aftermarket brakes?
Car: 91 firebird
Engine: sb2.2 headed sbnos
Transmission: tsi glide
Axle/Gears: 4.30
aftermarket brakes?
Just installed the strange drag units on the front. Now i need to know what to do about the brake lines. Anyone done this yet? Should be the same as the wilwood and aerospace set-ups. The calipers use a 3an.
Thanks,
Aaron
Thanks,
Aaron
Car: 91 firebird
Axle/Gears: 4.30
Re: aftermarket brakes?
the adapter fittings are for the following: 3/8-24, 10mmx1.0 for 3an im not sure which our cars have but thats what my plan was too bad everything is closed...
i just anny'd up and bout the premade lines from sjmmanufacturing.com for $70 or whatever. popped them right in the car and fit like a glove. i have the strange pro drag brakes front and rear in my car. just finished installing the front ones, matter of fact.
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
i have a set of braided lines that are 3an on one end and factory metric on the other.
id let the set go for 40 shipped if you are interested.
1 Post
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
OK, then for you guys running those brakes, is there any real weight savings??? I have "heard" 20# of weight loss, but I just don't see how its possible? Anyone have some hard #'s???
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I never weighed my front brakes.
Factory:
Cast caliper
Cast vented rotor/hub
Aerospace brakes:
Aluminum caliper with an aluminum mounting bracket attached to a modified spindle
Aluminum hub
Single steel rotor bolted to the hub.
The aluminum caliper and hub save a lot of weight and using a single disk rotor instead of a vented rotor saved a lot of weight. This is a drag racing only setup. The single disk rotor wouldn't be able to handle the heat generated from stop and go driving on the street with such a heavy car. For street driving, I'd recommend any dual vented rotor system.
Factory:
Cast caliper
Aerospace brakes:
Aluminum hub
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
i now have a vented rotor on the car which aerospace told me was 4 pounds per side more than a drag kit.
i didnt weigh my front kit. was in a hurry.
pretty sure its going to be close to the 26 pounds mentioned above compared to what i had in the rear.
Night rider327
09-02-2015 04:17 AM
