Need help hooking up
Went to 75 80 tonight for the first time since i swapped the auto for a t56. The car felt good and pulled hard but I couldnt hook up at all. Im running 315 nitto drag radials and the best 60 ft i could muster was a 1.9. Im running a factory suspension setup. Best ET was 12.9 as opposed to a 12.6 with the auto. Most of my 60 ft times were over 2 seconds. I tried heating the tires and not with no difference. Do I need some ET Streets? A torque arm? The rear shocks are kybs in pretty good shape. MPH was 108 if it helps.
Motor is a 406 with rpm heads, flat tappet cam with 226/234 duration. I was expecting a mid 12 but never came close
http://www.facebook.com/video/video....0682905&ref=mf
Thanks in advance
Thanks in advance
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Need help hooking up
Can't see anything on facebook unless you're a member of facebook. Try posting the video somewhere else like streetfire.net or youtube.
Post a timeslip with the auto and post a timeslip with the manual.
The slips are too faded to see after being scanned.
Auto Best
60ft: 1.83
ET: 12.68
MPH:108
6 Speed Best
60ft: 1.90
ET: 12.91
MPH: 108
http://www.youtube.com/watch?v=2fmLuCMunOY
It didn't bog at all, just spun like hell. I tried launching off idle and still no luck. I've heard drag radials don't do as well with manuals?
Auto Best
60ft: 1.83
ET: 12.68
MPH:108
6 Speed Best
60ft: 1.90
ET: 12.91
MPH: 108
Car: 87 IROC L98
That's not enough information for a timeslip. Need a complete breakdown to see what the car is doing all the way down the track.
Auto
RT: .274
60ft: 1.832
330: 5.244
1/8: 8.090
1/8MPH: 86.12
1000: 10.544
1/4: 12.632
1/4MPH: 106.89
6 Speed
RT: .357
60ft: 1.903
1/8: 8.319
1/8MPH: 83.24
1/4: 12.917
1/4MPH: 108.59
The track I wen't to yesterday didn't show 330s or 1000 ft times.
RT: .274
60ft: 1.832
330: 5.244
1/8: 8.090
1/8MPH: 86.12
1000: 10.544
1/4: 12.632
1/4MPH: 106.89
6 Speed
RT: .357
60ft: 1.903
1/8: 8.319
1/8MPH: 83.24
1/4: 12.917
1/4MPH: 108.59
Car: 87 IROC L98
Auto
60 = 1.832
60 - 1/8 = 6.258
1/8 - 1/4 = 4.542
Manual
60 = 1.903
60 - 1/8 = 6.416
1/8 - 1/4 = 4.598
More numbers gives a better breakdown of a run.
Given that the manual was making 1.7 MPH more than the auto, more power was getting to the wheels. With the manual, the 60' times were worse and it could be for any reason such as too much torque off the line, poor track prep, worn tires spinning, etc.
Breaking down the run into sections, the car was slower all the way down the track. Slower 60' time, slower time from the 60' to the 1/8 and slower time from the 1/8 to the 1/4 so all that can't be contributed to bad traction. If you had the same ET as the auto, your 1/4 mile time would still have been slower.
Because of the better MPH, I'd rule out weather conditions or a vehicle weight change with the tranny swap. The only thing I could see which would result in a slower ET all the way down the track is the shift point in relation to the powerband.
The T56 is really a 4 speed with two overdrives. If geared properly, you should be crossing the finish line at or just before the shift into 5th gear to make the best use of the power. There's also the delay factor in the time it takes to shift. That split second between the gears will slow you down unless you're brave enough to powershift without a clutch.
60 = 1.832
60 - 1/8 = 6.258
1/8 - 1/4 = 4.542
Manual
60 = 1.903
60 - 1/8 = 6.416
1/8 - 1/4 = 4.598
thats about all i could do with nittos also. 1.9's... they suck. ok for street tires, but dont expect much at the track.
most any other drag radials will make a world of difference. also work on your shifting. most people are not very fast with their shifting and lose quite a bit of time that way. powershifting is the only way to go, imo. keep it floored, and tap the clutch just enough for each shift.
Car: 87 IROC L98
A DOT "slick" is not designed to run on the street. Driving on the street heats and cools the tire excessively. The oils in the tires to make them sticky will dry out and won't perform at the track like they should. The only reason for a DOT slick is to race in a class that demands a DOT tire. If you don't race in such a class buy a second set of rims and have slicks mounted on them just for the track and leave the street tires for the street.
As I already mentioned, you were probably spinning off the line but even if you hooked up to equal the 60' time you got with the automatic, you were still running slower all the way down the track so it wasn't just a traction off the line issue.
I'm not looking for a drag car, I just think that i should be cutting better than 1.9 60 60 fts with a 406, 3.73 and 11 inch wide drag radials; am I wrong?
It looks like I'm gonna invest in a set of extra wheels and slicks, and work on the shifts, thanks for the advice let you all know how it goes.
1.53 60' in my 4th gen with et streets on stock 16" wheels. only chassis mods were jegster torque arm and eibach pro lowering springs. car made 376rwhp, and i was dumping the clutch at around 6200. had a 12 bolt with 4.30 gears.
it would probably have done the same on a set of m/t drag radials as well.
Car: projects.......
I went consistent 1.66-1.69 60fts on the 315/35/17 nittos with my stick. My buddy's '02 stang bested a 1.69 on the nittos, averaged 1.70-1.72.
W/o a tuneable suspension it's hard to make small sidewalls work, especially with a stick.
Car: 87 IROC L98
Adjust the pinion angle so it's down 2-3* in relation to the driveshaft.
The LCA should be parallel to the ground or down slightly in the rear. You'll need relocation brackets to change the adjustment. Changing the ride height by cutting coils or using drop springs will change the angle of the LCA, usually making it worse.
Stock ride height via new springs or 17+ year old original springs? - Check the angle of the lcas, as Stephen stated, you want level or slightly downhill toward the back(body mount point higher than rear). If you find the angle to be at all up hil toward the rear end, then you want/need the lca relocation brackets.
Lca's are a good start, not just for their strength but for age alone you will likely see a benefit. With the short length of the Jegs arm, 2-3 degrees down pinion angle would be a good place to start.
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
better ad relocation brackets to the list. my lower control arm bushings were so worn i could move the axle almost 1/4 inch back and forth. it was a little scary
I like the jegster tq arm with my set-up, I would not use relocation brackets with, being such a short arm it always wants to raise the car. I put my relocations back to stock with the jegster.. Its also on the noisy side, I would put some sound deadening material over tunnel where the arm is. 4.10 will help a lot, the 2.66 gear in the T56 makes it hard to launch with, compared to 3.06 or 3.35 in a mustang first gear.. I have gone 1.50 60s with mine, using a fast slip w/4.10, jegster TQ Arm, ET Streets. Second on the shifting as stated above, work on making that faster, I had been out of my car for about a year, my shifting was way slow comparing last years - keep practicing - You arm will be faster than foot if timed right, keep throttle pegged, Pull gear and tap clutch as fast as possible. I could shift with front ever losing elevation, but this year till I get a few more passes I was lagging in fear of missing gear till my timing is back.
here is a vid of us running a buddies bolt-on LT1 car....
http://vids.myspace.com/index.cfm?fu...ideoID=2221856
some guy actually came up to us wanting to know how we kept the front end up on each shift. lol
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Personally, i am great at shifting. I am not the best, but the swap to 4.10 gears in my 89 was a real test on the street. There was no way to spray first gear and it not spin WAY too bad.
Dont know how the 4.30s with the big block is going to be.
More often than not the lower gears can be easier to hook on the street. Yes, they muliply torque but they also lower your initial wheel speed. We were running a 4.56 in my buddies stang and it was A LOT easier to drive/hook than the 4.10's have been, but he was running out of rpm in the 1/4. A few changes since then may put us back to a 4.30. Time will tell.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
What your saying is that a 3.23 gear spinning in 1st at a 5500 RPM engine speed is not going to hook as well as a 3.73 since the tire speed is slower with the numerically higher gear right ****?
i do agree, the taller gears make it alot easier to modulate the clutch off the line and get a decent 60'. 3.42's and a grabby clutch makes it either bog or light the tires up.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
I couldnt stand the 2.73 gears, i had head and cam LS1 cars whooping my off the line and i had to reel them in by second and then i could leave them in 3rd. Got allot of respect but it still sucked. Especially at the track.
I am just glad to have a rearend that is not going to break like the 10 bolts.
Wen't back to the track today and was able to pull off a 12.6 at 111. 60 ft was still a little slow at 1.8. This time I powershifted and feathered the throttle off the line. Difference in the suspension is a jegs adjustable torque arm and spohn lc arms with the rod ends. The issue now seems to be 1-2 shift, I spun pretty hard. Im thinking with a set of slicks I should be able to cut a faster 60 ft. and could probably use a set of lca relocation brackets.
Z28/ZR1
10-23-2015 01:04 PM
