Going 6.0
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Going 6.0
Alright guys, i ditched the big block project, i really wanted to do it but i could not in the end afford to do it the way i wanted to get the most power out of it. I could have, but i want it now as i am greedy so what can i say.
So, i bought my 6.0 for 700$, i have the T56 with CF D/F clutch and Hays flywheel, not to mention i already have a Moser 12 bolt in the car with 4.30 gears.
I will be swapping the 317 heads for some 241s probably, mill them down to get 10.5 compression, cam i want is 236/242 @.050, .580/.590 lift on a 112 LSA
Going Vic Jr with a proform carb i built that is mechanical at 750 CFM, MSD 6LS box and i bought the lap top to tune with.
Shooting for 450 to the wheels, we will see.
I am in hopes of 100 MPH in the 1/8th at sub 7s.
What you guys think?
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Going 6.0
With 3.42 gears and a 3500 stall footbreaking a 79 malibu with a 6.0 and 650 vacuum secondary with 317s and a 232/234 cam V2 torqer, heads ported by me on a rush job flowing 267 at .600 ran 7.3 at right at 97.
So, i am hoping that more porting and the bigger carb and more cam with the deeper gears will net the extra 3 mph and a few tenths. Ought to get out there with the 26x11.5 ET streets.
Re: Going 6.0
toquer v2 cam has alot more sophisticated valve action than the camshaft you listed. based on duration/lift numbers, the lobes are lazy and will leave alot on the table.
i'm going to be running one of the new comp cams LSr camshafts. much quicker ramp rates, and puts the valve into the better flowing portion of the cylinder head (with good porting or aftermarket cylinder heads) my cam is a 231/239 .617/.624
267 is garbage compared to most aftermarket heads or cnc ported stock heads. the norm is 300cfm, PRC has a decent cnc ported 5.3 head that flow 312 at .600, and will bump compression to close to 11:1, if not more...compression builds torque, and is important to have lots of it with a camshaft like you're looking at. and for the cost at $1150, you can't beat it.
i just feel it's a bit overboard on duration, low on lift, which equals lazy ramp speeds, and not quite enough cylinder head. the car will make peaky torque curves and will be tough to drive.
but it'll sound nice
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Going 6.0
Yea, but for what the car is doing on a rush port job, it is damn good, better than i thought it would. I might find a different cam if possible, but i am on a budget and the grind i found is a regrind for 125$.
If i find something like what you are going to run for cheap, sweet, it is what i was looking for, but i doubt it will surface for 200$ or less.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Going 6.0
As in dont mess with it at all or the short block(which i plan on doing)?
Just doing a cam and ported heads.
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
Re: Going 6.0
Car: 02 SS
Re: Going 6.0
stock crank, rods, speed pro replacement pistons, arp rod bolts.
self machined and upgraded vj rev 2.02 valves with bc 243's 11.25:1scr
HKE spec cam, udp, ps lt, jesel ss 1.7, tsp pr, pp dual golds, stock ls6, ported bbk 85mm tb, sd tune
stock t56, spec3+. stock rear. 7000rpm shifts. 493rw n/a
have also ran 150 dose thru it countless times.
Re: Going 6.0
All these high peak hp motors never really do that well at the track compared to my smaller cam choices with more overall power. I could care less that for 200rpm the motor makes a ton more power, I'm more interested in overall power. Besides I run one of the quietest exhausts out of anyone else at our track rentals and my cam only setup has embarrassed quite a few shop built heads/cam motors. I'm looking forward to selling off this ls1 and tossing in a L92/6.0L soon as well.
Re: Going 6.0
you can hit 500rwhp with a 6.0L, AI/tea 243's and a fast 90/90 with 232/236 cam with the belt pulled.... seen it done.
doing it with self ported heads and a stock LS6 intake is for sure pretty awesome.
you can go 6.90's@100 with a nice set of heads and a 230ish cam if the car is setup pretty decent.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Going 6.0
Well, if i can pick up:
TSP XS Series Camshaft:
233/239, .595"/.603"
OR:
The Texas Speed Tsunami 235/240, .654"/.609", 111 LSA Camshaft.
For a good price with my discount, i will go that route for sure, i prefer the first one so my valve spring choice will be a tad cheaper.
OR:
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Going 6.0
Ls1 is a 346 and the 6.0 is a 365, so it is nearly 20 cubes and that translates to 30 more HP or so.
Glad you like small cams.
Car: 02 SS
Re: Going 6.0
i highly reccomend that u check out the LPE GT11 cam. that is one killer cam when paired even with stock ls2 heads. dont let its low duration fool you. it is very aggreesive wot. ive used this cam before twice now and have reccomended it many times all the times with great feedback.
it is even more pronounced in 6.0 engines. even with stock 317 heads and mill down for 10:1
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Going 6.0
Honestly, i am thinking about the Torqer V2 cam to bring things down a bit more, i still have time to figure it out, that way the power levels will be less peaky and more across the board...
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Going 6.0
Well, to compare, we took my buddies 79 malibu to the 1/4 last friday,Mods:
99 6.0, 317 with a slight port job by me(bowl blend and clean up, torqer V2 ca, 232/234 @.050, LQ4 pistons, heads were milled to get 10.5 or so, Vic Jr intake with Demon vac sec 650 carb. TH350 with 3500 stall, 3.73 gears. Car weighs 3240 without driver.
1.7 60 foot (previous best 1.8)
7.4 @ 95 mph (previous best 7.3 @ 96 with 3.42 gears)
11.58 @ 117
So, with that being said, there is more left on the table, the weather was nice and cold, so it should have done better or as good as it has.
The 1/4 mile from the 1/8th time told me it is losing 30 HP or so, i think it is not getting the fuel it wants. Trapping 117 from 95 in the 1/8, a 22 MPH gain and it should have been a 120 or so. Funny thing it, we had the best ever 60 foot with the new 3.73 over the 3.42 but we were .10 slower in the 1/8. Something in the tune is not right, but we only made 1 pass, so the truth is there is allot left in the car, i think it has 11.0 in it.
So, from that, that is why i want the slightly bigger cam, port the heads a bit more, and i have a deeper 4.30 gear and i want to shoot for 10s
11.58 @ 117
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Going 6.0
Well, her are the specs of the cam i am going with, it is a bit larger than i planned but it is designed for carbed LS engines like mine, the PTV is the only issue i will need to check out, but it will be a running MFSOB, not to mention it will sound sick:
Intake Duration: 236 Degrees at .050" Tappet Lift.
Intake Lift: .615" with 1.7 rockers.
Exhaust Duration 248 Degrees at .050" Tappet Lift
Exhaust Lift .615" with 1.7 rockers.
108 Degree LSA
108 Degree LSA
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Going 6.0
Alright, cam i laded is a Trex, so that is the change, ported the heads, dropped them off, have the 6010 MSD6LS box, vic jr intake, going to use a S10 manual steering box still, and i am really trying to pull some scratch together for some headers that are decent enough to support the engine.
For those that dont know, the Trex is: 242/248 @.050, .608/.612 lift on a 110 LSA. So it is allot bigger than i planned and the cam has made 430 RWHP on bolt on LS1 cars with unported heads with a best of 10.4x on motor i think is the record for the cam, so i am thinking i will be pleased with it.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Going 6.0
Id be happy with that, but i will be not happy till i am cracking 10.99-11.49 on motor. We will just have to see if i can get kicked off the track in one pass, LOL.
Car: Pair of 92 Z28s
Re: Going 6.0
What kind of race weight are you hoping for?
My bolt-on Z06 does 11.3x on stock clutch. About 380rwhp 3215 raceweight. That is with M12 gearing which is the equivalent of M6 with 3.73s.
I'm building a cam only ls1 for my third gen i am hoping for 29xx raceweight with my skinny self. M6 with 3.73s. Hoping for bottom 11s, high 10. Hopefully no clutch issues with this swap. I do rentals mostly so not looking at putting a bar in the car right now.
Clutch cars can be a pain on the strip...everyone knows that. It is also very hard to get slip from some clutches. They can be too grippy and cause massive bog or rip the car apart on a good launch. Well with corvette rears that is...
What clutch are you going with? Still on 10 bolt?
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Going 6.0
Think it will be about 3200 lbs, it has a Moser 12 bolt with 4.30 gears, so launching should have zero bog, at least i have never bogged with 4.10s or deeper. It is a center force dual friction, i think it is going to slip honestly.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Going 6.0
Yea, that si the numbers i am looking for, 10s would be awesome, but i think the lack of compression might hold back.
Did get the Hawks 1 3/4 3 inch collector headers on order.
Car: projects.......
Re: Going 6.0
I love everyone getting tied up with flow numbers and dyno numbers....my 496 with a set of old as dirt conventional big brodies made 423rwhp n/a but ran in the 9's @ 3020lbs. Flip the switch before you launch and that quickly becomes low 8's.
Screw racing dynos and flow benches, build a well matched combo and enjoy it.
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
Re: Going 6.0
#42
Re: Going 6.0
i understand that there is alot more hype on dyno numbers and flow numbers than there should be, but those numbers are there to help you. who cares about peak numbers, what i care about is numbers across the board. whether we're talking power numbers under the curve, or mid lift flow numbers. they ARE important.
i picked up a really nice set of cnc ported ls6 heads for under $1500. that's dirt cheap for the flow numbers they put out. with the amount of money i was going to pour into the 317 heads i had to make those work, i was nearly to the cnc heads anyway. i don't have the equipment to do my own machine work, so machining costs have to be factored in for me.
long and the short of it is, that i think everyone that was telling him there are better heads out there for the money were just saying that his efforts would be truncated if he'd spend about $1000 more on the overall combo. (cam, heads, everything)
#43
Re: Going 6.0
Some of us just go with what we can afford and bottle or force in what it doesn't do on it's own, lol.
#44
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Going 6.0
Exactly, most people dont know that mid lift numbers on LS cars mean more than peak numbers any day. I personally wish i could get better heads right now but i dont have the cash. I just ported and polished my headsfr free, doubt i picked up more than 20 CFM but it was free, so between milling, valve job and springs/lock/retainers i will have a set of home ported heads for 400$ ready to rock, not allot of money and the springs can be swapped out if i get different heads, not bad for a budget, i am still sick over spending so much on headers though...
Also, across the board is where the LS engines make more power than the old SBC engines, just another reason they are the way to go in my book, but i still wish i could have finished my big block, LOL.
#46
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Going 6.0
Well, the fact that a SBC will never be able to strap in a cam and pushrods with some springs mad make tons of power like a LS is the whole budget thing for me. SBC need to have allot replaced to keep up with what the stock LS can so, ANY LS aluminum heads will flow over 300 CFM, a SBC cannot say that. The LS is just the update and the older SBC needs too much to keep up, i have built many of them and now i have just given up since:
A SBC needs a distributor, ignition box, 2 step and timing retard box that is over 500$ worth of parts to compete with my MSD 6010 that has all of that built in for a touch over 300$.
Wish i would have had the funds to finish the big block, but at the same rate, i can just get another 5.3 0r 6.0 for 5-700$ if i need another one VS blowing up a big block and having to search, then build and all that, i just found the most well rounded way to go about making a very fun ride and not break me if it breaks.
Not to mention, SBC rods suck compared to the LS setups. The pink rods are ok, but capscrew rods are what i used in my SBC anyway and the LS just has it stock.
I can keep going on and on, i am happy with my decision.
#47
Re: Going 6.0
I honestly doubt the sbc vs bbc vs ls debate will ever end. All three can be built to work well in many applications. That said, stock for stock the old-schoolers do not compare to an LS motor, however, aftermarket vs aftermarket is a whole new can of worms.
The old-school sbc merlin block designed to use the LS heads is probably king of the "semi budget" small block builds, while the big $ can still be thrown either way to make either combo work well.
All that aside, there still is no replacement for displacement. I've got a full can of BBC whoop-azz that can be available to any type small block that wants a piece. I can even do n/a, n2o, or fi.
#48
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Going 6.0
Yea, but that block is nowhere in the term budget for me, that thing is out there in price. I cannot lie, i wish i did the big block, but there is no convenience for me to use one...unless i made allot more money.
#49
Re: Going 6.0
Well, the fact that a SBC will never be able to strap in a cam and pushrods with some springs mad make tons of power like a LS is the whole budget thing for me. SBC need to have allot replaced to keep up with what the stock LS can so, ANY LS aluminum heads will flow over 300 CFM, a SBC cannot say that. The LS is just the update and the older SBC needs too much to keep up, i have built many of them and now i have just given up since:.
Not to mention, SBC rods suck compared to the LS setups. The pink rods are ok, but capscrew rods are what i used in my SBC anyway and the LS just has it stock..
A well built SBC will cost the same as a comparable well built LSx engine u cant cheat that by buying junkyard parts.
#50
Re: Going 6.0
that 215cc lsx head you quoted as only flowing 314cfm was on a 3.90" test bore@ .600" lift, the SBC 220cc heads you quoted flowing 326cfm was on a 4.125" test bore@ .700"lift. please make sure you have apple to apples before throughing numbers around. the same 215lsx head on a 4.125" bore flows peak 324cfm @.600" lift, the SBC 220 head only flows 317cfm on a 4.125" bore and .600" lift. also, mid lift numbers on the lsx heads is superior to the sbc heads. thus...making MORE power across the board in a similar combo.
for comparison, my PRC stage 2.5 ls6 heads flow 316cfm on a 3.9" bore at .600", and cost $1400. take that AFR sbc 220cc heads!
stock connecting rods and crankshaft with arp upgrades have been known to be reliable at 550+rwhp range on the lsx. can your chevy "pink" rods say the same?
