street/strip engine, need carb.. what to buy?
right now my 496" is operating on a barrowed team G intake and holley 1050 dominator, he wants it back! haha... I've got to buy my own..
496"
merlin 310cc rect ports 2.19/1.88's
10.2-1= estimated, 170 psi cranking compression confirmed
herbert solid roller:
.685/.685" @ 1.7 R/R
253/266 @.050
286/301 adv.
108 lobe sep
102 ICL
2" shorty headers (needs upgrading)
hei ign (also needs upgrading)
TH350
4.10 rear gears
275/60/15 tire
I own a Professional products hurricane intake, 4150 flange, sounds more reasonable??? What about carbs? I know the 1050 is to much, I wish I knew the VE% of the engine, if its in the high 90's then 1050 wouldnt be, but im guessing some where in the high 80's, I found a brand new QFT Q-850 on ebay $499 buy it now, is the 850 gonna be sufficient for 7000 rpm?
also as the Stroke goes up, does the max rpm range for a cam go down? the cam claims 3000-7000, can i really expect 7k from this stroker?
also would like input on the combo? what should have been done diff?
496"
253/266 @.050
286/301 adv.
108 lobe sep
102 ICL
TH350
4.10 rear gears
275/60/15 tire
1 Post
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
Re: street/strip engine, need carb.. what to buy?
I don't have to much technical carb talk for you but I can offer experience. I personally was running a Demon 750 and it ran it's ***** off down the track. I drove the car very often on the street and it sucked. Idle jumped everywhere, bogged, and always came out of adustment. I gave PAtrick a call at Pro Systems and converted to a holley. It was a great move. The carb is taylored to what I do with it, and the streetability has picked up by a ton. All the problems are gone accept now it makes a whole bunch more bottom end torque and broke my damn rear.
Another thing to note is the history of holley and the available knowlage and parts around to tune them.
I listen to peoples BBC combinations around 10-15 times a day sometimes. I would personally say that 90% of people with an efficient combination laying down good numbers run Holley's.
I would give the 4150HP a good look. It's holleys most advanced off the shelf 4150 and has a great reputation. I chose to go with a builder because if it has problems it will be on a brown truck back to them or they can personally walk me through it.
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
Give TRC, Total RAcing Components a call. They specialize in Carbs. I had a Pro Systems and switched to a TRC and picked up 1.5 tenths on the quarter.
Zachattack0925
08-12-2015 09:52 PM
