Who said you can't go bracket racing with fuel injection?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
Re: Who said you can't go bracket racing with fuel injection?
i actually prefer fuel injection...my lumina would do that too lol
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Wow, pretty close passes for sure!
Car: 86 Camaro
![EEK!](https://www.thirdgen.org/forums/images/smilies/eek.gif)
Dan
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
nice.. when i was running mid 12's, i did 3 runs with increments within .015.. had no traction and a stick.. lost cause of a red light.
![doh](https://www.thirdgen.org/forums/images/smilies/doh.gif)
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Those are some very consistant times. What tires are you running?
Car: 87 GTA
How did you get identical ETs, when the Reaction Times are so far apart? Something is wrong with those time slips......
![Confused](https://www.thirdgen.org/forums/images/smilies/confused.gif)
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
ET doesn't start until the front tire clears the 2nd (staged) starting line beam. You could sit there for 2 minutes after the green comes on and still run exactly the same ET.
Car: 87 GTA
Gotcha.....
I knew that was how autocross worked, but they also don't tell you your reaction time, just the lap time. I just don't drag race so.....
I always thought that (in drag racing) the timer started with green, meaning the reaction time would be deducted from the run time.
So in reality, you don't hafta worry about reacting to the green? Just run a quicker time? Sleep for 2 minutes & still win?
![lmao](https://www.thirdgen.org/forums/images/smilies/lmao.gif)
Car: 1987 IROC
Engine: 350 vortec
no the reaction time is added to the elapsed time, still first one to the stripe is gonna be the winner, thats how i've won a lot of races i shouldn't have
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
9192camaro
16
02-03-2019 12:21 AM
Fast355
12-02-2016 06:33 PM
