some info
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
some info
Hey Guys been away from the race set for a few years.
getting a new eng and wanted to know about the price.. see what ya think
about the sort block price all mech work with Just rod's crank piston's all put together and shipped
422 CID 4 bolt 400 block
all mech work
6" rods forged after market (cant think of the name now)..ya i know
forged steel crank..... (also aftermarket....)
forged pistons.. 11.1/2 .1 with my heads (trick flows)
all the parts to go with the above (rings. cam bearings)
$3500 (this is from a shop in cali) shipping will be another $150 (think)
ill do the cam install.. along with all other parts..you name it.. it's there..
all my 383 parts will bolt on
flex plate (aftermarket)
milidone 8qt oil pan
milidon windage try
(the bolts from my eng? for this.main bolts ill send them new ones)
fluid damp
pass side dip stick
gear drive.. ill set it up agen
cover
ya think $3500 is about right...
same guys did my 383 back in 1993
it lasted 8 years..of beating on it...lol
all mech work
milidon windage try
fluid damp
pass side dip stick
cover
3rdgenparts
05-21-2016 11:50 PM
Linson
10-01-2015 09:50 PM
