HR cam did 7.4x at best, so this with deeper gears and what i consider a better engine should go as fast i think, we will see. I know a set of pro ported 243 castings would unlock a lot of power in this 6.0.
Specs of car if you dont know it:
Victor Jr intake with MSD ignition controller
750 Pro form carb(mechanical sec)
LQ4, milled and home ported 317(.030)
Trex cam with matching springs/locks/retainers/pushrods
Hawks 1 3/4 primary swap headers, 3 inch collectors with dual 3 inch and 1 chamber flows with turn downs
Car is a T56 trans with CF DFX clutch and hays FW
Moser 12 bolt with 4.30 gears
Tires will be MT ET streets 26x11.5x16
CE sub frames, BMR panhard, Spohn TQ arm
So, i will be osting results should the car not decide to break. It has no issues pulling to 7000 RPM and makes power pulling till the rev limiter says hi. So far i have dusted a GTR nissan, a 91 5.0 LX with heads, cam and 150 shot could not pull on me and an array of other rides that just didnt stack up on the street, my budies 71 Nova ran 7.5x at best ad i murder him as well, but the street and track are two different worlds. Wish me luck and no broken parts, LOL.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 1/8th mile tomorrow night 4/9
Hope you make it out, more the merrier.
Well, you guys have me confident i should make some desired times, i have a buddy with a helmet so i hope i wont get kicked off....LOL.
Then ext visit will be on a 150 shot of gas, just got the window switch, waiting on fuel cell and fuel pump.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
How are your clutch/shifting skills?
Remind me, what are the details on your clutch? Flywheel, clutch brand/type, MC, etc.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
I can shift with the best, there is someone that is better but i am a damn good gear banger, always have had a stick and always trying to get better.
It is a Hays flywheel, centerforce DFX clutch and pressure plate. This clutch does well on the street, i hope it slips a touch so the tires dont break, but i doubt they will.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Pathetic, car does not want to 60 foot to save my life, 8.1 was the best with a 1.9 60 foot, launching at 5100 on the two step, best trap speed was 91.65 MPH. So, the MPH says it should go 7.4 or a touch quicker if the 60 was down, i am disappointed, but being a 6 speed, i guess i will just have to live witht he fact it is a street car not a race car. I did want a quicker trap speed, but the 317s are holding back compression and the Trex doesnt have the mid range to carry the car into a good 60 foot after i launch, so, i wish i went smaller but oh well.
mph is down a bunch, get that thing on a dyno and figure out where the lost HP is. Whether it's timing, or jetting something is off. Put it on a 28x10.5 stiff sidewall slick and you should have no trouble 60' that car.
Going fast isn't as easy as other peoples time slips
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Yea, i figure the 26" tire would make the 4.30s happy in the 1/8th. I cannot wait to dyno the damn thing and lean it out and get the timing dialed in to optimal power. I just wish i had some ported 243s to swap out while i was at it. Car has all the top end in the world and i shoudl have just went with a smaller cam like i wanted but the Trex was cheap from a guy on tech.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Yea, i had it down on the last pass and still only got the 1.9 60 foot, so i was like whatever.
if the car is dead hooking, he will have to keep raising his launch rpm until its not bogging any more. depending on how the car hits the tires and how much weight transfer, he may need more than 6500rpms.... also, if the car is hooking that well, expect things to start breaking. especially if there is a posi in the 12 bolt.
the 1st gear ratio is 2.66 i believe, and that makes the car want to either spin or bog if it hooks. a 2.9x ratio out of a '93 t56 would make it work better...
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Did some tuning at the track and my buddies 383 in his 02 SS that was putting about a car and a half to 2 cars on my from a roll is now staying wherever he starts and cannot put land on me, holds at a half a fender. So i have improved the tune since we last ran by a good bit i guess.
Car: projects.......
A clutch car should launch within 1k of peak rpm/shift point. If it won't you need to work on the set-up/tune-up till it will if you want to optimize it.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Sorry fellas, i have just been driving it on the street daily, drug many cars on the street, just dont want to break my clutch trying to get a good 1/8th mile time. Drug a 91 stang with gears, cam and a 175 shot of dope, going to put the 150 shot on it next month, then i might go back to see what it does on dope, bet it doesnt bog then. LOL.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Oh yea, since i am wanting a car to beat on at the track without worry of the 60 foot from a cam too big or any of that i am going to be doing a single turbo 5.3 or 6.0 in my 90 RS with a stalled TH350.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
This was playing around today taking a buddy for a ride, i must say, these are my longest back marks to date:
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
I pulled a 1st gear stab, smashed the brakes, clutched to second gear and stood on it. Stabbing it in first doesnt leave as hard of a black mark, but it is still there and you can see the 1 2 shift further down.
reminds me of the turbo car. Even with ET streets, 2.73 gears in 3rd gear with the Th400, it will roast tires just about as far as you want to go... Its useless unless your above 50-55 mph and use 3rd gear for the pull.
Your car looks fun man Love that top end I bet
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Yea, the cam makes allot up top, i wish i went with a smaller cam when it comes to the track, but it isnt a track car so
Car: 87 Firebird Formula
Engine: AFR headed SBC
Transmission: TKO 600
Axle/Gears: 9" Moser with 4.11's
Wait so smaller cams are for the track and larger cams for street something is wrong with this picture. If your car launched in powerband and you shifted it and it stays in its powerband it would do great at the track. How do cars with large cams do great at the track then? Not being an *** but that is not the problem when it comes to your track times.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
In my application, a T56 bogs launching on slicks at 5000 RPM at the track, launching at 6000 or 6500 might be fine, but i do not want to break my street car. My car with a 4500 stall or so would be great, but for me to have a car that is fun at the track and not have to launch at the moon would need a cam that makes power down low and mid range, mine has no low end what so ever.
Big cam, big stall, ig gear, works great, a clutch that clamps and drops RPM out of the power band is the missing key for me. But, it is not a track car so i am just going to leave it alone. There are stock bottom end LS1 that have gone 10.4x with a stalled auto, not with a manual.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Must be nice. My buddies nova does consistent 7.5s and at the track he would whoop me, but on the street...he wants a LS or a big block now. LOL.
I'm very leary of 12-bolt tq arm rears and a manual trans. I've seen several 12-bolts killed with an aggressive clutch launch.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Well, no issues yet, mine was a used unit and the myth of the TQ arm bolts backing out so far has not happened to me and the rear is quiet(except for the ratcheting sound when making low speed turns).
1 Post
Car: 1985 IROC-Z Silver
Engine: Vortec 5.7L
Transmission: WC-T5
Axle/Gears: 3.23 disc brake 10 bolt
Im curious to whether or not you have a fuel issue causing the bog on the launch???
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
No, i am fine on the street launching where it can wrap out and sin freely, so i think i would notice a big there too right?
#43
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Actually, i wouldnt mind trying that at the track, but for me it was simply the clutch clamping hard and dropping below aggressive operating range, this cam does not come to life till 4500 and it dropped to 3000 or so, but it wouldnt hurt to test that out. I need to look in my HP and see if it has the extensions in it.
1992 Trans Am
08-08-2015 08:16 PM
