Power with this setup?
Car: 1986 IROC-Z
Engine: 305 TPI - 350 in the works!
It's a 350 bored .060" over. 4 bolt main.
-Flat-top Pistons
-Stock Crank and Rods
-Vortec 062 Heads (64 cc Chamber)
-Edelbrock Performer Vortec Dual Plane Intake
-Quadrajet Carb
-Long-Tube Headers w/ Cat
-Stock Goodwrench Cam for now, undecided on an aftermarket one.
Help me out if I'm missing something?
-Flat-top Pistons
-Quadrajet Carb
Car: 1979 Pontiac Firebird Formula
Engine: 355 Chevy
Transmission: Turbo 350
Re: Power with this setup?
i would go with a .450ish to about a .470ish cam also throw that quadrajet in the trash and get a holley
that motor should scream...My firebird is .030 over with 4 valve flat tops, a .480 crane cam, bone stock heads off a 81 c10 350, 1.6 roller rockers,edlebrock rpm intake and a 670 street avenger, and the time is posted in the sign.....its amazing what a difference makes in flat tops as apposed to dish pistons
Car: 1986 IROC-Z
Yah, I forgot to mention it'll be running 1.6 rollers.
Also, I'm thinking compression will be around 10:1. Does that sound about right?
Car: 1986 IROC-Z
Any other thoughts?
The compression ratio is really what I'm interested in. I don't want it to be too high, considering the flat-tops and 64cc chamber.
Also, I just bought the Comp XE 268 H cam. With the 1.6 rockers, I figure the lift around .508??
And what CFM should I run with this? I'll have to pick up a new carb since the Quad's not lookin so good.
sailtexas186548
08-24-2015 10:11 PM
